Question about Sony Cyber-Shot DSC-F717 Digital Camera
Memory stick error
All of a sudden, when I turn on my camera, I get a flashing memory stick picture and a code C:13:01, also flashing, and under that is the notation, "memory stick error". I have tried two different memory sticks, with the same results. I have recharged the battery, taken the memory stick out and replaced with another, and back again...nothing seems to work. The camera had been working fine, I loaned it to my daughter who didn't have any problems, but when I next used it, the problem occurred. Thanks!
  • 641 Answers
Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck
Posted on Sep 04, 2007
Upon turning on error message appears " error formatting "memory Stick" c:13:02 flashes above. I can't take any pictures or look at the ones that i've already taken any advice would be appreciated
This looks like a fairly new camera from the name. I think you've got a memory stick problem. For some reason, the camera doesn't like it.
If it is fairly new, go back to the shop, get them to try a different stick, or buy another stick yourself or better still have you got a friend with a Sony memory stick you can try/borrow?
Mar 07, 2010 | Sony Cyber-shot DSC-W270 Digital Camera
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Memory stick error when camera is turned on
How about download the user manual from this link
and then, please read page 106 and follow the sugestions they have relative to your memory error.
Are you using the correct memory type recommended for your camera?
Did you insert the memory stick in correctely?
Is the metal part of the memory stick and the camera clean?
Did you accidently recorded video for a long time on the memory stick. The memory stick may be full.
Did you unlock the memory stick if it has one?
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 27, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
My sony memory stick pro duo doesn't work
It sounds like the software on the card has suddenly dissappeared. Try downloading the software from sony back onto the card. Let me know if this helps.
Jun 19, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Blue screen access error when viewing or taking pics or vids
Please try to take as many pictures from memory stick as you can then format memory stick through format option in setup.
Hope this will resolve this blue access issue.
You can use another memory stick like 1GB in this camera.
Mar 13, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Memory stick error
Hi There, In the menu there should be a setting to set the camera back to factory. Try re-formatting the card. Try using a different card. The camera has some built in memory, take card out and shoot 2 pics on built in memory, is playback ok?
If not, card reader may be defective. Only service shop could tell you that for sure.
Let me know, mr cicmo.
Dec 28, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Format Error in Sony Cybershot
it could be a faulty memory card, but a more likely cause is that this stick isn't formatted yet. you can format it usually by bringing up the camera menu, then going to tools and format. you can also format it by using windows and a cardreader or your camera.
Mar 04, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Memory stick error
Try using another memory stick, or insert a confirmed good memory stick, if OK, the memory stick is defective, if the same error, try pressing reset at the back of camera, a small hole beside the the DC jack. if OK, then fine, if still the same, camera needs repair. thanks
Sep 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Format Error C:13:01 on Sony DSC-W7
Please try with the new memory stick. Regards, Arpi
Mar 26, 2007 | Sony Cyber-Shot DSC-W7 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
201 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
