Need a wiring diagram for Wharfedale ProR200 power supply cord
The power supply has 3 conductors -- Red, Black, Brown attached to transformer -- left to right. On the other (appliance) end, the power cord attachment has three hole connector sleeve with conductor solder lugs labeled 1 2 3. As the conductors were torn off the connector sleeve, I cannot be sure what color goes with which number. I have tried to look inside at the transformer end, but do not see any corresponding numbers on the circuit board. Please assist. Many Thanks Ed Werner
  • 160 Answers
SOURCE: Microphone wires are broken at connector.
what kind of mic m6b, devil, turner, black and silver eagle
Posted on Jul 08, 2008
  • 1028 Answers
SOURCE: connecting 4-wire recectacle 14-30r dryer
doesn't matter both are 110v lines but if you want look up to top screw connections the wires coming to those screws are also colored as long as the red and black are to outside screws dryer will work ok
Posted on Aug 07, 2008
SOURCE: Connecting Creative t6060 to my philips 5.1 dvd player
Hi Guys,
I am teh person who started this thread and I am happy to find the solution. The problem is not with Speaker but it is with DVD player. Infact it is not a problem, it is the setting which needs to be changed.
Go to the Setup menu and change the Speaker settings and set it to MultiChannel. This will give you sound to rear and center whenever it has to.
Hope this helps as it has to me.
Posted on Nov 15, 2008
SOURCE: 8 wires on my subwoofer??
"One has positive and negative input, another positive and negative output (red and black on each)"
Just from your description, it sounds like pos/neg input are the 12 volt pos neg supply for the amp inside the subwoofer. Red is pos, black is neg.
"positive and negative output (red and black on each)"
This sounds like it's used if you want to proved 12 volt pos/neg to another component.
"and a third wire with left input right input positive and negative (blue, red, yellow and black)"
This is for the cables coming from the "subwoofer out" on the amp. This is 4 wires altogether -- correct?
Posted on May 08, 2009
  • 2237 Answers
SOURCE: can a ribbon (AWM 2896) be repaired? Spliced?
if you can gently strip the insulation off with an exacto knife to where some of the copper is exposed, you can solder the exposed copper together. it will not be as flexible, though.
Posted on Jan 14, 2010
Stand up tanner requires a 240v 20amp receptacle and power supply, it was working at my last place I have the same receptacle and breaker however, I didn't pull the wire I bought 10/3 wire HELP PLEASE
If you need 240 volts only, it should work. If the tanner uses both 120/240, (which I would expect), you will need 10/3 with ground (it appears in the jpeg that you are using 10/2 with ground).
For 240 volts, 10/2 has two conductors,. Measuring with a voltmeter between each leg you get 240 volts. With 10/3 the third conductor is a neutral (there is no neutral in a 120 volt circuit). This carries the unbalanced load between the two legs and allows the appliance to use 120 volts as well. The conductor coloring is usually black, red for the power legs and a white grounded conductor (with a bare, grounding conductor).
If the cord has four pins , it needs 10/3 with ground. If it has three pins (240 volt only) the recept is probably wired wrong.
Jun 16, 2017 | Electrical Supplies
Radio/amp wiring diagram 2004 hyundai xg350 ?
2004 Hyundai XG350 Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: White/Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown/White
Car Stereo Dimmer Wire: Green
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Black/Yellow
Left Rear Speaker Positive Wire (+): Brown/Red
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Black/White
Dec 22, 2016 | Hyundai Cars & Trucks
What is the color code diagram for steed 3 somebody tried to steal my trailer attached to steed now all wires are m......
yellow - left turn. green- right turn. brown-lights, black-power + white-ground, blue- electric brake or red
Jun 09, 2016 | Electrical Supplies
Polaris 9300 sport pool cleaner. the wires pulled free from the plug into the power supply. not sure which wire goes where. There are 3 red black and brown. 4 holes for them to go back into.
Without a wiring diagram it will need either model knowledge or some educated guesswork aided by a multimeter and carefully studying the internal wiring of the power supply.
Without a great deal of additional description I can't help further other than to suggest you contact the retailer who sold the appliance.
May 31, 2016 | Blue Wave Polaris 9300 Sport Robo Cleaner...
How do you hook the four wire electric cable to the terminal marked L1, L2, L3? the wires are colored red, white, black and green.
To connect power cord:
• Remove the screws from the cover of the
junction box located at the top rear of the dryer.
• Loosen/remove the two screws on the strain
relief clamp and remove from 4-wire supply
• The strain relief splits into two indentical parts.
• Insert the large flange of both sections into the
hole located on the left side of the junction box
housing. The short flange of both sections and
screws must remain positioned on the external
side of the junction box housing.
• Insert the 4- wire supply cord through both
sections of the strain relief and re-install strain
relief screws, do not fully tighten until electrical
connections are complete.
• Attach the power cord ground conductor (green
wire) to the ground terminal marked with the
ground symbol. Tighten screw until ground
conductor is secure. (See Fig. 7)
• Attach the power cord neutral conductor (white
wire) to the neutral terminal. (marked N)
Tighten screw until neutral conductor is secure.
