Question about Technics SL-1200MK2 Turntable
Wiring the phono leads are faulty at the back.i want to change them myself how do i do it
  • fredd44 Oct 01, 2007
    thanx for both of your comments. i have a freind who is a good solderer and hes sorted it. i know this sound silly but one of my problems was finding the screws to open the deck!!!!!!,thaks a lot once more.
It's really not hard if you know how solder, my suggestion is to place it upside down on a desk with the tow arm hanging off the desk so not to damage it, then take the 4 feet off by simply twisting them off then remove all the screws, now that all that is removed you'll notice that where the rca's go in they are pinched in a piece of plastic simple remove the screws and it'll un snap take the remaining plate off and your in ready to solder
Posted on Sep 28, 2007
  • 515 Answers
It's not as easy as it looks or sounds. If you have to come on this site and ask this question, then I DO NOT suggest you attempt this repair. You will have to have some decent soldering skills, as well as mechanical capabilities - it's kind of difficult to get to the PCB where the RCA are soldered on to. If you damage the PCB, it is not replaceable, as that part has been discontinued by the manufacturer. So, with that warning... it's not that hard, if you are mechanically inclined, and all you have to do is get to the RCA's PCB section, and remove the base and locking mechanism. Then solder off the old RCA's, solder on the new RCA's, put it back together, and your done. Hope this helps.
Posted on Sep 23, 2007
Trying to hook up older technics stereo dont know
Turntable leads go to Phono.
Turntable ground lead (thin black wire) goes to screw terminal next to 'Phono'
CD phono cables go (unsurprisingly) to the CD
Cassette deck "Play Out" cables go to 'Tape Playback' sockets.
Cassette deck "Rec In" cables go to 'Tape Rec Out' sockets.
EQ Line Out cables go to amp's VCR/EQ Playback
EQ Line In cables go to amp's VCR/EQ Record Out
Aug 30, 2014 | Audio Players & Recorders
Connect hdmi goodmans tv
Forgive on this one but I do not have a soundbar but wonder if it has any other connections like phono for input as to me hdmi would be a strange choice. Hdmi leads are mostly alike in they are fully wired and carry a wire which directs a device to listen to it when turned on, also some hdmi sockets (like the old scart) are blessed with options.
Some may be input only while others set for in and out so it may be worth swapping connections on your TV to see if this changes the habit, though for me I would look to see if this soundbar has other sockets to use like phono (same with your TV if it has phono or scart socket options). Your TV instructions may show their ideal connection setup, otherwise you will have to shutdown your other item to stop it commanding the TV to switch through its sound. This "problem" is an old one with people using scart leads then I used to cut pin 8 (its control wire handing the descision to a user) but this new lead combo I do not know.
Hope this helps.........
Aug 29, 2017 | Samsung LN32A330 32 in. LCD TV
Very low sound after new needle installed
Firstly the cartridge could be faulty or incorectly wired. I think what you are refering to is a magnetic cartridge pre-amp. If the turnatable has seperate audio connectors these should be plugged into the "phono" socket. And not an "aux" or "CD" input. If there is no phono socket, you wouldn't be able to plug a pre-amp in anyway. Yes the deck if it is built in should have this pre-amp built in. However these pre-amp can fail!
To test if the pre-amp is working, even if has no phono socket, unclip the leads to the cartridge. With your amp on, touch the end of each wire with your finger. On two you should hear a buzz - one for each channel. If it's not loud then there's a problem with the pre-amp. If you do get a decent buzz the cartridge is faulty.
You can also trace the wiring to the pre-amp inside the unit, if you wish to fix it. It will almost certainly end up at an IC, which should be replaced.
Jan 15, 2013 | Audio Players & Recorders
Gemini XL-BD10. Always worked fine. Started sounding muffled and "dirty." Thought it was the needle. Replaced it with a new one. Still the same. Tried a new set of RCA cables and ground wire. Same thing....
Check the internal circuit of the deck, follow the leads from the cartridge. Perhaps a faulty resistor or something else in any pre-amp. Make certain also it's not your amp that has not got a faulty phono pre-amp stage.
Aug 25, 2009 | Audio Players & Recorders
How to connect phono leads
  1. Step 1 Check the back of your Stereo for recording input(in) and output (out), your cassette deck may be plugged into these jacks.
  2. Step 2 Connect the RCA/Phono wires to your equalizer's input and output jacks on the back.
  3. Step 3 If your cassette deck or some other component is plugged into the recording jacks in the back of your amplifier, unplug it and plug it into the back of the equalizer under monitor jacks. Be sure that the "out" from the cassette deck goes to the "in" of the equalizer.
  4. Step 4 Now, take the wires from the equalizer and plug them into the amplifier in the same manner: "in" to "out" and visa versa.
  5. Step 5 Once all your wires are connected be sure the "tape monitor button" on the amplifier is on. Turning it off will disable the equalizer. You can still monitor your recording devise or cassette deck by the "monitor switch" on the equalizer.
Mar 12, 2009 | Audio Players & Recorders
Wiring car amp up
the rem wire is for switched power from your head unit usually most after market stereos(head units) have an output for the rem wire.......if not use the power antenna wire from the back of the radio (usually blue or blue white) as for the input you need to use one or the other low or phono
Hope this helps..Good Luck!
Dec 13, 2008 | Car Audio & Video
Single sided sound from my RCA/Phono leads
Your query not complete. Please resubmit.
Nov 30, 2008 | Audio Players & Recorders
Phono lead connection.
Take it apart ind see if a wire is broken. You can use a meter for this. You could test the wires on another speaker also.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Jun 03, 2008 | Harman Kardon SoundSticks II Computer...
Phono leads are faulty
If you have a basic knowledge of Soldering,you can do it yourself.I'd be glad to help. brownwolf66
Sep 03, 2007 | Technics SL-1200MK2 Turntable
Everything's in black & white
are you using the s video socket if so you will get black & white picture you need to use rca phono to rca phono or rca phono to scart lead to record to dvd burner. as I do alot of copying over myself i never use s-video socket due to cable wrongly wired for colour just black video signal. hope this works for you
Aug 14, 2007 | Mitsubishi HS-U778 VHS VCR
Technics SL-1200MK2 Turntable Logo
93 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
