Question about Canon PIXMA MP460 All-In-One InkJet Printer
Error code i just bought a new canon printer. but as sooon as i installed it a orange light started flashing and the screen says error code 5100 some help i dont know waht to do
  • 3 more comments
  • Anonymous Dec 31, 2007
    i ve got this same problem erroe 5100 , and i have already installed the printer
    this same problem error 5110 ? what i have 2 do?
  • Anonymous Jan 03, 2008
    i have the same problem as u an orange light flashes and on the screen it sayes error code 5100 can u help me fix it
  • Anonymous Jan 08, 2008
    yjjiyg
  • dubbase Jan 12, 2008
    Tried to put in cartriges but they won't click into place, it's a new machine.....any thoughts?
    President:
  • Canon Master
  • 2,022 Answers
See all the catridges are properly installed
Posted on Sep 25, 2007
SOURCE:
I've got printer canon PIXMA MP170, it has error 5100. The green light and orange light flashing 2 times flowing each other.
http://www.youtube.com/watch?v=tmTJdJTAhYU
I am assuming this is a new printer install. You have to go thru the entire printer and remove ALL the shipping tapes. This one was worse than my HP all in one, which had 12 pieces.
Mar 03, 2013 | Canon PIXMA MP170 All-In-One InkJet...
Cannon Pixma ip90 printer mechanical failure code 5100. Printer works for about 2 inches then stops with failure code 5100
The error 5100 actually means nothing. You need to look at the printers green and orange lights. they will be flashing in a certain sequence. Count the way the lamps flash ie.Green are mechanical faults and orange are operator correctable faults. When you have the info repost and i will help you further.
Jul 27, 2011 | Canon Office Equipment & Supplies
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Green and orange light is blinking continuous.. and the cartridge head is not moving. ip1980.. please help..
    check the status of the printer in its driver. the error will be shown there. error 5100 is the most common. error 5100 means the carriage is experiencing difficulty in moving itself.
    Jan 19, 2010 | Canon PIXMA iP1800 Printer
    Printer not working. The light flashes red six times.
    Error Condition Indicator Beeps Error
    Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
    Code
    Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
    Oct 01, 2009 | Canon S400 InkJet Printer
    Both lights are blinking and will not print
    they call that flash codes or error codes. please count
    count how many times the lights flash, here is what they mean
    Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
    Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
    Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
    Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
    Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
    Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
    Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
    Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
    Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
    I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
    Please advice what can I do urgently.
    Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
    Need a help for Canon PIXMA® MP470 Printer
    My printer wont print. It flashes Error 5100 and the orange light flashes twice. There are no answers in the book.
    Feb 19, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
    Canon MP170
    primeramente me salio 5100 pero luego paso a 6000 no se lo que puede pasar ya que no se mueven los cartuchos y no hace el reseteo cuando la enciendo y solamente me sale COMPRUEBE IMPRESORA Y SALE 6000 ERROR. en espera me sean indicados los problemas que se puedan subsanar un saludfo
    Feb 28, 2007 | Canon PIXMA MP170 All-In-One InkJet...
    Canon PIXMA  MP460 All-In-One InkJet Printer Logo
    313 people viewed this question
    Clive
    Clive
    old marine
    old marine
    Ekse
