Sony Cybershot DSC-H3 Digital Camera Logo
Pris wilson Posted on Apr 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clock setting i have a sony cybershot dsc-h3 and every time i turn the camera on it asks for clock setting. so basically it doesnt keep the setting
  • 1 more comment
  • Pris wilson Apr 05, 2009
    ive tried to set the clock and hit ok and cancel and turn the camera off and when i turn the camera back on the screen is clock setting again like i never even set it.
  • Anonymous Apr 07, 2009
    your right i set the date format and time and my only option is to hit ok next. then i can proceed to use the camera. question is after i shut off the camera and turn it back on to use it again the first thing that pops up is clock setting again. i can set the date/time hit ok then turn camera off then back on again and the clock setting is back up like i never even set the time. is there a way that i can hold the setting so im not setting the time/date every time i turn the camera on?
  • Anonymous Apr 10, 2009
    i replaced the battery and still i have to set clock setting every time i turn the camera on.
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Apr 05, 2009
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957025
Points
33084
If you set current time in clock set, it will not asked you again. I think you just cancel it when clock set display appears.
  • Anonymous Apr 05, 2009
    when clock screen comes, select date format like D/M/Y or M/D/Y etc then go to date setup, set current date then set time and at end you will reach OK button, press OK and job is done. There is no way to press cancel button in this sequence.
    When you press cancel button that means you are not setting date/time and camera will show this screen again when you power it up.
    Yes,
    When Lithium Rechargeable Battery got defective or dead then camera will not hold time and date settings.
    Qualified camera tech will replace that battery as it is mounted on flexible board under top jog dial portion.
Camera want flash sony dsc-h3
If it flashes when you take any photo then you have the flash set to manual override for each shot or you're just shooting in areas too dark for any photos without the flash. Check your flash settings or try a factory default reset from the camera's menu options.
19helpful
It keeps saying my sony cyber-shot DSC-H3 macro is invalid. what do i need to do to get it working again?
Press the "Home" button, go to "Settings" (last menu item at right), then "Main Settings", and use the "Initialize" button.
And also;
Macro is not available in landscape mode, twilight mode or fireworks mode, if you try to use macro in any of those modes it will say invalid macro.
4helpful
SONY CYBERSHOT DSC - H3 DIGITAL CAMERA FLASH PROBLEM
Hi Jim,
Have you tried resetting all settings on the camera? On a Sony camera, it is called "initialize". The initialize setting is found by going to the menu, and tabbing down until you find an option called either "reset settings" or "initialize settings" and then confirm it.
Many times that will fix the issue, in case something has either been enabled/disabled on accident, or the software is sticking (which happens from time to time)
1helpful
Sony DSC-H3 Flash wont pop up automatically
Your flash setting is on "Manual".
[Menu]
[Flash]
Use the "arrows" to change from manual to automatic.
4helpful
Cybershot will not store clock settings
Hi!
The internal battery is bad. It has to be replaced. Contact your local Sony service center, but if they ask too much, you can contact me at [email protected] and I will give you a good price.
I work in Sony service center.
Tom
hi there...i have the same problem..did u find any solution for the very same..
get back to me on
[email protected]
System error
ok try this pls take out the mem stick b4 going fwd
factory reset the camera
Home Screen>Settings>Main Settings1>Initialize press OK on Control Button and then OK select Initialize All Settings press OK
then pls turn off the camera and take out the battery then move power switch of camera to ON position for 1 minute
after 1 minute move power switch to OFF position and then put the battery back and see everrything is OK
pls let me know with the results
Rate me FIXYA if i fixed ur problem
My sony cybershot dsc-h3
Symptom shows your DSC-H3 has problem in Lens Mechanism and you need to replace complete lens.
If you want to replace it by yourself, Its part number is as follows...
A-1359-213-A LENS BLOCK ASSY
It is available in Parts Store on $150
Or contact nearest Sony Service Center for replacement.
Flash doesnot work how does one charge the flash on a Sony cybershot DSC-H3
Some of the popup flashes seem to be defective on this product. Mine is. I am returning mine under warranty.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
