Canon PowerShot A60 Digital Camera Logo
Posted on Sep 03, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DisplY Issue I have no display when I want to take a picture, when I check the options and settings they appear on the display. Any suggestions?
zdenek vajdak
Level 2:
Champion:
  • Expert 206 Answers
  • Posted on Sep 04, 2007
zdenek vajdak
Expert
Level 2:
Champion:
Answers
206
Questions
0
Helped
90523
Points
353
No image in capture mode ( camera mode )with no problem in playback is typically ( assuming the lens and shutter work ok ) caused by faulty ? dead CCD sensor...replace.
TC-L32C5 - after 1 or 2 minutes from turning on..the display is fading and becoming all black display but the sounds stays loud and clear without issue. How can I resolve this problem?Thanks
Lines on the screen (vertical/horizontal lines, bands)
Image diagram of symptom
Press the HOME button on the remote to display the TV menu screen.
When the issue occurs in the Menu screenThere may be an issue with your TV. Follow these steps to troubleshoot:
  1. Restart the TV and check if the issue is resolved.
    1. Turn off the TV and unplug the AC power cord (main lead).
    2. Keep the TV unplugged for 2 minutes.
    3. Plug in the AC power cord (main lead) and turn on the TV to check its status.
  2. If the above steps does not help to resolve the symptom, the product may require service. Go to Product Repair.
When the issue occurs on other than the Menu screen There may be issues with the broadcast signal source, Cable/Satellite box, IPTV, or other devices such as a DVD player.
NOTES:
  • If this issue only happen to one particular channel or broadcaster, this may be due to the broadcast signal source. Please contact your service provider for further information.
  • If you experience issues when connecting a TV and an Audio/Video device via an analogue cable (composite or component cable) or HDMI cable, check the following section of this article before proceeding the steps below: Screen issues (Lines/Blurred/Odd colours) from the Audio/Video device
  1. Turn off any electrical or battery-operated devices that may be creating radio frequency (RF) interference.
  2. If using an antenna, broadcast signals are reflected by nearby mountain or surrounding tall buildings and may cause ghosting in the picture.
    It is recommended to adjust the antenna direction and location.
  3. Try plugging the power cord into a different electrical outlet and/or surge protector.
    These symptoms can occur if the electrical outlet is improperly wired or not producing the proper voltage.
    If using a surge protector or extension cord, it also could be faulty.
(Back to top)
How to perform a software update.
  • Clean the TV screen. Refer to the following FAQ.
    How to care the LCD TV
  • If the above steps do not help to resolve the symptom, the product may require service. Go to Product Repair.
  • When the issue occurs on other than the Menu screen There may be issues with the TV settings, broadcast signal source, Cable/Satellite box, IPTV, or other devices such as a DVD player.
    NOTE: If you experience issues when connecting a TV and an Audio/Video device via an analogue cable (composite or component cable) or HDMI cable, check the following section of this article before proceeding the steps below: Screen issues (Lines/Blurred/Odd colours) from the Audio/Video device
    1. For TVs with the Motionflow function, select Standard or Off.
    3. The quality obtained from DVD discs recorded on home DVD recorders often varies due to different quality settings being used on the recorders.
      Picture quality from VHS tapes often appears to be significantly worse than other sources, symptoms often include grainy and watery picture.
    4. Reset your TV to the factory defaults. Refer to the instruction manual supplied with the product. Manuals are posted on your model support page.
    (Back to top)
    Picture and video on the TV is displayed doubly.
    (Back to top)
    The screen appears to have a cloudy, white shadow or bright spots when there is no input or when viewing very dark scenes.
    (Back to top)
    Adjusting the Picture setting on my Android TV
  • For other than Android TVs: Adjusting the Picture setting on my LCD TV
  • (Back to top)
    How to reset an Android TV?
    How to perform a power reset on a Sony television.
  • Update the software of your TV to the latest version.
  • (Back to top)
  • If your TV has a reset function for its picture settings, follow the instructions below to reset the settings.
  • Press the HOME or MENU button on the remote control.
  • The next steps will depend on your TV menu options:
    • Select Settings- Display & Sound, Picture & Display or Display - Picture or Picture adjustments - Advanced settings - Reset.
    • Select Settings- Display - Picture - Reset.
    • Select Settings - System Settings -Picture - Reset.
      NOTE: If your remote control has the Option button, you can reset the settings by pressing the Option button on the remote control - Picture or Picture Mode - Reset.
  • Restart the TV and check if the issue is resolved.
  • If the TV is connected to an active and stable Internet connection, install the latest TV software. Refer to the following FAQ.
