Question about Mach Speed (MSNV-939) Motherboard
No boot on start up all fans start but no video
Hello I just put together a new system with all new components from the ground up. mach speed motherboard,AMD 64 X2 3800+ socket 939 cpu.one stick 1024MB pc3200 ddr@400mhz,Geforce 7300LE video card,1 80G sata hard drive. Well here is my problem. all the fans spin up the lights all come on but i get no boot screen just a looped beep. the sceen shows nothing i cant set the bios or anything. any help would be great TIA
  • 8 more comments
  • HERB1 Nov 03, 2007
    SAME DAM THIMG
  • Anonymous Jan 02, 2008
    PUT THE COMPUTER ON ITS SIDE SO YOU CAN GET EVEN PRESSURE AND MAKE SURE THE MEMORY STICK IS ALL THE WAY IN AND EVEN
    IT WORKED FOR ME
  • edtech Jan 30, 2008
    I got a Mach Speed MS945G-GLV mobo, and a 2.33GHZ Core2Duo, 2 gig DDR6400 RAM and a IDE HD. I hooked everything up and it won't post, no beeps or anything. The power supply comes on and the case fans as well as the CPU comes on but nothing displays.
  • Maxieg67 Mar 27, 2008
    I have the same problem, but I have matching Ram (Ultra ddr32000 1024*2) and I have tried a 2 regular VGA video cards adn S=a Saphirre radeon, no look, no post . I put the memmory in 1 and 2 is this wrong (from what I read I indred they need be in 1 and 3 - I'm ew to pc Building) i have an amd 3800 - also do I need to ground the Screws from the case as sonem people on other sites suggest?
  • crayv9 Apr 18, 2008
    My Mach Speed 939 w/amd athlon, 2gb ram has worked fine since I brought it Sept.07. Last week I let the system do a windows update but the next morning it would not post or boot. All fans spin, lights are constantly on and my dvd burnner seems to have died. I have removed connections to all devices and re-connected, reset cmos, reset memory, changed monitor and even tried another hard drive but still no video or post sound. Any Idea's?
  • Anonymous Aug 09, 2008
    MY PENTIUM 4 ONLY BEEPS 1 LONG BEEP AND THEN NOTHING SHOWS ON THE SCREEN
  • nssharma Nov 18, 2008
    please describe the specifics of your problem below.Well add your post as a comment to ffastje's your power supply ok dono't motherboard start to fan joust stop he is the problem the system.
    how are you the motherboard the fan start joust stop
  • blackstorm Dec 08, 2008
    My windows screen start up but goes black afterwards I thought my last action was when i disabled the vgasave video adapter in the display settings then when i rebooted i only see the bios and windows scree. can anyone help me with this problem.
  • wragapito May 11, 2010
    no boot but start all fans but no video
I had same problem!
I figured there was something wrong with my memory because that is what the manual says the constant beeps mean.
I bought a new PNY memory stick 1 gb DDR and got the same beeps when i put it in.
So being totally disappointed I tried putting the Stick in the #3 DIMM. I booted up and IT WORKED!
I have not called tech support or tried both 1 & 3 DIMM together but I will try after I set up the rest of my computer.
Posted on Dec 31, 2007
    New Friend:
  • 127 Answers
First Of All AMD CPUs Are Junk! Replace It With An Intel Pentium CPU,
Second If The Video Card Is Built Into The System Then Eather It Is
Defective Or Settings In The BIOS AND/OR Jumpers For THE Video Card
Are Set Incorrectley.
IF The Video Card Is Added To The PC Eather Same As Above Or It Is
Not Compatable Unless It Is Not Seated Properley Or It Is Conflicting With Another Device On The System!
Posted on Mar 04, 2013
    President:
  • 2,351 Answers
Your Mach Speed MSNV-939 Motherboard only takes matched memory. You must have two dims like 2x512 = 1gig or 2x 256 = 512. Read the manual and you will see it must be matched memory.
MAP
Posted on Dec 04, 2007
Ur procesor fan is ok,but u r nt getting any screen like POST or anything.So u must check ur moniter first.The problem may be that ur CMOS or BIOS is gone.Check ur motherboard also.
Posted on Oct 11, 2007
Check the beep-codes meaning. it may tell the error. make sure the ram is compatable and inserted all the way, and the correct direction.
