Question about Brother MFC 8600 Laser Printer
Brother mfc 8600
I have problem in the printer ...says on the screen ( chick cassette 2) i would like to know what that soppose to mean and how i can sorf the problem please thanks
    Scholar:
  • 31 Answers
Hi, For those models available with a 2nd paper cassette, the "Check Cassette#2" will appear if the 2nd cassette sensor does not detect the paper cassette. So my thinking is that 1: the cassette is not seated in the printer correctly (not trying to be insulting, but it can happen to anyone) or 2: the sensor that "sees" the cassette is either out of place, or it has dust blocking it. (It could also mean that the sensor itself is bad.) Good Luck.
Posted on Sep 04, 2007
I have a brother mfc 3360C fax and it gives me error message 50.How do I reset the machine.
How to the Reset Purge Counter on a Brother Printer (With a Numerical Pad)
The 'Unable to Clean: Machine Error 46? message prevents you from printing on your Brother inkjet printer. It is especially frustrating when you realise there no reason why you can't carry on printing other than this message. Continue reading to find out what makes me say this and how you can rid yourself of this error.
This guide will deal specifically with Brother inkjet printers that have a number pad on the front of the printer. If you printer has a touchscreen as well as a numerical pad please see here. If however your printer does not have a number pad at all, the guide found here should be of use.
What is Error 46? 'Error 46: Unable to Clean' indicates that your Brother printer believes the ink absorber in the base of your printer is saturated with ink and any further printing could cause ink to overflow. How full this waste ink tank is has been estimated by monitoring how many pages your Brother printer has produced and how many manual/automatic cleans have performed. Sadly this is not a particularly accurate method of measuring how full an ink absorber is and the majority of the time your printer could prints hundreds of pages before there was any danger of any ink escaping. However getting the waste ink tank changed and resetting the counter can be an expensive procedure if you get a service centre to do it on your behalf. In many cases owners of Brother inkjet printers report the cost of the procedure outweighs the value of their printer.
With this in mind we suggest resetting the purge counter of your Brother printer using the method described below and continuing to use it until waste ink begins to overflow inside/outside the printer. This ensures you get the most out of your printer and can avoid replacing it until it becomes necessary to do so. I do however recommend you protect any surfaces around the printer should you decide to reset the purge counter to save any surfaces becoming stained with printer ink.
What printers will this reset work with? This reset procedure should be compatible with almost any Brother inkjet printer with a numerical keypad on the printer itself (and not touchscreen panel) and has been tested on every current compatible printer at our disposal. You can find a full list of compatible printers below:
Brother MFC-210C, MFC-215C, MFC-3240C, MFC-3340CN, MFC-3342C, MFC-410CN, MFC-420CN, MFC-425CN, MFC-5440CN, MFC-5840CN, MFC-620CN, MFC-640CN, MFC-640CW, MFC-820CW, MFC-235C, MFC-260C, MFC-240C, MFC-3360C, MFC-440CN, MFC-465CN, MFC-5460CN, MFC-5860CN, MFC-660CN, MFC-665CW, MFC-680CN, MFC-845CW, MFC-885CW, MFC-250C, MFC-255CW, MFC-295CN, MFC-297C, MFC-490CW, MFC-5490CN, MFC-5890CN, MFC-5895CW, MFC-6490CW, MFC-790CW, MFC-990CW, MFC-J615W, MFC-J220, MFC-J265W, MFC-J410, MFC-J415W, MFC-J430W, MFC-J5910DW, MFC-J625DW, MFC-J6510DW, MFC-J6710D, MFC-J6710DW, MFC-J6910DW, MFC-J825DW
If you have a printer with a numerical pad not covered above and find the purge counter reset works for you then please let us know so we can update our list.
