Question about HP PSC 2175 All-In-One InkJet Printer
Slow Printing Recently experienced slow down of both printing directly connected to PC, and copying. Any help appreciated.
    Scholar:
  • 21 Answers
Hi, The slow printing issue can occure even if the cartridges are out or low in ink try to check the print function by the stand alone unit by printing a self test page Here are the steps to print a self test page: On the front panel of the product, press Menu (or Setup) . Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK . Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK . If the self test page takes less time to print and if all the color blocks and black block print fine the ink level are fine. if the time for self test is also more try to clean the cartridge contacts and replace the cartridges if needed this will fix the issue. If the printer works fine as stand alone self test and copy try to performe the steps in the below webpage: ========== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00093466&lc=en&cc=us&dlc=en&product=2512010&rule=10185&lang=en ========== If the issue is still un fixed try to set the print directly settings in the printer properties Click on start >> control panel >> printer and faxes >> there look for the HP printer icon with the check mark and right click on it and select properties and then click on advance tab and under it select the print directly to printer and click on apply and ok to save the settings. Once done try to print and check with the issue. Hope this will fix the issue. Regards, Barret.
Posted on Sep 27, 2007
  • Kiran Mishra
    Kiran Mishra Sep 27, 2007
    Hi there is also a Firmware update that can be downloaded and installed to check with the issue:
    Here is the link to download the firmware update from HP for HP 2175 All-in-one:
    http://h10025.www1.hp.com/ewfrf/wc/softw...
    Wish u success
    Regards
    Barret.
SOURCE:
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
I have an HP LaserJet 3600 dn printer and I'm experiencing a problem with slow printing. I thought it was just when I tried to print PDF documents, so I tried to print a regular MS Word document, and...
When you print the config page, does it print slow?
If it prints at a reasonable speed, it's not the printer.
Are you using the USB port, the network port or a jet direct card?
One of those could be bad.
Jan 11, 2011 | HP Office Equipment & Supplies
This printer starts printing really really slow, and then half way through just fails to print and stops printing. what to do?
I've also been experiencing this problems--for months now. It happens only when printing over the network. Prints fine via the USB connection.
May 02, 2010 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 7210 Is Very Very Slow (10 mins / page printing)
And I have exactly the same problem too that has happened in the last few weeks.
I've tried reinstalling the software/drivers and resetting the printer to factory settings but no joy. An upgrade either windows or HP must have caused this!
Mar 29, 2010 | HP Officejet 7210 All-In-One InkJet...
Laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
Oct 18, 2008 | HP LaserJet 2430dtn Printer
Slow Printing
it may just be a slow printer head, maybe an upgrade is in order. look on the box for page printing speed.
it may also be that you have the resolution set too high for basic printing. try turning this down slightly.
hope this helps.
kev
Oct 03, 2008 | HP PSC 1350v All-In-One InkJet Printer
Very slow printing & copying
I shut off the computer for about 1 hour, and when I turned it on, it printed and copied at the speed it is designed to do.
Apr 09, 2008 | HP PSC 2410 All-In-One InkJet Printer
Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
Hope this helps.
Jan 05, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP PSC 2175 All-In-One InkJet Printer Logo
135 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
