Push F8 before the splash screen loads - start pushing it the moment you start your computer. You should get a screen that allows you to start in safe mode. Once you've started in safe mode, try rebooting and see if you computer comes up normally.
The clientpro 385 was recently restarted and now the power button flashes green every one to two...
(More)
The clientpro 385 was recently restarted and now the power button flashes green every one to two seconds. Unplugging the computer and plugging it back in changes nothing.
3 contact Led Switch 12 volts Question the Ground tab on Switch which needs to be grounded for the...
(More)
3 contact Led Switch 12 volts Question the Ground tab on Switch which needs to be grounded for the LED Toggle to light up, can this ground be connected to one of the computer 4 pin Molex Black wire. If so which one the Black Wire next to the Red Wire or the Yellow Wire.
computer will not turn off, it just reboots. took it back to dealer and it worked fine at the store...
(More)
computer will not turn off, it just reboots. took it back to dealer and it worked fine at the store but as soon as I plugged it in at home office it didn't turn off
I have a hp compaq d350 sff and want to change the processor, but I need to know what type of...
(More)
I have a hp compaq d350 sff and want to change the processor, but I need to know what type of processors are compatible with the motherboard of this computer. Please help mE THANKS!
When I bought an older model Dell PC I was assured it came with cd burner... Whenever I insert a...
(More)
When I bought an older model Dell PC I was assured it came with cd burner... Whenever I insert a blank cd to burn material on my pc says "to insert disc" as though its not reading it. I've tried a few brands of blank discs and no luck. Im hoping theres a way to solve this problem on my own....
