Question about Panasonic Palmcorder PV-L353 Camcorder
Recording I can record and play my recordings but there is no sound. I had sound before but now all of a sudden I can't hear anything even when I turn the volume all the way up.
  • Anonymous Dec 15, 2007
    When I record the sound records sometimes -- can't tell when the sound will record -- one time it's ok the next time no sound recorded. I sent to repair a little over a year ago -- said a broken board -- repaired it and now the same problem. Repair will chage me the same $100 just to bring it in plus work.
    How do I disassemble the casing to get at the boards.
  • inajamaica Jan 13, 2008
    Ditto - had one recording where absolutely no sound was recorded. I'm guessing I'm going to have a mic problem like the rest. Tried taking the camera apart, but it's not so easy - looking for more info on how to disassemble it and get to the mic.
I had the same problem but now that I took all apart and reconnected the mic it works perfectly
Posted on Sep 23, 2007
    Champion:
  • 287 Answers
I see bad mics in these all the time.
Posted on Sep 18, 2007
Why the camera is recording without sound?
There must have been something really wrong with your camera, if the miss or was blocked..
Most of the time the removal of the battery should be enough to reset the camera.
When you are recording a video, and playing it back on the camera, you should hear the sound. I don't have the manual for the D5100 at hand, but there should be tree settings for the microphone Manual sensitivity , automatic sensitivity and off. Look in the menu settings what you selected.
I hope everything is well with the camera and I hope you charge the battery more often, even if you don't use the camera that often.
Jul 21, 2014 | Nikon D5100 Digital Camera
Sound recorder
Please check all of the settings options under the Control Panel - Sound.
Mar 09, 2014 | Toshiba Computers & Internet
Poor sound quality from external line
it may be the recorder itself.. these smaller recorders arent known for excellent recording quality..what is it set for..also check the recording lens and clean with a duster spray..it may be dirty..
Jan 19, 2014 | Tascam BB-1000 Portable CD/SD Recorder
Recieving calls ok ,we cannot hear anything, yet the caller can hear our voices,tried dailing out, same we can`t hear dail tone yet they can hear us, unplugged all lines put in phone to main line still no...
pls make sure that your cell microphone is working.. if not get the microphone replaced..
to chck the microphone, do any sound sound recording and play it back... u will know that it is working if u hear the recording, if no sound comes, sorry to say but your microphone's gone..
hope dis helps.
Jan 19, 2011 | Cell Phones
Friends say When i speak sounds like Static any 1 know how to change setting or find it in computer. Im using Satellite Fusion
The external microphone itself could be the culprit, or its connection to the 3.5mm port could be flaky. To test the theory do this:
1 Connect an external microphone to the computer.
2 Click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder.
3 Click the Record button and speak normally into the microphone.
>>>> WIGGLE THE CONNECTION AT THE LAPTOP OR FLEX THE MIC CABLE WHILE RECORDING. Maybe even narrate what you are doing while you record your voice. "Flexing cable near mic, now near plug..." <<<<
NOTE: You can only record 60 seconds at a time.
4 When you have finished recording, click the Stop button.
5 To hear what you just recorded, click the Play button.
6 To save the file, select Save from the File menu.
>>>> If you hear crackling in the playback that correlates with your handling of the cable then bad seating or a bad cable are the problem. <<<<
Adjusting recording quality
The better the quality of the recording, the more disk space the sound file requires. Experiment to find a balance that fits your needs.
1 Open Sound Recorder, if necessary (click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder).
2 In the Sound Recorder window, click Edit, then click Audio Properties.
3 In the Audio Properties window, adjust the Sound Playback quality and volume, and the Sound Recording volume.
4 Click OK.
Your new settings take effect the next time you record.
Dec 30, 2010 | Toshiba (P000257700) Microphone
HI when I use my cam (sony handycam D8) in the play mode to read videos the tape turns but there is no vids and the time counter is --:--:-- means not counting even if I can hear the sound of the...
Try to use cleaning tape there is must be dust on video head. First use cleaning tape for 5 secound then play you tape if its not ok then use more 5 secound. After that check your recording tape hope fully it will work.
Oct 28, 2010 | Sony DCR-TRV270E Digital-8 Digital...
Can't hear recordings
Try double clicking on the volume control in the system tray.
In the box that comes up, see if the wave control is off, or set low.
Move the slider up, you should get sound.
May 04, 2009 | Sony Sound Forge 8.0 for PC
No sound when recording on Sony TC W390 deck
If the deck does not have a monitoring function, then that's how it works.
Jan 13, 2018 | Sony CASSETTE DECK Single Dual Cassette...
Noise in the sound while recording
does it sound like you have stuck your head out of the window of a moving car if so then the speaker is blown it happens sometimes, worst case sometimes its the main pcb as well.
Nov 15, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Panasonic Palmcorder PV-L353 Camcorder Logo
259 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
