Question about Philco (R) 841.205 CD Shelf System
How to place the belt on the turntable.......
The turntable belt came loose and the turntable will not spin the record. Therefore it will not play the record
  • 1 more comment
  • Anonymous Nov 08, 2007
    I had the same problem... Here is what I did. As the previous post mentioned, remove the black plastic turntable platter. You now should see the loose belt. If the belt is still good, place it back on the underside of the platter. You will notice there are two opposing plastic pins located at the outer edge of the platter. Pull the belt over one of the pins. Place the platter over it's chrome spindle shaft, with the plastic pin facing the motor shaft. after the platter is in place (don't put the "e-clip" on just yet...) rotate the platter a couple of turns. This should do the trick. If not, keep trying. It worked for me on the first try. After the belt is back on, secure the platter with the e-clip and replace the black rubber mat. Viola!
  • Anonymous Dec 05, 2008
    Sorry, I was trying to say that i did NOT see when the belt was on.
    So i have no clue to why it's at least twice as long as it needs to be,
    OR so it seems. it wasn't stretched out.
    It worked fine "till i drop it on the floor". OPS
    but now have now idea how to put the belt back on.
    thanks again.
  • Anonymous May 11, 2010
    i did see how the belt was position when it was on.
    it seems too long just to be placed on two pins.
    The belt came fell off when the whole unit hit the floor
    from off it's table. :(
    I tried searching online for any manual to this unit with no luck.
    I would help if i could see a digram of the belt in the right position.
    Thanks A whole bunch.
    Philco Turntable CD with Cassette
    Art no. 841.205
    LW02334
Suggestion:
Pull rubber matt off TT. Use a small screw driver to pop off the small black "C" clip at base of steel record post. UNderneath plastic disc you will see the belt, and it loops on the metal post and over to the plastic barrel shaft to its right. Try this:
  1. Using Non-gelatin based nail polish remover OR acetone (gotten from any hardware store), and a few Q-Tips, rub the belt inside and out along its entire length until you feel the tacky rubber feeling come back to the belt. You may also see the shiny surface come off the belt as you clean it. The shiney look is from belt slippage and its like a glazing. Also, if you notice any of this black glazing on the two belt posts, clkean them off as well.
  2. If belt broken, replace with new by looping it back around the two posts under plastic TT platter.
If its truely a belt issue these two should solve it.
Posted on Oct 10, 2007
I just solved my own problem. the turn table plate/dish or what ever it's called.
on the under side there is a middle ring/ledge, it's the round cylinder that the belt needs to go on,
it holds most of the belt. Getting it on the ring/ledge and the motor spindle is tricky.
I turn the unit on it's side with the motor spindle up. I put the belt on the ring/ledge first and used a pair of real tiny needle nose pliers to work it on the motor spindle. It took me a few tries, and boy was it
frustrating.
So far so good, and hope it helps
Posted on Dec 05, 2008
SOURCE:
My jensen three speed turntable is not spinning my record
If it is a belt driven model it might have fallen off. If you lift up the turntable matt it should show a hole to view the belt. If the belt is good, it could be that a switch is not engaging when the arm moves out to the record, if it is the type that starts when the arm is placed on the record.
Mar 09, 2016 | Jensen Audio Players & Recorders
My Philco 841205 Turntable spins normally, but
If this is a belt driven turntable then when the arm rests on the record the weight cause the belt to loose traction and slip around. The only cure is a new belt. Make a note of how the belt fits before removing as the biggest problem with belt turntables is knowing how the belt fits. When removed. Measure the diameter of the belt in MM and then the thickness. You won't need to be spot on with the diameter. Put the measurments into Google with the words turntable belt. Get the one that is nearest your measurements.
Sep 16, 2014 | Audio Players & Recorders
Aiwa PX-E850
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
Apr 08, 2013 | Audio Players & Recorders
Turntable platter doesnt spin when you press start/stop
Is your turndable belt driven? If so replace the belt.
Jun 05, 2010 | Numark TTX Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Plays Records Too Fast
If it is a belt drive model it might be that the belt is out of place and therefore causing the speed to be wrong. This might be due to age or wear of the belt. I would look at that before adjusting.
If it is good and you can't see any mechanical fault causing it. Then look for a preset pot (or two) on either the pc board or on the motor itself. They will adjust the speed. If you find two - one will be for 45 they other 33.
Bear in mind the motor might have gone wrong!
Jul 25, 2009 | Audio Technica AT-PL50 Turntable
Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
Old record player spins too slowly
it sounds as if the rubber belt is to slack however also worth checking ithe attachment to the spindle itself is not loose 2make sure the belt is the correct type
Feb 09, 2009 | Crosley Traveler Turntable
Crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Dec 12, 2008 | Crosley Conductor CR73 Turntable
Philco (R) 841.205 CD Shelf System Logo
364 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
Perry Mellott
Perry Mellott
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
