Question about Monarch 9855 Thermal Printer
Monarch 8055 error 754 ribbon error. i checked what the manual states is the problem. ribbon tension is fine. does it require a takeup reel?
    Novelist:
  • 113 Answers
Yes, it does require a take up reel or core. It should look the same as the one that is in the core of the ribbon spool.
You can order these from the manufacturer. Please note the width of your ribbon, as there may be more than one core width for sale for this model.
Their number is 1-800-543-6650
Ohiotech
Posted on Feb 06, 2008
Tascam 388 The drive belt broke. After I replaced it for some reason the takeup reel moves backward when I push play. What's up??
This machine uses a servo tension system. I am guessing that when you changed the belt you also upset one of the sensors. You will need to get a service manual and go to the tension setting section to verify or correct what is going on. These units were pretty complicated for regular users.
Apr 06, 2013 | Audio Players & Recorders
I have a single cassette deck Philips DC 900 when you hit the play button,it plays for about 5 seconds then stops and head retracts. Belts have been replaced
It's not seeing the takeup reel turning.
Either the takeup reel isn't turning or the takeup reel sensor has malfunctioned.
Check the belt to the takeup reel by doing a fast forward.
Will it fast forward? and is the takeup reel spinning during playback?
Feb 27, 2011 | Audio Players & Recorders
I have problem with 9825 mo
Yes, you can.
Under the supply setup menu change ribbon to "NO". This shuts off your ribbon and allows you to print direct thermal with any 754 ribbon errors.
Jun 26, 2010 | Monarch 9855 Thermal Printer
Riccar 9600, no manual, how do we thread it?
If I remember it is reel of thread on the reel pin, make sure the presser foot is up and takeup lever at the top, take the thread to the left and over the top cotton guide, straight down through the tension disc and down to the larger guide, round the right and take the thread back up the left hand side, through the takeup lever right to left and follow the guides all the way down to the needle, thread needle front to back.
Mar 28, 2010 | Sewing Machines
Take up reel not working on Monarch 9825 printer
Go into the printer's menu and turn on the ribbon, or if you are using a 3rd party software, go into the software settings to tell the printer that it has a ribbon.
If you go through the printer, use this document. Go to chapter 4, page 4.
http://www.monarch.averydennison.com/support/doclookup.asp?printer=9855&doctype=oh
Jan 04, 2010 | Paxar Monarch 9825 Thermal Label Printer
Tape stuck in sony uvw-1800
02-874 error code signifies a defective takeup reel. The reel is not winding the tape in, so the deck won't go through the eject procedure. Check the connection to the takeup reel motor; if that's OK, the motor itself may be bad. Rarely, the takeup reel motor assembly will need to be replaced; usually it's a connection problem.
Jul 02, 2009 | Sony UVW1800 VCR
9855 ribbon take up reel not working
When you're sending data to the printer you're sending a command that is telling the printer you're NOT using a ribbon. When the printer receives the data it's shutting off the ribbon. Check your software.
You should be set for THERMAL TRANSFER.(RIBBON)
THERMAL DIRECT Means NO RIBBON
Feb 04, 2009 | Paxar Monarch 9855 Thermal Printer
Error code 754
It's very possible you are not installing the ribbon properly.
When loading a new ribbon on a Monarch printer, you must save the plastic ribbon core (it's butter yellow in color) from the previous roll of ribbon. The core is what the ribbon is wound up on.
Do not throw away this plastic core - you need it for the next roll of ribbon you load!
You have to move this now empty core from the back ribbon spindle and slide it on the front ribbon spindle. You then load the new ribbon on the back spindle and attach the ribbon end to the empty plastic ribbon core on the front spindle.
You CAN NOT just tape the ribbon to the front spindle. You must have an empty ribbon core to attach the new ribbon to. The printer will give a 754 error unless you have two plastic cores on the two spindles. It can also give a 754 error if the ribbon is not loaded properly, and also if you have a bad motherboard. There are no ribbon sensors, so that's never going to be a problem...
Jul 28, 2008 | Paxar Monarch 9850 Thermal Printer
AG-DV2000
If you are seeing tape collect inside the unit, the takeup side is not functioning correctly. This may be as simple as a belt change or idler change. This is not a repair I would suggest that you start with. The alignment of the tape is critical to proper functioning. I would geuss that the "link support mech" is probably just the belt/idler assembly or it is a "mode" switch. In any case, this unit should be sent in for repair. As part of that repair, the conformance to industry standards.
Dan
May 12, 2008 | Panasonic AG-DV2000 Mini DV VCR
Ribbon error 754
Your printer is not correctly configured for ribbon. Download the manual located at ftp://www.servisource1.com/user_documentation/9855/9855oh-ae.pdf
Go to chapter 4-1 to see the map of the menu system and change your printer to ribbon yes.
Make sure that your printer is loaded with supplies and the ribbon is set up correctly, as well as slack taken out.
You may see a couple of labels not print well, but after that, you shold have proper tension and good print. If you notice a lot of ribbon wrinkle, you probably need to reload your ribbon or adjust the tension bars.
This should resolve any issue you have with the ribbon.
Ohiotech
Sep 14, 2007 | Monarch 9855 Thermal Printer
Monarch 9855 Thermal Printer Logo
467 people viewed this question
Top Monarch Office Equipment & Supplies Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
David Payne
David Payne
ka4iup
ka4iup
Are you a Monarch Office Equipment and Supply Expert? Answer questions, earn points and help others
