Question about Eclipse EA3422 Car Audio Amplifier
Interior speakers cut out when the volume is turned up
When you turn the volume up the light on the amp turns red and the interior speakers cut out. When you turn power off and back on it seems to work at a low volume then when volume is turned up the speakers cut out
  • Anonymous Dec 31, 2008
    i put 4 speakers in a 4 channel amp. wiring is fine, but the amp cuts out after a high volume???
  • 1,139 Answers
You may have speakers of an incorrect impedance attached to the unit since the problem occurs when audio signal level is increased and the current goes up.The unit is shutting down to prevent damage. I would check the speaker connections and make sure that the speakers impedance are matched for the unit you are using.
Posted on Sep 03, 2007
I have a KVT 514 unit that cuts out when the volume goes past 23. Even when I change the audio equalizer to natural and turn off the loud it cuts out. I have a 2003 accord ex v6 coupe, infinity reference n...
to me you need to do the big 3 upgrades .
1 second battery
2 bigger power cable
3 high output alternator
sound like you electrical system can't handle the high volume you want to here you system at.
it starving for power
need to upgrade your alternator to a 150 amp or bigger so your amps and factory accesories can get the voltage to run properly .
then put a second battery in trunk to help your amp
does you head lights flicker or interior lights flick signs of your car audio system killing your alternator
can help you more
Oct 14, 2010 | Kenwood KVT-514 Car DVD Player
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
If I turn the volume yp over 60 on my Onkyo
disconnect speakers turn up to 60 and see if cuts out if it does not cut out check your speakers
Apr 04, 2010 | Onkyo TX-SR602 Receiver
My 605 turns off and red light blinks when volume goes past 58
Shorted speakers can cause the unit going on protection mode (the red light blinking) when a certain volume is reached.
Test with a set of replacement speakers.
If it is not the speakers, it is probably transistors in the amp final or something nearby. Test also input output board.
Apr 27, 2009 | Onkyo TX-SR605 Receiver
1000 w sony xplode works at low volume then red lights at volume5
Most likely one of your subs are blown, or the Ohm's are too low for the ampliphier. Try hooking up one speaker at a time to the amp and see if it does the same thing. If it shuts off on one of the two speakers, that speaker is most likely blown.
Apr 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Speakers cut off when bass goes up...
sounds like you hava a load problem.if your'e running your woofers at 1ohm,make shure your amp is 1ohm stable.....
Jul 03, 2008 | Car Audio & Video
You need to check the DC voltage across the power and ground terminals of the amp. If the voltage drops below ~11v when the amp shuts off, you need to check the power/ground wiring and fuses.
If the voltage remains above 11 volts, you may have a problem with the load on the amp (incorrect ohm load, shorted speaker, shorted speaker wires...).
Jun 13, 2008 | Pioneer GM-X542 Car Audio Amplifier
it might be that your wires from your amp to your subs are too thin. since they were relatively new the first three months, they were probably undamaged, but after pushing them too much, they probably have broken wires, and can't get enough power to the subs when turned up, i suggest getting thicker wires before investing in a capacitor, it could save you money.
Mar 21, 2007 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Eclipse EA3422 Car Audio Amplifier Logo
536 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
