2007 BMW 525xi Sedan Logo
Posted on Apr 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1993 bmw 525i fuel pump
Where is the fuel pump located on a 1993 bmw 525i ?
  • mpaneral May 02, 2009
    1992 BMW 525it (wagon- 6 cyl) with 225K miles... Engine will turn over, but not start... My neighbor, a part time mechanic, guess is the fuel pump... Any suggestions? Also, can you access fuel pump from trunk of wagon version? Thank you
greg benton
Level 2:
  • BMW Expert 231 Answers
  • Posted on Apr 05, 2009
greg benton
BMW Expert
Level 2:
Answers
231
Questions
0
Helped
169551
Points
626
Hi, your fuel pump is located in the trunk underneath an access cover on the passenger side. remove the screws on the cover and you will see the in tank pump and sending unit. when replacing your pump, make sure to note the position of the 2 fuel hoses so you don't accidentally cross them when putting in the new pump.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Apr 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4249
Points
14
Agree. Lift up the carpet and it will be to the right (standing facing frontward) of the spare tire. Remember to mark everything...Pictures are a great way to remember...
1 Related Answer
Anonymous
  • 40 Answers
  • Posted on Apr 04, 2009
SOURCE: fuel pump 1993 bmw 525i
Hello vchinto,
The fuel pump is located inside the gas tank for your car. The easy way to get to it is from the top.
First remove the backseat or atleast the bottom portion.
Once you have the seat out of the way you will see two metal doors. Underneath the right door is the fuel pump.
I'm sure you could probably drop the fuel tank to get to it as well but this would be much much harder.
If you feel I answered your question please give me a fixya rating.
Thanks,
AadoubleA
???Location of spark plugs '93 525i
if you know where the distributer cap just follow the wire until you find it, what type of motor does it have
2answers
How to change the fuel filter to a 1993 BMW
You will need fuel line block off clamp
Location for fuel pump on 92 525i bmw
Typically, you will find the fuel pump for a BMW 525 located under an access panel in the trunk. Remove the contents of the trunk, remove the floor/spare tire cover and a metal access panel will be visible on the floor being held in by several small bolts. The panel is about 4"x6" in size. Remove the bolts, carefully pry up the panel (it has some sticky sealing material) and the fuel pump mounted on top of the gas tank will be visible with fuel lines entering/exiting it. This is where it was for my 1990 525i.
1990 521i oriiginal fuel pump -- normal whirling
you need to replace fuel pump its located behind rear seats
1993 bmw 525i. I changed the fuel pump relay, check the fuse and fuel pump is pumping. i took out the pump from the car tested with a 12v jumper and it does work. i hope someone can give a tip of what...
hello vchinto, when you reinstalled the fuel pump, did you make sure the lines were reinstalled correctly. the lines may or may not have the to and from arrows on them and can accidentally be installed backwards. if the fuel hoses are correct, check for 12 volts across the blue/green wire and the brown wire at the fuel pump connector. with the engine cranking it should be appr. battery voltage.
8helpful
2answers
Fuel pump relay 1993 bmw 525i
In the engine compartment on the passenger side under the black box towards the windshield. It is Orange
1helpful
Fuel pump 1993 bmw 525i
Hello vchinto,
Thanks,
AadoubleA
1helpful
My 1993 BMW 525i will sometimes not start after it has been running. It will fire up then die. Any suggestions? Could it be a bad check valve in the fuel pump?
hello there
I had the same problem with my 325i. I had get the fuel pump changed it was fine after that.
Hope this helps, please don't forget to rate me.
7helpful
2answers
Need location of fuel pump on a 1992 BMW 525i straight six engine
The fuel pump is located under the back seat on the passenger side. You will find an access cover and will need to remove the screws. You should be able to listen for the pump while someone cranks the car. Also I believe there is a large green w/ blue trace wire and an equally large brown wire at the connector. Check for battery voltage across the two wires. The fuse for the pump should be in the fuse panel under the hood.
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
