Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
GE GSH25JSRFSS REfrigerator not working
All the lights are woorking but flikring with a cliking sound. The filkering & clikiring sound goes off when the Dispensor light is also lit. But in any of these conditions the compressor is not getting on i.e. the compressor is not working.
  • 3 more comments
  • Anonymous Feb 09, 2008
    just like you described, lights on, clicking every second or so and lights dim . also fan motor and compressor not running
  • Daklu May 10, 2008
    Similar problem here. The water and ice dispenser is not working, the dispenser light won't turn off, and the compressor quit working.
    I traced the clicking to a relay on the main control board but haven't yet been able to figure out why it isn't staying on. I could see the rear fan in the freezer (look through the slots in the grill just below the ice maker) trying to start up when the relay turns on, but since the relay will not stay on the fan doesn't continue running. I can turn the fan freely by hand so I know it's not jammed.
    I also discovered that when I disconnected the dispenser control board the compressor would run although the clicking didn't stop. You can access the dispenser control board connector by removing the top freezer door hinge cover with a phillips screwdriver.
    Still trying to track down the problem... I wish I could find an online circuit diagram.
  • rtatl Jun 20, 2008
    Same problem. lights dim, makes a clicking sound every second, compressor never turns on.
  • courseone Jul 24, 2008
    unpluged only and plugged back in. Nothing
  • bssilv Oct 18, 2008
    I have the same problem also, fridge is only 2 years old. Never will buy GE again.
  • 3 Answers
I had the same problem as do thousands of people with this same fridge. The mother board is bad and needs to be replaced. It is easy to do yourself and the part costs less than a service call.: Unplug the cord from the wall, remove the panel from the back of the fridge (it is about the size of a small shoe box lid) You will see the mother board (ice, water, light, and compressor control unit). It is an electronic circuit board. There are about 5 or so plugs going into the board. Remove the plugs and the retaining screws and search Ebay for the part#WR55x10552 GE Power Control Board. I found one for $74, popped it in, and everything works better than new!
Posted on Mar 21, 2009
This seems to be a common problem with these units.
GE does not seem to be willing to provide schematics to allow one to troubleshoot the unit easily.
Replacing the main circuit board seems to solve this problem with most. This indicates that the relays GE used in this circuit board were of poor quality.
Posted on Jul 30, 2008
The compressor and condenser are stoped working whenever the dispenser cradle is pressed, then the control board keeps clicking forever and the freezer is becoming warm and the frozen stuffs are melt. Also there are no water,ice cube and crushed ice cube coming out from the dispenser when the dispenser cradle is pressed, even though the water line is connected and the ice cubes icemaker made are filled in the ice bin.
And recently(in the past week) refrigerator stops running several times and the control board keeps clicking when we returns from outside. we wait long hours and until the freezer are melting, we have to unplug and plug several times in a try to start the compressor and condenser.
Posted on Jul 04, 2008
  • 291 Answers
Need more info not understanding much what u wrote.. sounds like you have control board problems
Posted on Sep 03, 2007
Water not coming from gss25lgmb bb
I have a GSH25JSRFSS GE refrigerator. Twice, the water line has frozen near the dispenser. Each time I used a hairdryer to heat either the side of the door where the water line runs and blew hot air up the dispenser. This last time, I took the plastic cover off the outside of the door (it clips on) and blew hot air into the small holes in the door that the outside grate clips into. This allows the hot air to get inside the door, and I heard ice from the frozen line drop. Subsequently, the water line worked. Two points: I did have water running to the line in the bottom of the refrigerator, so I knew it was an ice clog, and secondly, I took care not to blow hot air on the exposed wires inside the door.GKAZ
Oct 23, 2011 | GE GSH25JSRSS Stainless Steel Side by Side...
Freezer woorking ok fridge not cold model GSS20DBPC WW
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Aug 23, 2010 | GE GSS20DBPWW / GSS20DBPCC Side by Side...
GE Refrig. Water leaking on floor after ice maker stopped
look at water delivery tube to the ice mker . it has iced over and pluged up causing the water to go out the back and down on floor . . clear the water tube with hot water and problem is over . .. some models cah use a updated water tube. mm
Jul 16, 2010 | GE GSH25JFR Side by Side Refrigerator
I have a GE fridge, it is a GSH25JSRFSS model, GH204618 serial number. It stopped working except for the light inside. I found that the main or mother board was smoked up and had a burnt place on the....
Sometimes you can call GE and get help but most times not if the year warranty has expired. I personally have never found any problems other than the board itself just having a bad relay or a circuit blown off the back. Thunderstorms are hard on them too. Below is a link for the model unit you asked about.
Main Board
May 21, 2010 | GE GSH25JFR Side by Side Refrigerator
Stops cooling ice melts and leaks water on the floor
That model refrigerator uses the mother control board for deciding when defrost is to take place. It has no defrost timer or Adaptive Defrost Control like other refrigerators. This sounds like *********** board part number WR55X10942 is malfunctioning. The board decides most functions of your refrigerator. Until the board is replace I do not believe the problem will resolve itself. Thanks, Sea Breeze
Sep 26, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
GE SIde by side refrigerator GSS22JERF WW is making a clicking sound and is not keeping cold. We have tried cleaning the back of the refrigerator to see if this would help. But it continues to make the...
Hi!!! your current relay has shorted change it and you should be okay..your hearing your relay cliking its no looks like this and is located by the compressor where the rires go into the compressor..good luck..look at image of the current relay..d1dad63.jpg or location here
Jan 04, 2009 | Refrigerators
GE Side by Side Refrigerator
Door Alarm -
To set the alarm, press this pad until the indicator light comes on.
This alarm will sound if either door is open for more than 3 minutes.
The light goes out and the beeping stops when you close the door.
Jun 01, 2008 | GE PSS26MGS Side by Side Refrigerator
Replacement of motherboard
call me i will walk you thru it 345-916-2343 too much to type here
Nov 03, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
1,560 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
