Question about Pioneer DEH-245 CD Changer
Speaker Balance We just purchased a jeep with a Pioneer Deh-245 Stereo, only the right side speakers work. Where is the balance button to see why the left side is not working? Please help....
  • Anonymous Dec 27, 2007
    How Do I Set The Balance On My Pioneer DEH-245?
Its the shift button. that lets you adjust your bass treble fade and other stuff.
Posted on Feb 16, 2008
How do I reset my pioneer deh-x6500bt car stereo and produce sound from my rear speakers?
a 'reset' of the entire stereo should be able to be accomplished by disconnecting the battery for several minutes: alternately if you remove the faceplate there should be a reset button you would need a pen to press, however you should be able to find the EQ levels and set the balance and fade I think it is so the rear produces sound, if that is not the case, I would check wiring to make sure nothing is loose. I suppose it could only be a software/firmware problem with the stereo itself however, if you have had this happen before and it was fixed without tinkering with the wiring.
Jul 30, 2014 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
Pioneer DEH-P47DH Front left speaker not working, if i press audio button, i get no option to adjust balance, just fader. left rear speaker works and plays as loudly as right rear speaker. Huh? bad...
Are you sure you wired up the head unit correctly? It is fairly uncommon for a audio output amplifier to blow out leaving 3 working speakers and 1 not working. So more than likely it is bad wiring or a blown speaker. Best bet would be get a digital multimeter and ohm out the speaker and see if it has continuity and is the same as the adjacent speaker. You could also try swapping the left/right channel wiring and see if the front right speaker stops working when connected to the left speaker output or vice versa.
Nov 12, 2013 | Car Audio & Video
How do I set the volume on both speakers?
Go to the stereo fader and balance the volume in each speakers. You can see there L for left speaker R for right speaker and F for front speaker and then R for rear speaker. Put them all in zero to have equal sounds volume.
Apr 06, 2011 | Pioneer DEH-P2000 CD Player
Cant get the speakers balance its all on the right side.
ok maybe i am not understanding what you are trying to do .if you are looking for balance you found it balance is front to back and side to side. if you are saying the volume wont change you might have one rear hooked up to the front and one to the back. this is most common on cars thatare hard wired "no harness"double check the way you ran the wires good luck
Aug 22, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Adjusting front and speakers
Push the menu/sel button, select bal/fad. Pioneers use the same adjustment for balance and fade. push side to side for balance, up and down for adjusting front to rear
Aug 18, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I cant figure out the wiring digram for the DEH-245 pioneer stereo
Yellow = +12V constant (Battery)
Red = +12V switched (Ignition Switch)
Black = ground
Blue-white = Remote On
White/White-black = FL speaker
Grey/Grey-black = FR speaker
Green/Green-black = RL speaker
Purple/Purple-black = RR speaker.
May 30, 2009 | Car Audio & Video
How to ajust speaker front to back
Hello bill_cordova,
Start with the "AUDIO" button. Press it until FAD appears in the display. Press the up/down buttons to adjust front/rear balance. FAD:F15-FAD:R15 is displayed as the front/rear balance is moved from front to rear. FAD:0 is the center position with the balance equal between the front/rear speakers.
Hope this helps. If it does, please rate as "FixYa".
Apr 24, 2009 | Pioneer DEH-P4700MP CD Player
Pioneer car sttereo without manual. front speakers work but rear speakers silent
Press the audio button (A button in right hand upper corner) till you see FADE or BAL press the up down or left right arrows to adjust the fade and balance till all your speakers work.
If they still dont work, check the wiring at the speaker and the wiring behind the head unit to make sure their properly intact and properly grounded.
Jul 28, 2008 | Pioneer DEH-1600 CD Player
My l/r channel will not work
With the radio on u will need to push audio button it will change to something different on the face push until speaker balance comes up & then push butons below it left or right to balance each side of speakers. For me it was the left speakers that i needed to balance good luck John
Jun 06, 2008 | Pioneer DEH-1600 CD Player
Right side speakers do not function
Have you checked the speaker wire for breaks or shorts?
Apr 22, 2008 | Pioneer DEH-P3100 CD Player
Pioneer DEH-245 CD Changer Logo
132 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
