Question about OKI B4250 Led Printer
OKI PRINTER B4250
The paper started feeding out the back after removing a paper jam that required lifting out the toner cartridge. Where is the switch or is there one that can reactiviate the paper feed toward the front again?
  • 161 Answers
You have accidentally pulled the back paper tray. Even when pulled a little, this tray tells the printer to deliver output to the back. This is useful when printing on heavy, or thick paper. Just push it back all the way down to it's original place.
Posted on Sep 26, 2007
SOURCE:
Error: open upper cover exit jam
Feed Jam or Exit Jam ecblank.gif ecblank.gif dot.gif ecblank.gif 1. Remove the tray and clear any misfed sheets as given above.
2. Open the top cover.
WARNING! The fuser area will be hot. This area is clearly marked. Do not touch it.
CAUTION! Never expose the image drum unit to light for more than 5 minutes. Never expose the image drum unit to direct sunlight. Always hold the image drum unit by the ends or from the top. Never touch the surface of the green drum inside the image drum unit.
3. Carefully lift out the image drum, complete with the toner cartridge. Be careful not to touch or scratch the green drum surface.
4. Remove any jammed sheets from the paper path.
5. Re-install the image drum complete with toner cartridge, ensuring that it correctly locates into the slots on each side of the printer.
6. Close the top cover and press down to latch it closed.
7. The printer will warm up and commence printing when ready. he page lost through the jam will normally be reprinted.
NOTE If the edge of the jammed paper protrudes (or can be seen) from the exit, reinstall the image drum, close the top cover and switch the printer on. Remove the jammed paper from the exit when the exit roller begins rotating after a few seconds after switching on. However, if the jammed paper cannot be removed, contact a service representative.
Mar 12, 2010 | OKI B4350 Laser Printer
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Oki B4250 PaperJam
clean and wash paper transfer roller or feed roller guide it fail timing
Sep 10, 2009 | OKI B4250 Led Printer
Oki B4540 keeps saying
You should certainly start by looking at the toner cartridge to see if there is any tape to remove. If there is no tape with a visible pull tab, check inside the printer to make sure that there are no pieces of torn paper stuck anywhere inside.
May 05, 2009 | OKI B4350 Laser Printer
Print fragmented documnts
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Aug 14, 2008 | OKI MICROLINE ML-395 Matrix Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
381 Paper Jam Error
I had to remove every toner cartridge and drum. I found the paper under the second to last drum.
Jan 22, 2008 | OKI C5500n Printer
Oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
There is a red light flashing
From the OKI site, I found this information. My problem is a Flash 2 Blink, which is a problem with the cover or minor error, whatever that means. I can't figure out how to fix it. Any suggestions greatly appreciated!
Flash type Ready LED (Green) Manual feed LED (Amber) Error LED (Amber) Meaning Flash 1 -- slow blink X ecblank.gif ecblank.gif The printer is processing data when printing has been suspended. ecblank.gif ecblank.gif ecblank.gif X The image drum required changing or toner is low. Flash 2 -- blink X ecblank.gif ecblank.gif The printer is receiving and processing data during printing or the printer is resetting itself. ecblank.gif ecblank.gif X ecblank.gif The printer is requesting manual paper feed. ecblank.gif ecblank.gif ecblank.gif X There is a printing error, problem with paper or a cover open. ecblank.gif X X X There is a minor error with the printer. Flash 3 -- rapid blink X X X There is a major error with the printer.
Oct 27, 2007 | OKI B4250 Led Printer
OKI B4250 Led Printer Logo
353 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
