Question about American Pro VS-2043 Car Audio Amplifier
WHEN I HOOK UP THE AMP
ALL MY SPEAKER WENT QUIET AND NOW I CANT GET MY SPEAKER WORKING SWITH THE AMP ON AND THE RED LIGHT STAYS ON AND IT WONT GO BACK TO GREEN HELP
    Genius:
  • 1,139 Answers
Check your speaker connections and the try to power the unit on again. I fear that you may have damaged the power amplifier MOSFETs on the output stage. This is what this sounds like. I would first try to see if audio is going into the unit by using an oscilloscope and taking a reading at the input of the amplifier. If audio is preset I would take the unit to a shop since there are no user serviceable parts inside of this device. Look for a shop that will give you a free estimate. I do feel that you have internal damage to that device.
Posted on Sep 03, 2007
SOURCE:
Craig wireless portable speaker cma3561 won't charge battery
Batteries are holding back the 21st century. I have the older model of this and my battery went bad very fast. Now I have to keep it plugged in and not just any usb port will work it has to be a usb power supply of at least 2 amps. I keep mine in a 2100mA usb source.
Dec 25, 2013 | Craig Audio Players & Recorders
The Ground wire is hooked up right but the red light wont go off and stay green so the amp will work. It is very frusterating all the cables are the right size its is a 1000 watt amp. I have two 500 watt...
Sounds to me like the amp is going into protection mode. Try placing one sub on the amp with very little gain. One of the biggest reason why this happens is because the subwoofers are wired wrong. What is the brand and model number for your amp?
Apr 14, 2011 | Car Audio & Video
My mtx thunder 421d I just got has the red light staying on all the time, I have hooked up a rca converter and the amp wont play my sub, is that light supposed to be red all the time.
The LED should be red. If you are not getting power to the sub, make sure the speakers are connected properly to the amp. Also make sure that the gain control is turned up. If it is all the way down, you will not hear anything from the sub(s). If none of that works, it is possible that you have a blown sub. If you smell a burnt smell near the speaker magnet, there is damage to the voice coil in the sub.
Feb 25, 2011 | MTX Thunder 421D Car Audio Amplifier
I just got a sony xplod 1000 watt amp i got everything hooked up and when i turned the key the power light chaned from green to red. i check over the amp again and again, i cant find any thing wrong........
Try disconecting all speakers from the amp, turn it on after and if it stays on red it sounds like it had kicked the bucket. if it stays green start from their and check all of your wires for shorts (speaker wires) again. hope this helps...
May 08, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Red Light
that means you probably have a shorted speaker wire, a bad speaker or the amp itself is bad, try disconnecting the speakers one at a time and see if it turns on or not. if the red light stays on with no speakers hooked up it means the amp is bad
May 30, 2009 | Kenwood KAC-7252 Car Audio Amplifier
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Installing cd players
YOU HAVE THE ILLUMINATION WIRE HOOKED INTO THE RADIO
Oct 02, 2008 | 1999 Chevrolet Tahoe
I have a dub 4001 amp
Take it step wise.
Unplug the inputs and outputs from the amp (be sure to mark the wires so you can hook them back up), leaving only the ground, +12, and remote wire hooked up. Now, turn it on. If the amp light goes red, the amp is broken. If it goes green, turn if off, plug in the speakers, then turn it on. if it's red, its a speaker problem, if green, do the same with the inputs, and you'll have your answer.
Jan 22, 2008 | AudioBahn DUB Mag Audio DUB4001 Car Audio...
Audiobahn A2300HCt wont work
you might not have enough power pushing the amp.... I have two batteries and two caps running
Apr 02, 2007 | AudioBahn A2300HCT Car Audio Amplifier
American Pro VS-2043 Car Audio Amplifier Logo
127 people viewed this question
Top American Pro Car Audio & Video Experts
Dalynn Turner
Mark Skinner
Are you an American Pro Car Audio and Video Expert? Answer questions, earn points and help others
