My camcorder stopped recognizing the battery. I thought it was my battery, I purchased a new battery. Still have the same problem.
The message the pops on the screen is "For Infolithium Battery Only". Battery is fully charge. When I turn on, for about 10 seconds the camcorder works, then I get the message, then the camcorder turns off.
It is a Sony Infolithium battery F960
Thanks,
SOURCE: Camcorder Sony DCR-HC19E not connecting with USB
hi I have the exact same camera,
i had problems connecting it with the firewire connection but not any of the other connections on the camera. I found that it was down to one of the pins on the DV/Ilink connection, one of them had been bent back. i just used a pin to bend it back into shape and it works again
SOURCE: My computer does not recognize the camcorder on the USB Drive Port.
did you install the cd driver camed with you camcorder to your pc? install it so that it recognizable the camcorder to your pc.
CHARCOIS
SOURCE: XP Pro w /firewire not recognizing Sony DCR-TRV730
Try a video card that supports current DirectX. Apparently it has an effect even if you capture without previewing the video. (worked for me, anyway).
SOURCE: camcorder not being recognized by my computer
I assume that you are running Windows XP in your PC and have Sony DCR-TRV19 camcorder.
Please go to camera Menu and enable USB stream option. Computer will recognize camcorder.
If any thing is different, let me know to help you out.
