Question about Intel Thread Checker 2.1 (ITC021WSGB001) for PC
Unable to defragement the system
I am working part time in browsing center. there i cant able to perform disk defragement. it displays error msg... i tried with administrator login also.... how can i defragement the systems system config... win xp sp2, version 2002, 256 mb ddr2 ram,intel celeron board
  • nening Feb 08, 2008
    I would like to know on how to defrag my computer.I defraged it once and i would like to do it regularly
    Problem Solver:
  • 11 Answers
  • 883 Answers
Xp will not allow defrag on disk requiring error checking. run error checking utility first.
Posted on Sep 04, 2007
My Acer Aspire 5742 runs so slow even after a reboot, what can I do? Thanks. Kevin.
Hi Kevin...you can install a free software like cc cleaner and run to remove cookies and temp files on ur PC
->perform a defrag of the Hard disk
->you can increase virtual memory
->you can disable some unwanted programs at startup
->can do a registry cleanup if it works well and good if not
my email address is jalander.reddy@gmail.com please email me when ur free and ur convenient time so that i can take and work on ur PC and try to optimize ur PC performance..n it wud be for free.
Oct 01, 2013 | Acer Aspire One AOA150-1784 Netbook
Tip
How to speed up your computer's performance?
<p><b>Information:</b><br /> <p>There are some few guidelines that you can follow to maintain your computer and keep it running smoothly. <br /> <p><b>Free Up Disk Space</b><br /> <p>By freeing disk space, you can improve the performance of your computer. The Disk Cleanup tool helps you free up space on your hard disk. The utility identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.<br /> <p><b>Use Disk Cleanup to:</b><br /> <p>&bull; Remove temporary Internet files.<br />&bull; Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).<br />&bull; Empty the Recycle Bin.<br />&bull; Remove Windows temporary files.<br />&bull; Remove optional Windows components that you don't use.<br />&bull; Remove installed programs that you no longer use.<br /> <p> <br /> <p> <br /> <p><b>Tip:</b> Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.<br /> <p> <br /> <p><b>To use Disk Cleanup</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.<br /> <p> <br /> <p> <br /> <p>Disk Cleanup calculates the amount of space you will be able to free.<br /> <p>2. In the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.<br /> <p> <br /> <p> <br /> <p>Choose the files that you want to delete.<br /> <p>3. Clear the check boxes for files that you don't want to delete, and then click OK.<br /> <p>4. When prompted to confirm that you want to delete the specified files, click Yes. <br /> <p>After a few minutes, the process completes and the Disk Cleanup dialog box closes, leaving your computer cleaner and performing better.<br /> <p> <br /> <p> <br /> <p><b>Speed Up Access to Data</b><br /> <p>Disk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.<br /> <p>Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.<br /> <p><b>Run Disk Defragmenter</b><br /> <p>In addition to running Disk Defragmenter at regular intervals, optimally monthly, certain events warrant running the utility outside of the monthly rule of thumb.<br /> <p>You should run Disk Defragmenter under the following circumstances:<br /> <p>&bull; You add a large number of files. <br />&bull; Your free disk space nears 15 percent. <br />&bull; You install new programs or a new version of Windows.<br /><br /> <p> <br /> <p><b>To use Disk Defragmenter:</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Defragmenter.<br /> <p> <br /> <p>Click Analyze to start the Disk Defragmenter.<br /> <p>2. In the Disk Defragmenter dialog box, click the drives that you want to defragment, and then click the Analyze button.<br /> <p>After the disk is analyzed, a dialog box appears, letting you know whether you should defragment the analyzed drives.<br /> <p><b>Tip:</b> You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.<br /> <p>3. To defragment the selected drive or drives, click the Defragment button.<br /> <p>After the defragmentation is complete, Disk Defragmenter displays the results.<br /> <p>4. To display detailed information about the defragmented disk or partition, click View Report.<br /> <p>5. To close the View Report dialog box, click Close.<br /> <p>6. To close the Disk Defragmenter utility, click the Close button on the title bar of the window.<br /> <p><b>Detect and Repair Disk Errors</b><br /> <p>In addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.<br /> <p>As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.<br /> <p>If you use your computer daily, you should try to run this utility weekly to help prevent data loss.<br /> <p><b>To run the Error Checking utility:</b><br /> <p><b>Important:</b> Be sure to close all files before running the Error-Checking utility.<br /> <p>1. Click Start, and then click My Computer.<br />2. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.<br />3. In the Properties dialog box, click the Tools tab.<br />4. Click the Check Now button.<br />5. In the Check Disk dialog box, select the Scan for and attempt recovery of bad sectors check box, and then click Start.<br /> <p> <br /> <p>In most circumstances, select Scan for and attempt recovery of bad sectors.<br /> <p>6. If bad sectors are found, choose to fix them.<br /> <p><b>Tip:</b> Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.<br /> <p> <br /> <p>Hope this will help...<br />
on Jan 17, 2011 | Computers & Internet
Tip
Information: There are some few guidelines that you can follow to maintain your computer and keep it running smoothly.
Free Up Disk Space
• Remove temporary Internet files.
• Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
• Empty the Recycle Bin.
• Remove Windows temporary files.
• Remove optional Windows components that you don't use.
• Remove installed programs that you no longer use.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
To use Disk Cleanup
• You add a large number of files.
• Your free disk space nears 15 percent.
• You install new programs or a new version of Windows.
Tip: You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.
Important: Be sure to close all files before running the Error-Checking utility.
Tip: Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.
on Jul 05, 2010 | Computers & Internet
My computer is unresponsive or very slow nearly all the time now
When was the last time you ran disk clean up, scanned your pc for spyware and virus and finally defragmented the disks. Doing all three of these could have a big impact on the speed of it. Run all three in the order above.
Sep 30, 2013 | Microsoft Windows XP Home Edition
The computer is too slow
follow the steps below
- Delete programs you never use
- Limit how many programs load at startup
- Defragment your hard drive
- Clean up your hard disk
- Run fewer programs at the same time
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that made your system slow
Sep 22, 2013 | Computers & Internet
My new fujitsu lifebook SH877 is slow.
Follow these instructions
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 18, 2013 | Fujitsu LifeBook Computers & Internet
Acer 4720z. sluggish performance
The first thing is always make sure that you dont got any trojans, viruses, worms, or spyware on your computer.
www.avast.com Offers a HOME EDITION free Virus scanner,
Download this
Install
Remove your computer from the internet, and do a FULL SYSTEM SCAN
Step 2, would be just cleaning out the files and cookies on your computer though internet explorer.
In Internet explorer click on "TOOLS"
Then "Internet Options"
under "Browsing History, under the general tab click "Delete".
Please rate me and give me feed back, ty for your time and I hope this works for you.
Sep 27, 2009 | Acer Aspire 4720 Notebook
Cannot defrag my hard drive..
Go to Control Panel, Select System and select the Advance Tab. Now Select Settings Under Performance and again select the advance tab. Under Virtual Memory select Change. Make sure that the Paging File Size for selected Drive for the Drive partition you want to Defrag has either a custom at least 2 times the amount of installed RAM if the space is available or is set to System Managed Size.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 24, 2008 | Dell Latitude D600 Notebook
Intel Thread Checker 2.1 (ITC021WSGB001) for PC Logo
113 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
