Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
O.S. how can i back up my all data of hard disk
    Problem Solver:
  • 12 Answers
This solution is to copy your entire hard drive. You will need hard drive imaging software. One product is Symantec Ghost but you can "google" hard drive imaging to find other products. This type of software will create a "snapshot" of your hard disk. It will then write it to some other attached disk that you specify. Without knowing how mush data you have, I would suggest that you save your "ghost" image to another hard drive of greater size than the one you have installed. Hope this is of help to you.
Posted on Sep 03, 2007
    President:
  • 2,961 Answers
You can use windows backup facility, start>all programmes>accesories>system tools>backup, or use a third party software similair to norton ghost if you wish to back up the operating system as well.
SOURCE:
Is it possible to recover data from the disk inside the external hard disk?
See first this clicking sound is not good in terms of hard drive failure as continuous clicking is one of the symptom of hard drive failure.
Secondly you have tried to do something with the hard drive by your own that you should not as it is always recommended that you should not open your hard drive in any open environment except Class 100 Clean Room Labs that is only available with Professional Data Recovery Company.
This is recommended because opening the hard drive in an open environment can damage your hard drive severely thus it reduces the chances of successful data recovery from the hard drive.
Now if your data is really very important then i would suggest you to take help from a professional data recovery company.
Mar 22, 2013 | Transcend StoreJet 25M2 500GB Hard Drive...
Tip
Hard Disk Data Recovery
Definition of Hard Disk: Hard Drive is a storage device where you can store any types of data and file. Hard Drive is available as external and internal device. We know PC storage device as internal system Hard Disk. When you save data or install programs on your computer, the information is typically written to your Hard Disk. The Hard Disk is a spindle of magnetic disks, called platters, that record and store information. There are several interface standards for passing data between a Hard Disk and a computer. The most common are IDE and SCSI. Hard Disk is made of one or more aluminium or glass platters, coated with a ferromagnetic material. Most Hard Disks are found as Parallel ATA (PATA), Serial ATA (SATA) or SCSI device.
Difference with Floppy Drive:
The term hard is used to distinguish it from a soft, or floppy, disk. Hard Disks hold more data and also faster than floppy disks. As an example a Hard Disk can store anywhere from 10 to more than 100 gigabytes, where most floppies have a maximum storage capacity of 1.4 megabytes. Floppy is more risky device than Hard Disk for losing data.
Problem with Hard Disk:
Most common problems of Hard Disk which may arise anytime are Booting problem, OS Installation problem, Hard drive crashing and another Hard Disk not showing original space or not showing partition etc. But in every case the risk is loss of data. In some of cases formatting and reloading of Operating System can recover your Hard drive and make it useful but formatting can recover a blank Hard Disk only without data. But you have to recover Hard Disk with data, so formatting is not possible.
Data Recovery:
Data recovery is the process of retrieving back data from the damaged media. The damage of storage media can be physical damage and logical damage. The data is retrieved back by recovery experts after determining the type of the damage caused to the storage media. Most of cases data recovery is important and formatting is not possible there. So that I need to choose another way for solution of this type of problems of Hard Disk. The first and secure way to recover a Hard Disk is using data recovery software.
Recover Data from crashed Hard Disk: Power surges, Software Corruption or Malfunction, Hardware or system failure, Natural calamities, User errors may crash your Hard Drive. Data recovery software helps to retrieve or recover the data from the crashed hard Drive. Data recovery software gives an easy and Graphical User Interface with less difficulty so that the data can be recovered easily. The recovery software helps to recover the data and restore them on a second Hard Disk, the Hard Disk being connected to the computer and recognized by the BIOS, the recovered data can be stored on a safe location on the second disk.
Logical data recovery: In a data loss situation when the Hard Drive is perfectly fine and the BIOS recognizes the Hard Drive but reports a read error, logical data recovery technique is very helpful. Here the files that are damaged or corrupted by any user error or virus attack are rebuilt rather than repairing the Hard Drive.
Fragmentation: When the FAT entry is lost during accidental file deletion, formatting or partition deletion that particular block of Hard Drive becomes inaccessible. Some data recovery software makes an attempt to rebuild the files without a FAT entry. This technique is very efficient if the file size is smaller than the clusters size. But it is inefficient in recovery the larger files.