Posted on Sep 04, 2007
Trio TCH843 MP3 Player: Have a new Mach Speed Trio TCH843 and wonder, whet...
I FOUND THE SOLUTION!
Hi. If you're like me you just bought one of Mach Speed's mp3/media players (I have the Trio/Eclipse Model G2, it looks like the Ipod Nano). I bought it at Big Lots for about $30. Everything works except i can't get video to play on it! Here's what i found after hours of trial and error:
Seems mine (hopefully this will work for yours) will ONLY play either FLV or RM files. If you have AVI or other kinds of video files you can use this great software to convert to FLV:
http://download.cnet.com/Koyote-Free-FLV-Converter/3000-2194_4-10832044.html?tag=mncol
It's free and it won't put a watermark on the video...which is great 'cause all the other free ones out there will. Anyway i hope this helps.
May 18, 2010 | Mach Speed Trio TCH843 MP3 Player
After power on Fans are running but no Videosignal, no bios startup.
Could be 3 things Memory or CPU or Powersupply. are you getting any beeps if so how many, how long. try taking all the memory out and powering up see if it beeps if so try to put one stick of memory in at a time and see if it will boot. if you get no beeps with memory out check powersupply some PS's have a red switch on back for current input. switch back and fourth about 20 times uning a pen and set it to the right current for you location. put ram back in see if it will boot if not its trial and error of the PS and the CPU replacement and it still could be the RAM giving false readings. yea i know sounds like a ball of fun.
Feb 24, 2010 | Intel D915GAV Motherboard
When powering up the tower, all I hear is the fans running full speed and I never hear the ''beep''. The system never comes on. Nothing on the monitor, etc.
Is this a brand new system? If so, maybe components not correctly seated inside, ie CPU or memory not seated correctly.
If this isn't a new system then in my experience it is most likely a power supply or motherboard issue. Hopefully power supply as this is normally the cheaper component of the two!
Hope this helps.
Nov 29, 2009 | Gateway GT5220 PC Desktop
2500 dell inspiron fails to boot when new fan comes on
You are drawing too much current from the power supply with the current hungry fan.Try using a different fan that draws less power on start up. Or use a limiter to lower the input voltage draw on start up. These are usually found in fan speed controls You could also use a voltage dropping adaptor like the one use to quite fans down . They drop the 12 volt voltage to 7 volts by connecting the two voltages usually found on the power connector 12v and 5v and and adding them together getting a 7 volt output. You can also try connecting the fan directly to the power supply and avoid using the motherboard connector.The problem with this is you will not get use of the speed controling sensors used in the motherboard connections. Hope this helps you with your problem.
Apr 29, 2009 | Dell (6F858) Cooling Fan
My computer wont start, no setup, no bios, nothing...
This is only a stab in the dark but are all your M/board fixing connected correctly
Hard drive etc.
One other way is to disconnect everything from M/board except for Video and memory and try to boot up if it does then connect hard drive etc one at a time rebooting each time until it will not boot that is the wrongly connected one
Oct 17, 2008 | Mach Speed MS945G-GLV Motherboard
System freeze up
Remove side of case and check ALL fans are clean and free of fluff
Check CPU heatsink vanes are clean ( usually fluff and dirt Build up in them )
Check power supply fan is working and is clean
Vacuum out care cleaning all vent holes etc especially behind power supply
when this works give us a fixya
Sep 29, 2008 | Mach Speed P4M800 (890552603480)...
Mach speed
Unplug the the dsl & any other device except the keyboard & mouse. Double check the video cable at both ends monitor & PC. Boot up system. If the system starts shut down & connect 1 device. Boot the system. OK? continue to do this. On the dsl there is a reset button. With it unpluged from power use a pen & hold in the reset for about ten seconds. Reconnect the power & reconnect the Rj45 to the PC. Boot system.
Jan 26, 2008 | Mach Speed VENOM MSA2-6100V Motherboard
P4MBMS Motherboard Problem
look for the reset jumper on the board and then reset it then try again
Jun 03, 2007 | Mach Speed P4MBMS Motherboard
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
Mach Speed (MSNV-939) Motherboard Logo
967 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
Iqbal Husain
Iqbal Husain
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
