I believe the exclamation point inside the lines(which are supposed to be a tire symbol) is a low tire pressure warning indicator. Check all tire pressures, as a drop of just 10% will set the lamp off. It will take up to 5 minutes with the car running for the lamp to shut off after filling tires. Hope this helps.
GOOD LUCK i hope this is of help
Does it look like this?
Yes, exactly like this.
I did check the tire pressure, but it dose not go away.