Data Recovery from deleted partition: Partition is allocation of memory in different sections. Each partition will be like separate disk drives. Partition is very use full when the user is using operating systems more than one. Usually after formatting the disk it may not be able to recognize a partition because of accidental deletion of the partition table or by virus infection. The partition is not actually deleted; it can be recovered by using recovery tools and copy the data present in the partition to the required destination. Formatting the drive erases a large amount of data present on it, but not all the data. The recovery of the data depends on the fragmentation of the file system as the parts of files are being placed on different places in the drive. The data recovery software will assume that files were not fragmented and stored in continuous clusters. If the partition was formatted using different file system, then recovery process will be very complicated.
Another Data recovery process: If you don't have any data recovery software you can try another process to recover data. Attach the Hard Drive with another system in slave or second SATA.If detect the drive then boot to the first Hard Drive and use the bad Hard Drive as secondary. Then you can copy the data from the second drive to first drive easily. Here have another process to recover data from a crashed Hard Disk. But it is so risky, and should not try to do this for an inexpert person. First pack the Hard Disk in a bag properly where moisture can't attack. Now freeze it upto get chill. After freezing quickly attach with a system in secondary, and copy the data within the Drive will come in room temperature.
So the most secure process to recover data from a Hard Disk is to use data recovery software. It is available in market.
on Mar 18, 2011 | Computers & Internet
How to recover data from my toshiba 320 hard disk?
Data lost due to unintentional formatting of the drive or when someone knowingly delete some data later on realizing that the data was important, In situations like this one should use a data recovery tool. To know more about data recovery process visit http://www.recoverlostfile.net
Dec 23, 2012 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
I have an external hard disk drive. It has a 160 GB transcend, Yesterday, all things were working OK, but today, when I insert the disk, my laptop gets hung. The disk is being detected, but after opening,...
Firstly,recover your data on the external hard drive with third party data recovery software.Then you can format it to check out whether it can be fixed.
For data recovery program,I have a professional one on my computer that can recover data after deeply scanning your hard drive to look for lost data due to drive crash,system sabotage, virus attack etc.You can download it and scan your hard drive for free to preview whether your data can be recovered. http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Aug 04, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
My hard disk on nx9420 failed (i get the message 'critical error - imminent hard disk failure, save all your data'; but the computer will not boot (just says press 'control alt delete')....
This warningmeans the hard disk will fail sometime in the near future. You need to back upyour data regularly before the hard disk fails or you will lose your data.
When the hard disk fails, you need to replace with a new one and installWindows on the new hard drive to get your computer working again.
If you cannot boot up your computer then -
Remove the hard driveand connect it to an USB hard drive adapter and plug it into a workingcomputer's USB port. If this computer detects it as an external storage deviceand you can open the various folders and files then back up your data.
If not you are in trouble, there are companies that can recover data fromfaulty hard drives BUT it will cost you an arm and a leg for their services.
Jul 18, 2011 | Computers & Internet
My 310gb transend hard disk all foders became shortcut lnk files size shows 2kb,please guide me to recover data?
Hi there,your external hard disk may be infected by virus.Firstly,remove the virus with anti-virus software in your computer.Then you can recover your files from hard disk with third party data recovery software.I have succeed to recover files from hard disk with Tenorshare data recovery.It can recover data after deeply scanning your hard disk to look for lost data.
By the way,you can download a trial version and scan your hard disk for free to preview whether your files can be recovered. http://www.any-data-recovery.com/index.htm
Jun 24, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I have purchased the lenova laptop in which th Hard Disk is from Hitachi and my data is in the Hard Disk how can i get back my data
You can use an external Hard disk and transfer your data.
If you want to transfer it exactly as it is, U can remove the Hitachi Hard Disk, put it in a hard Disk case, and use it as an external hard disk
Mar 01, 2011 | Computers & Internet
Smart disk programme
Back up your data as soon as possible so when the hard disk actually fails you won't lose your data.
When this happens you will need to buy a new hard disk and re-install Windows and you can copy your data back onto the new hard disk.
Mar 27, 2009 | Acer TravelMate 3270-6569 Notebook
Hard drive failure in system less than 2 years old!!
Since you are comfortable with working inside your computer, the best thing to do now is to purchase an external enclosure for your type of hard drive, SATA or EIDE.
Alternately you can use a live linux cd, boot up with that, and transfer your data to an external drive.
Once your data is safe, try booting to the Windows cd and attempt a repair installation.
And finally, yes, hard drives can go bad in 2 years or less.
Dec 14, 2008 | Dell Dimension 2400 PC Desktop
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
94 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
