Wants to uninstall unused components of windows
I want to uninstall unused componets from mx windows xp sp2 system... i got a coding to show to hiden componets in xp to show in ctrl panel-->add or remove windows components.but i cant able to do it correctly..... i read some ware the we can remove some components that i not able to use other than in America.... my location in "India" so plz give me solution for both this problems
    Problem Solver:
  • 6 Answers
I do believe that if you go to add or remove programs there should be a tab that has add remove windows components.
Posted on Sep 04, 2007
SOURCE:
Remove unused software
if you know the softwares you want to remove, you can go to Add/Remove section in the Control Panel to uninstall them. For Windows Components, go to Add/Remove, click Add/Remove Windows Components, then uncheck the components you want to uninstall.
Aug 29, 2010 | Computers & Internet
It says that itunes requires that your computer is running xp sp2 or newer what can i do?
Update your PC/laptop using the Microsoft Update.
or
You can check the requirement in installing Microsoft XP Service Packs to your system @ http://support.microsoft.com/kb/322389
Aug 09, 2010 | Computers & Internet
Cyclic boot and reboot after installing SP2
If you have the Windows XP recovery disk you should boot into the disk and do a repair install of the Windows OS. You can also press 'F8' before or right after the Windows XP splash screen comes up and tell it to either boot into Safe Mode or "Boot with last configuration that worked". If you boot into safe mode, go to control panel and programs and uninstall the sp2 installation. Please comment back if you need further assistance. I will be providing a How-To on how to recover a system using system CDs today.
Good Luck,
NOLA Tech
Jan 27, 2010 | Computers & Internet
Fsx problem
To properly install or upgrade to the MSXML 4.0 SP2 SDK, uninstall the previous version of MSXML 4.0 and then install MSXML 4.0 SP2 and then install the follow : (copy and paste below)
download.microsoft.com/download/9/6/5/9657c01e-107f-409c-baac-7d249561629c/MSXML4SP_RelNote.htm
May 07, 2009 | Computers & Internet
Can set up Windows XP to show hidden files/folders
go to controal panal in start then folder options then the view tab
You will have a option to view all hiden folders xp by default will have this turned off Thanx for using Fixya
Feb 17, 2009 | Microsoft Windows XP Professional
My motherboard doesn't make sound
check in device manager and see if the driver shows
if it shows click and update
let me know
Jan 21, 2009 | ASUS P5VDC-MX Motherboard
WINDOWS XP SP2 DRIVERS FOR COMPAQ PRESARIO DESKTOP SG3510IL
I checked the Compaq website and since this system was built for Windows Vista they do not have any drivers available for Windows XP. If you know the individual componets of your computer you could try each component manufacturer to see if they have available drivers for XP. Sorry.
Dec 25, 2008 | Computers & Internet
Audio Hardware Detection
check the website for newest drivers if not you have to reinstall then install sp3 and hope your drivers work again. or just stick with sp2.
Jul 02, 2008 | ASUS P5VDC-MX Motherboard
Printer error message when tried to print test page
You are going to need SP2 to run many applications, doing system restore to before SP2 setup will make SP2 unusable.
If you can install, the printer on a different plug. Uninstall and re-install drivers as suggested on other post, afterward connect printer to new port, drivers will work differently.
You can also try this:
Disconnect printer.
Remove drivers
Uninstall sp2
restart pc
re install SP2
Download and install latest drivers
connect printer
In this way there are less chanches for driver interfeering with sp2. Use last driver version, older drivers may not work well on sp2.
If this had been helpful vote my solution in the other thread. Thanks
Apr 15, 2008 | Office Equipment & Supplies
About windows setup
Hi niket_shah, sorry but you're board Asus M2N-MX, does support Win XP SP2.
Chances are that while installing windows updates one or more updates failed. People like myself know from repairing PC's which updates need to be installed first. If you're Win XP SP2 did not or would not install than either the Win CD is not a valid Microsoft Win XP SP2 CD or (You have a copy) & there is something wrong with the CD. After a fresh (New install) of Win XP with SP2 there is more than 90+ updates for SP2 which must be downloaded through windows update program. Or you're windows will not function properly.
Just to show you what versions of windows the M2N-MX board does support. Click the link listed below. Once the link loads click the + sign next to Audio. Scroll down the page an notice the different Window version listed for you're board.
http://support.asus.com/download/download.aspx?modelname=M2N-MX&SLanguage=en-us
To recap this issue. The problem is either the WinCD or possibly you're hard drive. Make sure you allow windows to perform a full format before installing window. (Not a quick format).
Mike
Apr 12, 2008 | ASUS M2N-MX Motherboard
Open Questions:
Computers & Internet Logo
141 people viewed this question
Ekse
Alun Cox
