Question about Samsung SGH-E330 Cellular Phone
Wont Turn On
I Dont Know What Button To Press To Turn My E330 On? Anyone Help? X
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
The red one with the phone symbol on it.
Posted on Nov 26, 2008
6ya staff
SOURCE:
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
Megane key fob wont work
the lazer bulb has snapped off inside your key fob
open it up... move the blubs pins to the revers side of the chip board and solder it to the nipples
make sure you dont turn the bulb as + / - will be the same on ither side of the chip board
Jan 03, 2009 | 2000 Renault 181
Lexmark e330 doubts
Please use this link it may be helpful:::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi
Feb 26, 2008 | Lexmark E330 Laser Printer
WIFI and SDIO
Are you sure your PDA supports Wifi through SD? I have only found information that suggests BlueTooth.
Sep 15, 2005 | Toshiba e330 Pocket PC
What is the maximum amount of SD/MMC memory on e330
In my opinion there is no any limitation. I am pretty sure that you can use 1GB SD Card without any problems. Only thing that can happen is that access to your data can be a little bit slower.
Sep 11, 2005 | Toshiba e330 Pocket PC
GPS on a e330
In my opinion there is no reason that it will not work properly. As far as I know lot of PDA`s are sold in Germany with GPS. Only problem can be GPS hardware. If you want to buy some please check which ports they need to work properly.
GPS-card possible in SD-slot?
As far as I know there is possibility to use Compact flash but no SD. I also know that you can find a lot of solutions that use USB or Bluetooth connection for GPS.
E330 crash
Use the reset button at the back side of your PDA. Keep pressing for a few seconds.
My PC not turn on
The Toshiba Pocket PC e330 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower left edge of the unit, next to the "DC-In Socket". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. If you have further questions, please refer to the Instruction Manual page 2-3 (20 of 105).
Sep 08, 2005 | Toshiba e330 Pocket PC
Initialize my Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e330 or e310. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Your Pocket PC's initially installed programs are not deleted. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow the steps: Turn off the power Press the power button while pressing and holding the reset switch with the stylus. Then release the power button When a screen appears, release the reset switch When initialization is completed, the Welcome screen appears. Set up the system according to the screen as in the case of startup procedure.
Samsung SGH-E330 Cellular Phone Logo
52 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
