Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub-Zero 550 with Bottom Freezer
We have a 20 yr old Subzero 550. The freezer works well (zero degrees at setting 5) but the refrigerator is not keeping cold (currently 48 degrees on setting 10). No ice build up on lower left of back panel. What do you think is the cause and steps to troubleshoot. Is it time to stop putting money into something 20 yrs old? What is usual life expectancy? Thanks
  • massoud_p Sep 11, 2008
    The refrigerator is not cold enough. the compressor is running all the time and when I push the needle in freon valve a little, oil comes out instead of freon.
    Is it because of low freon pressure or bad compressor? Which type of freon is used in this model S-Z 550?
  • Anonymous Mar 27, 2014
    our refrigerator is set to 5 degrees but everything inside is almost frozen now, we expect the temperature in the refrigerator to be around zero.. the temperature suddenly dropped. Could it be some problem with thermostat?
  • 175 Answers
The life expectancy of these is as long as you want to fix em. I stll work on plenty of them builty before 1980. You may have to pay $900 for a bad compressor, but the fridge replacment cost is around $600, so it's up to you. take the back wall off behind the shelves an look at the coils. If the coils are frosty on only part of the coils (less than 2/3 I would say) Then you have a freon leak. likely from the evaporater (this will need to be cut out and soldered in with aq torch) If you have all frost top to bottom, defrost it, turn down the setting, and check that your door seals well and the door doesnt bounce open when you swing it shut. If there is no frost at all, feel the frame around the door opening. If its warm, take of the upper grille and then the upper sheild on the left side (2 screws). Use a flashlight to shine trough the condenser (thing on the right, looks luike a radiator) if you shine a light throuhgh towards the fan, but cannot see the light come through on the fan side, you need to vacuum off the condenser and try again. If light still does not get through, go to your local auto parts store and buy 2 cans of NON FLAMMABLE brake cleaner. Unplug the unit and hose the condenser down with the stuff untuill you can see light through it from the flashlight. this will be messy, so have a spare rol of paper towels handy. The fumes will be bad too so open a window and put a fan in if you can. If the frame of the fridge is not warm, and there is no frst, discannect the cold controll and use a piece of wire to connect the two wires together after you disconnect them from the cold control. Do not connect the green wire, and be carefull as ther will be 110volts in one of those 2 wires if you didnt unplug the fridge. let the thing run with the control bypassed for 15 minute or so and watch the coils to see if they frost. If they frost all the way, top to bottom, replace the cold control (one for the fridge on the right, by the way)Hope you can get the info you need out of this. Good Luck!
Posted on Sep 07, 2007
I have 685, what is the best temperature for the fridg and freezer
Dear strusler,
We recommend that the refrigerator be set at 38 degrees F and that the freezer be set to 00 degrees F.
If you have any further questions or concerns regarding this or any other issue, please contact us directly. You can contact us via phone Mon-Fri. 8:00-5:00 CST at 800-222-7820. We can be reached via email at CustomerService@SubZero.com.
Thanks!
Customer Care Team
Sub-Zero/Wolf Appliances
Feb 21, 2011 | Sub-Zero 650 / O Bottom Freezer...
I have a sub zero (model 550) bottom freezer. Moisture appears to gather at the right side of the freezer then ices up to the point that the drawer can not be opened. I have replaced the drawer seal and...
I had this problem several times and have learned alot. Hopefully some can benefit from my learning and mistakes.
On the inside of the freezer on the right is a drain tube. The defroster cover flows into this little drain. This drain goes into the pan at the bottom of the freezer, and the water evaporates. My subzero 550 had an old drain heater already in there, but obviously not working properly.
First, defrost the freezer completely. I had also poured hot water down this little tube, but this takes too long, and doesn't clear the drain completely. Also, see if you can tolerate turning the freezer temp setting down. I had mine at 1, and it was sufficiently cold. With this simple method, note the weeks /months until it happens again. If you can live with this, you are done.
If not, order a drain heater (contact Clarke Customer at 800-305-0722 and order item number 4202160, Freezer Drain Heater - under $40). I installed this and got some success, and am still counting the weeks after 8 have already passed.
Good luck
May 16, 2010 | Refrigerators
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
My subzero 550 ice maker is not making ice
My subzero model 550 is not making ice after I shut the water off for a plumbing repair. Now that I turned water back on my icemaker is not working.
Jan 24, 2010 | Sub-Zero Bottom Freezer Refrigerator
Fridge side light is off. fridge works
check if your bulb is busted, have it replace
Nov 14, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub zero bottom freezer access
that unit must be 20 plus years old. There wouldn't be any diferent shelves available for it.
Jan 31, 2009 | Sub-Zero 650 / O Bottom Freezer...
Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero Model 550, freezer not working properly
Blow out the condenser with an air compressor. Make sure the evaporator coil is not frosted up, if so, the drawer may naot have been closed properly, or you may have a defrost problem, (timer, terminator, etc). Possible freon leak in the high side drain loop. Compressor may not be pumping efficiently, could have a bad condenser fan motor.
May 28, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
1,250 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
