I am afraid I already know the answer to this one, but here goes. A family member accidentally cracked the LCD screen and now the camera will not do anything. The screen lights up, but no picture visible. Will not go into telephoto range. Can this be repaired? Or do I just have to scrap it and get a new camera?
Thanks for advice.
I was about to say you could find someone with another part broken and put the two cameras together to make one good one, but your comment about it not zooming suggests that more is broken than the display. Looks like you are out of luck.
You're so funny. You're complaining to the wrong place. Not many people want to deal with a lunatic. The people here on fixya (like me) volunteer their free time to help others out. We don't own you an answer.
Try removing the cam battery and reinstall after a 10 sec waiting time. This will reset the camera and put setting back to DEFAULT mfg settings.If that doesn't work it is a loose connection on the ribbon cable that connects the LCD screen to the board and Im afraid it will need to go to the camera shop.
Thanks for using Fixya.com
Please dont forget to rate my answers.
I work for a computer company and i am sorry for what has happened to your computer. Regarding the display that your screen shows I'm afraid but let me get straight forward. The LCD screen is broken from the inside. Probable causes:
Computer must have been accidentally dropped.
Force applied on top of the laptop which caused the back side of it pressed.
Heat that escapes from the motherboard, goes through the keyboard straight to the LCD which causes liquid elements to expand and breaks LCD from the inside. That's why it is always advisable to let the laptop cool before closing the LCD screen.
I wish I had £1 for every time I have answered this problem! If the your screen is cracked then I'm afraid it's gone! The only cure is a new TV - to get the screen replaced will cost more than a new set!
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
It sounds like this is a common problem with this model. The lcd screen on my SD870 IS developed a large area of dead pixels a few months after I bought it new. A family member with the same camera had the exact same problem.
There is connectingflexible cable/ wire between lcd board and camcorder board which is cracked and requires replacement.
I can provide you part number of flexible cable and rest is your own skills like how to apart camcorder and lcd section.
If you are familiar with camera repair, let me know to proceed.
You need a replacement screen.
You can find a broken M407 with a good LCD on Ebay for pretty cheap. (I picked up one for $20 shipped).
From there, it's a matter of taking out the 6 screws (very small Phillips screwdriver) that hold the camera housing on, the 2 screws that secure the LCD retaining ring on, pulling the LCD out of its mount, and gently pulling the LCD ribbon down and out of the white connector (mounted on the camera's board).
Reverse to reassemble.
Gentleness and patience is key, you're dealing with sensitive electronics here.
Even someone with little mechanical aptitude can do it, I'd say 30 mins tops to swap screens out of 2 cameras.
Before you buy an Ebay camera, try taking yours apart first to make sure you can do it, or find a family member or friend who's up to the task.
These cameras are not worth that much now. It's not worth paying a shop to do it. If you don't get a deal on an Ebay parts camera and do it yourself, you should invest in a new camera.
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
