Question about Canon imageRUNNER 400S Copier
WHEN I AM PRINTING....DIAG FAILED ERROR IS COMING
  • 24 Answers
The printer memory card( RAM) is defective. If there is two memory card on the board remove one by one and check.Printer will work with one also.If there is only one replace the same.
Posted on Sep 06, 2007
    Sniper:
  • 54 Answers
In the printer board RAM is the problem
Posted on Aug 14, 2008
Windows 7 dell inspiron 1546 error code 2000-0146
HDD Read error, boot to the 32 bit Dell Diags, Custom, HDD, run the diag there. If you get a 0F00:xxxx error in the 32 bit diags then replace the HDD
Jul 23, 2011 | Dell Inspiron17 Notebook 22GHz 500GB 173...
I cannot get windows to load..goes to an error screen which asks me to choose repair(recommended) or start window normally...then repeats
Run diagnostics on the system (Hold Fn Key and press Power) and see if the HDD fails diags. If it does, then replace the HDD.
If the DIags PASS
Boot to your windows XP CD, press R at the 1st prompt to enter recovery console, the run the command CHKDSK /R then see if the system will boot normally.
If no go, then reboot to the WIndows CD and continue the install and try a repair install of WIndows. If that fails, then try a clean install of Windows (Delete the existing NTFS partition and create a new one)
If all those fail, replace the HDD (Passing DIAGS does not ensure the HDD is good, just the diags didn't detect the failure)
Nov 03, 2009 | Dell Inspiron 1545 Notebook
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Asi gave mine laptop compaq c700 pc notebook to hp service centre for check up. they told me that there is a hard disk problem .so the problem was "HDD test fail & check with another HDD.& all...
Only Hp knows what that means in their diags. Get it shipped back and take it to a Locally owned PC shop and have them take a look at it. It is possible that you have just enough file fragmentation and file structure corruption that it is fail diags. Why did you take it in to be looked at anyways?
Sep 11, 2009 | Compaq Presario 700 470024-192 Notebook
Error:SSG_THNK-32 Diag/Eerr(9)
create new user and your problem is solved
descomp_7@yahoo.com
Jun 24, 2009 | Office Equipment & Supplies
My Phaser 7700 Printer does not come to a ?Ready? state
This might be a bad main Image Processor (650-4307-00) board. We can isolate it by printing an internal test print.
You can power up the unit in diags (hold "back" & "info" buttons while powering up) Go to "Built in Test Prints" and try to print the "Grid 1 Dot Pattern"
If you print, then it's proven...
If not, then you will get an error that will allow further troubleshooting.
-Whit
May 10, 2009 | Xerox Phaser 7750DN Laser Printer
Samsung printer error ssg_thnk-32 diag error
There might be a firmware update on the printer, try that. Also did you try another network cable? Sometimes they go bad.
Apr 18, 2009 | Samsung SCX-4300 Monochrome Laser...
Laptop does not open windows
Boot to the WIndows XP CD, and at the first prompt, press R to enter Recovery Console. Once at the C: prompt, type CHKDSK /R and let the run, once finished, reboot and see if the system will boot.
If it still is in a reboot loop, or if CHKDSK reports unrecoverable errors, then you may have a hdd problem, run HDD diagnostics and see if you get a failure code.
If diags pass, try repairing the installation with the XP CD (Odds are fair to poor at fixing issue) if that fails try a clean install of XP (Sometimes that is the only resolution)
If the HDD fails diags or if all the above fails, replace the hard drive
Jan 26, 2009 | Toshiba Sattelite A105-S2051 Notebook
Error message on my broadcom
PXE errors (Also known as Pixie errors) occurs when the system bios setup is configured to attempt to boot to the network card (an option used in some networks to load system images)
You can boot to the system setup (F2 at Dell screen) and make sure the HDD is 1st in the boot sequence and *** if there is a setting for the network card to turn off PXE (Usually they the following options (ON, OFF, ON W/PXE, select the ON option)
If the system is failing to boot to the hard drive at all, this can be a sympton of a failing hard disk drive. You can try and confirm this by booting to the HDD diagnostic on the F12 on time boot menu or boot to the Dell Resource CD and run diags from it. If the HDD fails diagnostics, it definitely needs to be replaced. If the diags pass, it is no guarantee that the drive is good though, just an indication that no fault was found.
Dec 05, 2008 | Dell Inspiron 1501 Notebook
Canon imageRUNNER 400S Copier Logo
47 people viewed this question
old marine
old marine