Video Guide Purge Counter Reset Instructions Please note that some of the terms used below to describe buttons may change from one printer to another. For example:
  • START may be down as MENU or SET on your printer or be a green button
  • STOP may be referred to as EXIT or a red button
Before you begin the reset procedure your Brother inkjet printer needs to be in maintenance mode, but depending upon the model of your printer the method of doing this will vary. For most modern Brother printers please try the following:
  1. With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable).
  2. Hold down MENU/SET/START and re-insert the power cable/turn it back on.
  3. Keep the button held down until the screen reads MAINTENANCE.
If your screen does not now say MAINTENANCE it will need to be put into maintenance mode using one of the two methods below:
  • Printers with a built-in Fax: Hold down MENU/SET/START and quickly press * 2 8 6 4.
  • Printers WITHOUT a Fax: Hold down Menu/Set and the Black Start key before pressing the UP arrow four times.
Now your printer should say MAINTENANCE on the screen and you are ready to begin the process of actually resetting the purge counter.
  1. Type in 80 using the numerical keypad.
  2. Use the DOWN key to locate the purge counter. eg. PURGE0060025
  3. Use the number pad to enter 2783 (this should zero the numbers after PURGE).
  4. Press STOP/EXIT to return to the first stage of maintenance mode.
  5. Press 9 and 9 to exit maintenance mode.
Your purge counter is now reset and you can now resume printing as normal. If however this has not cleared the error message I advise going through this guide again following the instructions to the letter. If the error persists please let us know.
I hope you have found this guide useful. If however you have anything to add or any further questions please don't hesitate to let us know in the comments.
Jun 02, 2015 | Brother Office Equipment & Supplies
Print unable 71
Print Unable 71 means Polygon Mirror Failure on the Brother HL-4040, MFC-9840 and MFC-9440.
Pretty safe to say it means the same thing on the MFC-8880.
The Polygon Mirror is part of the Laser Unit, and its rpm isn't within specs.
The Laser Unit must be replaced.
Jan 08, 2015 | Brother MFC-8880DN Mono Multifunction...
How do i find the page count on a brother mfc 9700?
I could not find where or how to get the count on the unit (may not be possible).
But I found :
Estimated page count for Brother DCP-1200, 1400, MFC-8300, 8500, 8600, 8700, 9600, 9700, 9800, PPF-4100, 4750, 4750E, 5750, 5750E (TN-460) 8,000 pages
Nov 12, 2010 | Office Equipment & Supplies
Black dots on print outs from Brother Laser Printer MFC-9840CDW
meaning your printer drum is growing weak and will soon need to replace
Apr 10, 2009 | Brother MFC-9440CN Laser Printer
Can't get brother out of sleep after 99 minutes inorder to pring
Try plugging the mfc into another usb port on the computer. The ones in the back are closer to the processor, usually work better.
Mar 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 8460
Hi
There must still be a piece of paper in the machine check the fuser section at the rear of the machine maybe be piece there or check at the paper cassette area remove cassette and check that the paper hasn't got jammed as it feeds through.
Thanks
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Full-Screen configuration for MFC-5440CN
Well, the configuration panel has two sections, Software Button and Device Button. It's not self evident, but you must set the update paramet BOTH on the first AND on the second.
God knows why make things complicated when they be simple!!
Nov 13, 2008 | Brother MFC-5440CN All-In-One InkJet...
Not receiving faxes or able to copy
it is referring to the paper holder (cassette ), it's expecting to get paper from cassette # 2
check settings for paper source and change it
Oct 03, 2008 | Brother MFC 9700 All-In-One Laser Printer
Brother MFC-9700 error message says "reinstall cassette #2 properly". It is installed properly. Turned machine off. looked inside, no paper jambs, cassette seems to be okay, reinstalled just...
I just experienced the same issue, and from research it looks like there is an optional second paper cassette that you can purchase. If it is set to have the second cassette turned on and you don't have that option the machine is looking for something that does not exist. In my case cassette #2 was turned on via the menu (Menu, Option 1 (General Set-up), Option 5 (Cassette #2), make sure it is set to "off"). Once Cassette #2 was set to off the machine started working properly again.
Jul 10, 2008 | Brother Office Equipment & Supplies
Brother MFC 8600 Laser Printer Logo
152 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
