Question about Sub-Zero 680 / S
Refrigerator Model FR23W3aw0 Frigidaire
The ice and water in my refrigerator are absolutely GROSS. I would like to change the water filter on my refrigerator but I can't find it on the refrigerator. When I type this model number in I get 0 results. My husband went to Sears and bought a universal filter to replace the one on it. Could you tell me where it is located on the refrigerator and how to replace the filter? Thanks, ljreaney
  • ljreaney Sep 05, 2007
    I don't see a plastic case that holds the filter in the side on the right top. Thanks for the info though.
  • Anonymous Jun 14, 2008
    I need to replace my filter and do not know where is is located and I cannot find my owner's manuel
There is probably an inline filter - it would be located under the ref. between the front connector and the source of the water
Posted on Oct 28, 2008
  • 291 Answers
Cant bring up that model # there in the refrigertor side top right... in rouund like the fliter, plastic case most filters usually just turn counter clockwise to come off
Posted on Sep 04, 2007
My frigidaire refrigerator has terrible chemical smell
FOUL TASTE OR SMELL IN ICE OR WATER FROM FRIDGE
Check ice and water filter: If equipped, the Ice and Water filter in your refrigerator is responsible for removing any debris or contaminants from your water that may still remain after local water treatment. Most filters contain and are made up of carbon and fabric filter. Over time, the filter may become restricted and reduce the water flow to the ice maker, causing a symptom of little or no ice. Most manufacturers recommend replacing the filter every 6 months but local water conditions may require that you replace more frequently. Lastly a clogged drain line can cause a foul smell and get into the ice and water as we,,.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1
Feb 18, 2017 | Frigidaire Refrigerators
Need to get water back working
I appreciate your inquiry, Michael Dempsey!
From what you have described your Frigidaire refrigerator is not producing ice or water. You have stated that the filter has been changed and valve has been opened, you still do not have water. This could be a potential problem with the water valve or water line. I would recommend performing a manual defrost, it is possible that the line has been frozen, within your refrigerator. In order to defrost it you would need to disconnect power from the refrigerator for four to six hours. I hope this information has been helpful. -Matt
Feb 16, 2015 | Frigidaire Refrigerators
It making a noise and the ice maker stop working
Thank you for your inquiry, Joann siefert!
I see that your Frigidaire refrigerator is making noises and no longer producing ice. Have you attempted to replace your water filter? If your filter is bad that could cause ice to stop producing. I would recommend changing your water filter to see if that would help correct your issue. The noise could be a normal operating noise. If you have your manual you can look inside for normal operating noises. If you need your manual could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the inside wall of your refrigerator. With that information I can further assist you. -Matt
Jan 23, 2015 | Frigidaire Refrigerators
Does the refrigerator filter filter the ice maker too
Hey friend, that's a great question!
For our Frigidaire refrigerators the water filter does in fact filter the ice maker too. The water enters your refrigerator from the water valve and then goes into your filter. It is then distributed between your ice maker and water tank. Hope this information has been helpful. -Matt
Jul 26, 2014 | Frigidaire Refrigerators
Why is our ice maker not making enough ice
Good Afternoon Friend,
I understand your Frigidaire refrigerator is not making enough ice. I suggest changing your water filter. It is recommended you change your water filter every 6-8 months. If you have not done so, please try changing it. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave me your model number. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire Refrigerators
No water in ice maker and water dispenser
Good Morning Friend,
I understand your Frigidaire refrigerator is not making ice and not dispensing water. I suggest starting by changing the water filter in your refrigerator. You should be changing the water filter about every 6-8 months. If this does not work, I also suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try getting water out of the dispenser. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Refrigerators
Water dispenser does not work
I understand that the water dispenser on your Frigidaire refrigerator does not work. First, I suggest changing your water filter, making sure that the filter is flush with the filter housing. Secondly, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try to get water out of the dispenser. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. If further troubleshooting is required, please leave me the model number of your refrigerator. Typically you can find this number inside the refrigerator on the right hand wall. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
Frigidaire KSRA22 CNWHOO Side-by-Side refrigerator, Serial # SS1241434 I just changed the filter in my Frigidaire refrigerator. It had stopped making ice when the filter light came on. However, now...
Are you getting any water.
If you push the tab for water any you hear a buzzing or humming sound with no water then it could be you water pump which is located at the back of the fridge.
Just follow the water line and you will find it .
It's a small pump
May 26, 2017 | KitchenAid Superba Architect KSCS25INSS...
Need to find were water filter is to change model R134a
R134a is the refrigerant that is pumped through the compressor. The water filter is for the water dispenser and the ice maker, it has absolutely nothing to do whatsoever with the refrigerant. If you have a water filter on your model, and its possible you dont, it will be located inside the fresh food section at the top.
Oct 09, 2010 | Frigidaire Refrigerators
No water to the ice maker
filter cracked because it froze . changing the filter is not enough change the housing . as the lines are frozen and wll brake . mm
Apr 18, 2010 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
122 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
