Question about Panasonic CR-SRF100 SIRIUS Radio Receiver
Satellite receiver my sonicview satellite receiver is not responding I can't turn on it has power on the receiver screen is not channel number or clock time instead is just one digit
  • 520 Answers
Dont need factory to reflash.
turn of set at plug.press and hold backup on set(keep pressed)
turn on at plug.keep backup pressed for about 15 seconds.all lights on set will flash.if you have tv tuned to set screen will display updating system.dont turn off.when lights on set go off(about 10min later)set is reset(flashed)Press power on remote sky will restart like new.
Posted on Mar 10, 2008
My sonicview 8000 hd satellite receiver is not responding has power on the receiver screen and its booting and nothing
Posted on Dec 16, 2008
  • ram71 Dec 17, 2008
    thank you but its not working .
    Genius:
  • 1,153 Answers
Maybe resetting it will help! Sounds like eeprom problem. If only on and no channel must have some software problems. Factory may need to reflash memory.
Posted on Sep 04, 2007
How do you set time/date?
Hi, do you have the MiniTuner module in the radio? You need that in, and the antenna connected facing the SW horizon. Turn on to SATellite. Adjust antenna so that you can hear Channel 1 clearly. After you hear channel 1, the satellite will send a time signal. Then go to MENU, select Adjust time and pick your time zone and if you are on Daylight Savings time. Then, menu to exit out. Your satellite signal will keep the time updated when in Satellite mode.
I don't know if that will also set the regular clock too, or just only the time while in satellite mode. Let me know how you do with it.
Aug 19, 2014 | Timex TMX1 Satellite Radio Receiver
I have 4 TVs using 2 receivers. TV 1 and 2 use receiver VIP722K. TV 3 and 4 used receiver 322G. I bought a new Vizio tv to replace TV 4. (Note: TV 2 is also a Vizio) I tried to set up the new Vizio...
Hi, Cheri Torres with DISH Network Customer Service here. Icame across your question and wanted to see if I could help. It sounds like youmay need to either readdress your TV4 remote to your 322 DISH receiver or youcould possibly have receivers for TV2 and TV4 mixed up. Since your TV4 has "Pressselect to watch TV" on the screen you can check both of your receivers andwhich ever receiver has the TV2 blue light off is the receiver this TV runs offof. If this is not the case and you are positive that the TV4 does run off the322 you will want to take the remote to the receiver box location in order toreaddress it. I will list here for you the instructions for readdressing theremote to the receiver box. I hope you find all this information useful and ifyou have any other questions or this does not fix the issue you are experiencingfeel free to email me at Cheri.Torres@Dishnetwork.com. Thanks and have a greatday!
Instructions for readdressing your remote to your DISH receiver
  1. Go to System Info screen. You can do this by pressing the power button once then the channel up button once on the front of the receiver box.
  2. Once you are in the system info screen you will see primary remote address and secondary remote address.
  3. Hold down the SAT button until all mode lights light up.
  4. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number to something different then what is already listed in the little white square for secondary remote address.
  5. Press the pound (#) button
  6. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 4 will appear in the System Info screen under Remote Address.
Feb 16, 2011 | DISH Network IR Remote Control
I have a 2007 dodge ram pickup with sirius already built in. When I hit the sat button it is on channel 184 and there is no sound. I cant change the channel and the volume control will only let me turn it...
Hit eject button and clock button at same time. Ur Id number will show up. It will only show 4 numbers at a time. Hit seek button 2 more times to get the rest of the numbers
Jul 07, 2010 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Sirius radio does not keep last channel
Are you using the POWER button to turn it off, or just shutting off the car? Using the "power button" will usually help this situation.
Aug 16, 2009 | Clarion (NAVSIR) SIRIUS Radio Receiver
How to set the clock on vcr/dvd.
Make sure the antenna//cable TV connections are correct. Channels are set. If this unit is connected to a cable/satellite box, select the local PBS station on them to set the clock automatically.
There's an Auto Clock Setting. "This Unit can set the time and date automatically by reffering to a PBS station.". But I never had to do that, I just went to Setup and it already knew what the date and time was.
"Note: The clock may set itself automatically after you connect the antenna/cable signal and plug in the power cord. Only the analog PBS channel signal is effective for auto clock setting. The unit receives the clock data at 12:00 A.M./P.M. from the PBS channel when the power is off.
1 Press [SETUP] and use the up and down arrows to select "General Setting", then press OK.
"General Setting" menu will appear.
2. Use up and down arrows to select "Clock" then press OK.
"Clock" menu will appear.
3. Use up and down arrows to select "Auto Clock Setting", then press OK.
4. Use up and down arrows to select "Auto" then press OK.
5 Press SETUP to exit.
6. Press STANDBY-ON to turn off the unit.
This unit will search for the time only when the power is off. Leave it off for several minutes to give this unit time to set the clock.
If the unit chooses an incorrect PBS channel, set the PBS channel manually by following the steps below:
1. Select "Manual" at step 4, then press OK.
2. Use [the number buttons] or up and down arrows to enter your PBS channel number, then press OK.
3. Press SETUP and turn off the unit.
If this doesn't work, let me know and I'll type up the instructions for what to do if you need to actually set the clock manually.
Mathis...
Feb 17, 2009 | Philips Magnavox DVD/VCR Dual Player
Satellite receiver not responding
reset the receiver again and try if its responding again
Feb 06, 2009 | JVC SIRIUS Satellite Radio Interface for...
I can't turn on my satellite receiver, it has power on the receiver screen is not a channel number or clock time just one digit
Is this a Pansat receiver? If so or not then you will have to find out about Jtagging your receiver. Maybe because bad script or just cloning you have to jtagg first then rescript.
Sep 12, 2007 | Audio Players & Recorders
was you satellite tampered with? If so then it could be an eeprom jam!
Sep 02, 2007 | Audio Players & Recorders
Search internet for JTagging sonicview receiver. You will need special equipment.
Panasonic CR-SRF100 SIRIUS Radio Receiver Logo
273 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
