Question about Toshiba Satellite P105-S6207 Laptop
I want to restore factory settings on my laptop
Daughter accidently changed settings and now some programmes are unavailable
  • Anonymous Mar 28, 2009
    i have a virus on my toshiba satellite p105, i need to restore it...help
    President:
  • 2,961 Answers
You could try a system restore to the day before the changes, go to accesories,system tools, system restore. The programmes should be there again but may not work correctly it's a fingers crossed job. The only other way to restore is if you have a restore partition on your hardrive or a restore disc, but normally there would be a programme built in to restore the notebook to factory settings.
Posted on Sep 03, 2007
SOURCE:
Restore Acer aspire laptops to English factory settings
If you click onto the "Start" and then go into Programmes, you should see at the top "Acer" click on this, and you can reset the Net-book to it`s original factory settings, or choose the other options. This is the manufactures settings, where it was made. Not quite sure what you mean by English factory settings? Good luck
Feb 19, 2015 | Acer Computers & Internet
I'm trying to restore my Dell Inspiron 5160 to the factory settings
If the restore partition is still there, press F8 just before boot and select restore. You will lose all data and programmes will need to be reinstalled.
Feb 09, 2015 | Dell Inspiron 5160 Notebook
Factory restore
1. Turn on or reboot your system. When the Fujitsu logo appears, press the [F12] key.
2. From the Boot Menu, that appears, check whether the <Recovery and Utility> option is present.
If it is not present, it means that the utility must be used from the disc.
Proceed to "Running Recovery and Utility from the Bootable Disc" , if <Recovery and Utility> is unavailable.
http://support.fujitsupc.com/CS/Portal/s...
Dec 22, 2013 | Fujitsu LifeBook AH530 NoteBook
How do u change the way all of ur apps and stuff? Like i accidently made everything into a list. so now everything changed . so how can i make it go bak to normal?
simply restore the pc back to old setting where everything is normal, for this go to programme - accessories - system tools- system restore
Jul 25, 2011 | LG Computers & Internet
Hi there my daughter accidently put voice over on my iphone 4 now i cant get into my phone can you please help?
if she cannot open it, then you need to plug it into a computer and restore it, this should remove the voice, if that doesnt work use itunes again to restore to factory settings, this will remove the voice for sure, luckily any apps you may have downloaded would be in the app library in itunes, so all will be fine, i hope this helps
Mar 30, 2011 | Computers & Internet
How do i reformat my toshiba laptop with windows 7 preinstalled
Within drive "D" there is a restore section. Start the laptop and as it is booting, press F8, that will open a menu allowing the startup of a restore programme. This will return your laptop to the factory setting.
Hope this helps.
Nov 12, 2010 | Toshiba Satellite P35-S611 Notebook
My acer laptop needs restoing
To restore to factory setting, power up the laptop, when you see the logo, press both Alt and F10 key, it will initiate the recovery program. Follow the instruction on screen to restore to factory setting.
CompQ
May 11, 2010 | Acer Aspire One PC Notebook
Acer 5535 how to restore back to factory settings
Hi
Thank you for your query
Restoring a laptop back to its factory settings can be done in one of 2 ways
1) Some manufacturers provide the recovery CD/DVD, simply put this disc in and restart the PC, the DVD/CD should boot and then you can follow the onscreen instructions
2) Some manufacturers provide hard drive based recovery, this mean rather than provide a CD/DVD,manufactueres put the recovery on a section of the hard drive. To use this method you click on start>Programs then find the name of the manufacturers folder. In this folder there will be a programme titled system recovery, factory settings. Click on this and follow through on the instructions
If this has been useful please leave postive feedback/vote
Feb 11, 2010 | Acer Aspire 5535-5050 Notebook
Deleted drivers
click start find my computer and right click and select properties, should come up with system info and a tab at the tob "device manaager" secet device manager and select action -> scan for any hardware changes.
This should reslove the issue. failing that use system restore using restore point before doing factory restore
to do this click start and type in rstrui.exe press enter
Feb 02, 2010 | eMachines E620-5885 Notebook
How do i restore my lasptop to the factory settings
To restore your acer to its factory installation status (formats C: and removes all data) press ALT and F10 repeatedly on first boot. This should take you to the acer restore program which is partioned onto the hard drive.
Alternatively use the acer e recovery program to create a set of boot disks which will allow the same operation.
Nov 25, 2008 | Acer Aspire 5315 Notebook
Open Questions:
See all Toshiba Satellite P105-S6207 Laptop Questions
Toshiba Satellite P105-S6207 Laptop Logo
1,470 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
