Question about Panasonic TH-42PD25U/P 42 in. Plasma EDTV
No Picture, clicking noise in rear of set
No picture, no use of remote or on-tv controls. Red power light comes on, but theres a weird clicking noise in rear of television. Any ideas????
  • 1 more comment
  • Ben jones Feb 11, 2008
    I have the same problem. I've checked a few voltages at the PF-board(Power filter board). The 10.5 voltages were at 1.6 to .4 volts. The 24v is at 0.0 and the 5v standby is 0.0. I suspect the PF board. There is also a very light clicking coming from the PF board in beat with the louder clicking noise. I want to replace the PF board but I want to be sure. Anyone out their have any suggestions
  • juany813 Jan 15, 2009
    dosent start ,light stays red and a clicking noise inside a couple of second after it starts the light
  • Anonymous Mar 19, 2014
    TV is reluctant to come on
IC Control not work
Posted on Feb 18, 2009
    Problem Solver:
  • 3 Answers
I have the same set and had the same problem. I repalced the DT board and now its fine except I have no video signal. I get sound all day long!! I also have the on screen menu to make adjustments but still no video from any input.
Posted on Mar 10, 2008
First unplug the set for about 10 secs and plug it back in to force it to reboot its firmware. The on/off switch does not do this. It takes about 10 seconds for the reboot to occur so wait that long then turn on the TV with the on/off switch. If that doesn't work try a factory reset. Turn off the TV. Open the front door on the TV and HOLD the OK button down and then press and HOLD the power button at the same time for about 2-3 seconds. Hopefully you will see a screen come up and say Self Check. The TV does some built in tests and then goes to the menu screen like it came out of the box. You will have to reprogram all your stations and settings.
Posted on Sep 07, 2007
    Genius:
  • 1,139 Answers
This may be a power supply relay actuating, What I would suggest is taking this set to a TV repair shop since the attempt to try to repair this yourself may lead to further complications.
Posted on Sep 03, 2007
SOURCE:
My tv clicks to come on but no sound no picture
If there was a power outage the problem is likely in the power supply.
The power light on the front comes on or not?
If no power light unplug the set and follow power cord inside and check the fuses---the click is a power relay activating---set may have up to 3 black relays on the power board.
Let me know your skill level and I will be happy to help.
SD TECH
Jan 16, 2012 | Hitachi 57F500 57" Rear Projection...
TV does not have a picture, however when the power button is tuned off and then on the IR light blinks and there is a LOUD clicking noise coming from the speakers. The remote control seems to work fine,...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 01, 2011 | Akai LCT2715 27 in. LCD Television
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Burning plastic smell, colours way off, picture way off & skewed
Thats funny!My TV is doing the same thing,but now I hjave no picture just sound!
Sep 01, 2008 | Akai PT5598HD 55" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Open Questions:
See all Panasonic TH-42PD25U/P 42 in. Plasma EDTV Questions
Panasonic TH-42PD25U/P 42 in. Plasma EDTV Logo
314 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
