Home | Maytag | M3DH30B2A Dehumidifier | Will run but won't tak...
Maytag M3DH30B2A Dehumidifier
Problem for Maytag M3DH30B2A Dehumidifier
Will run but won't take moisture out of the air
By porterl77 on Apr 05, 2009
We purchase the maytag unit 3 years ago at Menards and we run it in the spring and summer time. Last week we turned it on and it would kick on just fine and would run but wouldn't take any moisture out of the air. Not a drop of water in the bucket. When we would turn the dial down it would kick off just like it is suppose to do. We would turn the dial up and it was running just fine but the bucket was empty. I was wondering what could be wrong with it and would it be fixable. The booklet said it had a 5 year parts warranty. Please let me know what you think.
lisa
Same Problem
May 14, 2009
-   Same exact problem and compressor is quite hot -   lmstraight
Apr 25, 2009
-   Similar problem but the unit is icing up the front row. There is a sensor a the right side is loose. Does anybody knows where a small cylindrical sensor with a black wire with a extra clear insulation sleeve is attached to?-   urcoupe83
Apr 23, 2009
-   I have the same problem. I have the machine apart and the compressor is running but it is extremely hot. The coils in the front are not getting cold. Could it be that the refigerant need to be replaced or is that even possible?-   shpear
Apr 13, 2009
-   Runs but will not pull moisture despite power off and on and trying different settings-   Guest
Apr 07, 2009
-   I have the same problem. I am betting the compressor doesn't kick on either. If not then it is the thermal defrost switch. I jumped mine out and the compressor kicks on now but the unit sometimes freezes up so......I am in serach of a new switch-   Guest
Solution #1
posted on Apr 05, 2009
Somewhat Helpful)
gasfast
Rank: Guru
Rating: 90%, 49 votes
It sounds as if the fan motor is running, but the compressor is not.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Apr 28, 2009
Somewhat Helpful)
spike200080
Rank: Apprentice
Rating: 75%, 4 votes
you would have to check if it needs more refrigerent
Was this helpful?
Yes
No
Solution #3
posted on Jun 08, 2009
Not Rated)
urcoupe83
Rank: Apprentice
Rating: 0%, 0 votes
the black cylindrical has to be in front of the air to sense the humidity. Make sure to provide a small bracket (something plastic with a zip tie)so the intake air hits it.
It took few tries. Somehow the first 3-4 time it will breeze the front part of the condenser and will overheat the compresor because it doesn't draw any air to cool the freon. It works without any problems the last month.
Was this helpful?
Yes
No
Popular Solutions for Maytag M3DH30B2A Dehumidifier
Questions and Unsolved Problems for Maytag M3DH30B2A Dehumidifier
Do you recommend Maytag M3DH30B2A Dehumidifier?
Answer
Answer
Runs for awhile then it actually gets ice on the inside where the water falls into the container.... (More)
Answer
My Maytag M3SH30B2A dehumidifier runs but wont't collect water. I just got done cleaning the filter... (More)
Answer
My Maytag Dehumidifier has been constantly running. But, it now seems it is only the fan we hear and... (More)
Answer
My M3DH30B2A (30 pint) dehumidifier smells somewhat rotten. Still completely functional. Help?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag M3DH30B2A Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