      1. Press the HOME or MENU button on the remote control.
      2. The next steps will depend on your TV menu options:
        • Select Settings - Display - Picture - Reset.
        • Select Settings- System Settings - Picture - Reset.
    • Check if the cable is firmly connected to the TV and the connected device and make sure it is not loose.
    • Use a spare cable to replace the currently used one and see if the situation will improve.
    • Use another input terminal of the TV.
      1. Connect your device to other input terminals of your TV.
      2. On the TV's supplied remote control, press the input button to switch to the input method that corresponds to the connected device and check if the situation improves.
    • Connect another A/V device to your TV using the same input terminal to check whether the connected A/V device causes the issue.
    • If using an antenna, broadcast signals are reflected by nearby mountain or surrounding tall buildings and may cause ghosting in the picture.
    • Turn off any electrical or battery-operated devices that may be creating radio frequency (RF) interference.
    • Reset your TV to the factory defaults:
    Webcam issues
    For use with systems including an Acer Orbicam, CrystalEye, or other factory installed camera.
    Taking still pictures
    1. Double click the Orbicam Icon to start the program, which will open the main application screen.
    2. Set the configuration choices by clicking on the "gears" icon, which should open an additional window that slides out. Clickthe tabs and select the options for the desired settings. By default, still pictures will be sent to the "Pictures" folder.
    3. Set the resolution for still pictures by pressing the arrow under the main display. A drop down menu should appear with the available resolutions. Larger resolutions will result in larger file sizes.
    4. To take a picture, align the subject in front of the camera so that the display appears in the window as desired. Click Take Photo.
    5. The pictures should appear along the bottom of the application window if the Gallery view is enabled.
    Using the camera as a webcam
    1. It is suggested to find a third party application to use this functionality.
    When trying to take picture of my children it is very blurry. Yes they are somewhat moving but it didn't use to be as bad as what it is now. Should I try another setting? Thanks
    Check if the white balance setting in the camera menu is set to Auto White Balance (AWB) . Ordinarily, the auto white balance function of the camera can resolve issues with color accuracy, but sometimes certain lighting conditions can still cause discoloration. For example, the entire image may appear blue under cloudy conditions and white subjects may have a reddish tint under incandescent bulbs. If the auto white balance does not resolve the issue, try a different white balance setting, depending on the condition - Daylight , Cloudy , Fluorescent , etc.
    If the issue still persists after changing the settings, please initialize the Camera and that should resolve the issue.
    To Initialize the Camera,
    Press MENU to display the menu of the Camera.
    After pressing the FORWARD ARROW key on the Control buttons, go to SETUP and then press the FORWARD ARROW key again.
    Scroll to the SETUP 1 submenu using the Arrow keys. Press the ENTER key ( the key at the center of the arrow keys ) once you reach SETUP1.
    Then scroll to INITIAZE setting.
    Then select the INITIALIZE option using the ENTER key and then select the OK option.
    Then press the ENTER key to select the OK option.
    After initializing, the Clock Set will be displayed, set the Clock and capture an image and then the images should appear perfect.
    If the issue still persists, then the Camera requires to be physically examined to determine the exact issue.
    Thank You!
    I dont know how to turn camera on
    Q: Camera Usage Instructions
    A:
    Recording video
    We cannot support third party application configuration or use.
    I have toshiba a505, how do i mk my webcam work
    A:
    Recording video
    HP Pavillion dv9000 screen disply problem
    Try starting up in Safe mode by pressing F8 as soon as you see the HP logo on the screen at startup, then choose safe mode.
    If there are colors within safe mode, try going to Start-->Right click on My Computer and go to Manage.
    From there go to device manager on the left side and on the right side click the plus next to Display adapters
    Under there right click and uninstall all display adapters, then reboot
    Windows should reinstall all drivers for the display and hopefully will correct the issue
    Monitor disply movable horizontal lines.
    yes you first check the supply at vertical ic 12v if present then replace that vertical ic if supply is not present then check the regulator ic in smps if faulty then replace it
    DVD wont display anything on the TV
    Some of these devices reset completely when you disconnect them from the electricity. Try this, if not, go to the menu, and in "set up" select te option "default settings"
    Display Issue
    This is a CCD problem - contact Canon re placement
    2answers
    ADJUST HORIZONTAL HOLD
    PRESS DISPLY KEY AND PICTURE MODE KEY SIMILUTONSLYON THE RECOTE CONTROL.
    SERVICE MODE WILL APPEAR ON THE SCREEN.
    GO TO DEF SETTING AEREA AND SHIFT BY PLUS OR NEGATIVE KEY.
    Top Canon Cameras Experts
    old marine
    old marine
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Canon Camera Expert? Answer questions, earn points and help others
