Question about LaCie 301103U 500 GB USB 2.0 Hard Drive
The fan from my LaCie 500 GB USB 2.0 Hard Drive
When the fan starts make's a lot of can i open the case to see what is rong.i belive theat he is thouchig somthing inside there..10x
    Problem Solver:
  • 6 Answers
I'd look for tiny screws. I'm not familiar with this model, but external drives either slide into a tube-like case with a removable front and back plate, or have a removable top, similar to the case on a computer. I'd be surprised to find that there's something hitting the fan. The wires in there are packed pretty tight. I'm guessing that the fan is dieing. You'll likely need to replace the fan. If you're lucky, it's a plug-in. More likely, it's a solder-in. If this is under warranty, I'd call LaCie and have them fix it. Definitely don't use it if the fan is dying. When the fan goes, the drive could be close behind.
Posted on Sep 05, 2007
I just bought Lacie rikiki hard drives. As I put it into my computer the assistant starts. Unfortunatelly after few minutes the process stopped and the capacity is 465 GB instead of 500 GB. Is there any...
This is normal. You will never get all the capacity for a USB key or a hard drive. The missing space is for format purpose and hard drive maintenance.
Hope it helps
Feb 08, 2011 | LaCie Rikiki Go 1TB USB 2.0 Portable -...
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Lacie do not start
If it still is under warranty, then exercise the warranty, and get it repaired/replaced.
If it's out-of-warranty, then disassemble the case, and disconnect the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if the disk-drive still works.
If it's dead, it's dead, unless you pay mega-dollars to a professional "Data Recovery Service" to rescue your files.
If it is dead, then buy another disk-drive that is compatible with that USB-to-disk-drive adapter, and reassemble the unit, and you'll have a brand-new external drive that you can use.
May 29, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Not reading
Disassemble the case, and remove the disk-drive.
Attach it as a "slave" disk-drive in some desktop computer, and see if the desktop computer can "detect" the disk-drive, and if the files on the disk-drive are still accessible.
Mar 03, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
My computer is not detecting my LaCie Hard Drive
there is a usb port inside hd .box /many time it is damage and also usb cablle damage . so once time change this thing one by one to check. there is a rare chance to damage hdd. we have facinge many time same problem. this hdd and laptop hdd are same. only potr is diffrent, (nepal)
Oct 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Go for it. There's a chance the internal drive will be PATA (IDE) but odds are good it's a SATA drive with standard connections.
Make sure your PC has connections for SATA drives, and you'll need to buy a SATA cable since the one in the LaCIE case won't connect from your drive to your motherboard.
Sep 08, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie 500GB P3 got the clicking sickness
There are companies that can recover the date from the disk of a failed hard drive, check online, It is expensive.
Apr 20, 2017 | LaCie 500GB P3 HD USB 2.0 7200RPM 8M 500...
LaCie 301103U 500 GB USB 2.0 Hard Drive Logo
154 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
