Question about Onkyo TX-DS787 Receiver
Default volume too high
Hi. Somehow the defualt volume setting on my receiver is +10 which is more than i need. Does anyone know how i can set the default volume ( that is the volume when the receiver is switched on) to, say, zero? thanks in advance.
    President:
  • 1,114 Answers
You can download the manual from the link below: http://www.intl.onkyo.com/downloads/manuals/pdf/tx-ds787_manual_e.pdf c. Power On Volume This sets a designated volume setting for the TX-DS787 to be set every time that the power is turned on. This prevents the TXDS787 from being turned on while it is set to an extremely high volume and suddenly output very loud sounds. For the absolute volume display method, this can be set between min and max. For the relative volume display method, this can be set between ?? and 18 decibels. If you do not mind having the TX-DS787 turned on with its current volume setting, set this to "Last." Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 03, 2007
SOURCE:
Pioneer vsx 52
I am trying to work out which has got the high volume.
If it is the Pioneer then it could be the volume control chip that is faulty. These days volume is no longer determined by a control that adjusts the signal level. The signal is passed to a chip and the volume control setting information is also passed to the same chip. If the chip goes faulty then the volume will sometimes go to max, regardless of the volume control setting. This can also apply to the TV sound as well.
If the sound level is high on other functions of the receiver, such as the radio, then it is certain to be the sound volume control IC.
Nov 10, 2017 | Pioneer Elite VSX-52
Sound Setting
Starting from the main menu, select settings.
For sound select 'sounds' in the E10. There are 3 settings:
1. Custom EQ; default levels of all frequenties should be in the middle at o decibel, which means no stronger or weaker sound for all pitches from high to low.
2. SRS setting; 3 dimensional sound / surround sound effect, default setting is off / disabled.
3. Fade In: when enabled, volume will become bigger from the start of playing music. Default setting for Fade-In is disabled.
You can find a manual at iRiver Tech Support :
In the support page 'select a category' Manual and 'select a product' E10 and click GO on the right. Next select User manual of E10 and a list of several languages guides will show as a zip file.
Jul 02, 2010 | iRiver E10 Digital Media Player
Hi i need to reset my rvx 1000 to factory
Page 42 or 69:
"To reset all of the parameters to the factory-set values
Use "9 PARAM.INI" on the SET MENU to reset all of the parameter values of all DSP programs within the selected group to the factory-set values (see page 42)..."
Feb 09, 2010 | Yamaha RX-V1000 Receiver
I have install a new mother board, but when i power the computer the power come on, but no response on the monitor
Or reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defualts.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Nov 15, 2009 | Asrock K7S41GX SiS741GX Mainboard...
Ge pro-ht it beeps three times long
Nov 11, 2009 | Asrock GE Pro-HT R3 Socket 478 Motherboard...
My board will power up but i cant get any video dont know where to srt jumpers
FOr reset motherbord settings to defaults you can reset with 2 methods.
Nov 10, 2009 | PC Chips P23G Motherboard
EnV3 Ringer Volume TOO LOUD
There is a bug with this phone. All of them do this. The V05 firmware that came out 10-2-09 does not fix this. Sorry. I hate this too.
Oct 06, 2009 | LG enV3 VX9200 Cell Phone
Volume on my Onkyo Receiver
Yes it is. I have the 705. My room mate has the 605. Both AVR's will not have appreciable volume until 50 on the dial.
The dial in not linear. I don't know of anyone who has plotted the scaling of the volume control yet.
I have found much useful user info on avsforum.com. Owners post Q&A based on experiences.
Search the forum for "official onkyo TX-SR605" thread.
Some comparable info may also be found under the "official onkyo TX-SR705".
May 21, 2008 | Onkyo TX-SR605 Receiver
PCD120U volume issue
i think I know what your problem is ... if you hold down the menu/select button ( the button between the volume buttons) there will be a volume option it'll say P --- volume. I think that sets a default volume that the cd player will always reset to once the cd player is turned off then on again.
Jun 02, 2007 | Phase Linear PCD120UCS CD Player/Receiver...
Turn on volume
If you go to this link and click on "find a manual" http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=13668&langId=-1 Page 11 should tell you what you need to know :)
Apr 20, 2007 | Jensen CD4610 CD Player
Onkyo TX-DS787 Receiver Logo
456 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