(See Fig. 7)
• Attach the power cord phase conductor (black
wire) to the phase terminal (marked L3).
Tighten screw until power conductor is secure.
(See Fig. 7)
• Attach the power cord phase conductor (red
wire) to the phase terminal (marked L1).
secure.(See Fig. 7)
• Tighten the screws on the strain relief so that
the power cord cannot be moved.
• Re-install the cover of the junction box and
secure with four screws removed earlier.
• The dryer is now ready to be connected to the
power supply receptacle.
This is from the manual for the Danby DCD5505W. You did not give the model # so I went off of what you listed it under.
Good Luck and please rate 4 thumbs for the free answer.
Apr 29, 2010 | Danby DCD5505W Electric Dryer
We were recently given a kenmore dryer, without a power cord. How do I attach the 3 wire power cord that I bought to relace it?
Attach the power cord as follows:
1. Remove the cover on the terminal block on the back of the dryer.
2. Match the corresponding wire colors as follows:
a. RED - HOT (120VAC)
b. BLACK - HOT (120VAC)
c. WHITE - Neutral (0 VAC) - should have a ground strap attached, tying it equipment ground.
3. Make sure you use the power cord strain relief clamp when installing the power cord to prevent chaffing of the insulation and wire strain which can lead to broken wires.
NOTE: If the wires are not color coded, the outer two wires (left and right) are the HOT leads. The center conductor is Neutral.
For clarification purposes, the following link explains dryer power cord configurations/installation in detail:
If you have any questions, please post back and let me know. I hope you find this information helpful.
Mar 17, 2010 | Dryers
Heath-zenith sl-6107 wiring diagram
hi there the wirings colour codes for nz are as follows
Green = Earth
Black = Neutral
Red = Phase Or Live
Green/Yellow = Earth
Blue = Neutral
Brown = Phase or Live
============DANGER 230VOLT ===============
Electricity can kill.
You should use an Electrical contractor for this repair job,
Caution always turn off power first before touching any wiring,
The Live wires always carry power,from one point to another,
the black neutral is your return path from the live phase wire
the green wire is always the ground ,
In this example
the sensor will have four wires as follows
Green = Earth Wire
Black = Neutral
Brown = Phase (incoming supply) 24 hrs
Red = Phase Load (outgoing supply) from sensor to lights triggered
Notice there are to phases in the circuit.Brown and Red
Always treat them as LIVE or Active Power.
Brown will normally be the Live incoming power and
Red will be the load side of the sensor,
Check the brochure supplied by manufactuers or their website to confirm the wiring order is correct before commencing any installs or repairs,
Always Safety first.
Safe a live today and you'll remembered forever.
Jul 06, 2009 | Heath Zenith Occupancy Motion Sensor Wall...
Wiring diagram for PowerBright VC-1500W Step Up&Down Transformer
I just had a similar problem but only a couple wires popped out. I took a guess at where they came from and it works again.
Top right corner - left hole - black wire
Middle, right side - left hole - brown, right hole white
bottom centre - left hole - blue and green, right hole yellow and green
Apr 03, 2009 | PowerBright Power Bright PW200-12 12 Volt...
Dryer 4 tp 3 pring cord install
Hello wgirdler,
While it is preferred to upgrade the receptacle to a 4-prong type (which includes Neutral & Ground) Code requirements grandfather in 3-prong receptacles in older homes. So if your preference is to remove and replace the power cord on your dryer, make sure you get one that is designed for a dryer application and is 10/3 type. ( 10 Gauge wire with 3 conductors)...
Unplug the original 4 prong plug from the receptacle and pull the dryer away from the wall to gain access to the back of it.
Next, loosen the cord clamp that allows the cord to pass thru the back panel and into the druer compartment.
Open the access cover to where the end of that cord is terminated on a terminal block of the dryer.
Note which color is attached to which terminal ( red to red,black to black, white to white and green to green)...
3 Prong cables do not use a ground wire ( green) in the cord so you would wire the red to red, black to black and white to white ( The red and black are the power conductors and the white ..which is normally terminated between them.. is in the middle. You can get a seperate insulated conductor wire and route it from the ground stud of the dryer to the receptacle metal casing but do this with power disabled at the circuit breaker box...
Hope this helps.
Nov 29, 2008 | Whirlpool LER5636P Electric Dryer
I need a wiring diagram to wire my oven to the house power. Whirlpool electric model# rb260pxyb
You will have 3 or possibly 4 wires coming out of the oven Red and Black go to the hot leads in the junction box.Usually red & black but could be 2 black. White goes to white Bare/green go to the white if no Bare/Green available. This is for a wall oven. If the stove is free standing and you want to attach a cord. Just buy the cord that matches the outlet in your house. Make sure it is a range cord and not a dryer cord. They are very similar. If a 3 conductor cord (most common) outer two terminals are the hot ones. There is a wire or metal strap between the frame of the range and the center (neutral )terminal . On a 3 conductor cord leave this connected. On a 4 conductor cord remove this wire and connect it to the green/bare wire in the cord. There may be a vacant terminal on the block for this purpose. If not use a wire nut.
Jul 06, 2008 | Whirlpool Kitchen Ranges
334 people viewed this question
