Feels like i have a trailer attached when i dive and makes a "clink clink clink" noise with the rpms. this all started happening after my front tires locked up coasting in reverse at about ten miles per hour, any advice would be much aprishiated thank you
SOURCE: 96 automatic Outback, Shudders or rough feeling
Limited slip axles require in many cases the additive. It is ***** whale oil that is added to the required gear oil. Ck with Subaru is best. They sell it in the parts department and if capable you can add it yourself. or, have the dealer service your differential fluids. fluids
SOURCE: Cause of noise in front differential of 1997 Subaru Legacy Outback.
there is a plug on the shaft-side of the differential. Using a ratchet remove the plug and with the engine OFF, stick your finger inside the hole and you should get fluid just below the threads of where the plug goes in.
SOURCE: how do I drain front differential
bottom front plug of gearbox,middle plug is gearbox plug dont take that out
SOURCE: wheels making binding noises when turning
I have this same problem with my 1996 Subaru Legacy 2.2 Wagon. There is a Subaru Service Bulletin #16-62-97 dated 5/16/97 with a Subject entitled "Transfer Clutch Binding And/Or Bucking On Turns". There is also an important follow-up to it numbered 16-64-99 dated 09/15/99 entitled "Revised Transfer Clutch Assembly Replacement Procedures" that should also be used should you decide to go ahead with the transfer clutch replacement.
I just got these Service Bulletins from my mechanic who got them from a Subaru dealer.
The estimate was about $700-$1000 to fix. This is more than likely the cause of the binding problem on slow, sharp turns.
Dan Hunt
Danbury, CT
SOURCE: transfer case is popping/jerking in low speed turns
Center differential is broken,you can test it by doing tight circles in a car park 3 or 4 to the left and repeat to the right,if it doesn't un block and it still feels like you're driving over marbles (big ones) when you turn you're sure it's the c.diff.
Check tyres are all in spec.identical and same usage, right pressure.
