Question about Brother XL-3510 Mechanical Sewing Machine
Putting the bobbin back together
I took apart the pieces that holds the bobbin thread and now I can't figure out how it goes back together nor how to thread the bobbin thread so that it will sew into the fabric like its supposed to. Please help me :( I only have until tomorrow to finish my son's pants before school. Thank you so much in advance Shelby
  • 2 more comments
  • Anonymous Apr 12, 2008
    I have a bernina 930. I took aprt the bobin casing to oil and clean it. When I put it back together again it wouldn't pick up the bobbin thread.
    HELP ..HELP... HELP....... HELP .....HELP .......HELP
  • Anonymous Mar 14, 2014
    the bobbin case cover came apart and I can't get it back together
    MY BOBBIN CAME APART SND i CAN'T GET IT BACK TOGETHER
I cant get the thread on the bobbin
Posted on Jan 06, 2008
    President:
  • 1,114 Answers
You can download the manual from the link below: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_xl3500t3510eus&type2=-1&flang=English&dlid= Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 03, 2007
  • Greg Cann
    Greg Cann Sep 03, 2007
    Thanks for the good feedback, it makes it all worthwhile!
    Best regards,
    Informatica.
SOURCE:
Took my machine apart to clean & oil. Now having concern about how to put hook assembly back together. I have a manual but photo doesn't show enough detail!
This video is about removing the items in the bobbin area to clear thread tangles, but the instructions may help you figure out how to put them back together.
30 Removing Tangled Thread from the Hook Race FREE
Jan 26, 2016 | Sewing Machines
I cant figure out how to put the bobbin carriage back together on my brother vx1010
I think you're talking about the shuttle and race. It goes together like this: http://www.manualslib.com/manual/85659/Kenmore-385-15208.html?page=68
Jan 21, 2014 | Brother Sewing Machines
My daughter tried to remove a jammed bobbin on my singer machine. The bobbin holding mechanism fell apart. Is there a diagram to show how the parts fit together?
looking straight on at the area where assembly goes, First clean and oil area, the jam was likely caused by accumulated dust or a small piece of thread . You should have three pieces, four including the bobbin itself. first piece to be replaced has a center post this piece goes into the machine by fitting it to the bobbin area, it will only go in one way so when it fits into place you will know. the next piece is a ring this piece has a small piece of metal attached to the top when looking at it correctly the two screws will be on top and there should be two indentions. first one is at 3 oclock and the other is at 9 oclock fit this piece into machine and there should be a lever on either side that turns around and rests in to indentions. replace your bobbin in the bobbin case ,be sure to thread the case correctly and load into newly assembled bobbin area making sure that it clicks into pplace
Nov 06, 2010 | Singer 1120 Mechanical Sewing Machine
I broke a needle on something hard. After I replaced the needle it wouldn't go all the way down. I took the screws out and removed the piece that holds the bobbin. I can't seem to get it back in so that...
This sounds like your metal plate needs adjustment. Loosen the screws and adjust it until the needle goes all the way down. If that doesnt work, ensure that your bobbin case has been aligned properly.
Apr 07, 2010 | Brother CS6000i Computerized Sewing...
Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
May 27, 2009 | Singer Sewing Machines
I took the tension apart for a kenmore 148.15600 model
Hi - unfortunately, putting the tension back together takes alot of training - not only do you have to re-install the parts correctly so the hook is in the correct position and the bobbin is in the correct position when the needle moves down thru the needle plate and into the bobbin case to pull up the bobbin thread. Further, you need to set what called the timing - your needle needs to enter the bobbin dead on center and to a very precise depth. Technicians often use a special tool to set the timing, because each machine has a different a different hook and bobbin case.
I know this won't win me any points, but you will probably need to take the machine to a repair shop to have the hook replaced or reinstalled. If you mechanically inclined, you can search the web for a service manual for your machine - the service manual will illustrate how to replace the hook and specify the timing and needle depth settings.
Good luck,
Ginny
Jan 24, 2009 | Kenmore Sewing Machines
I took apart my bobbin case, plate andbobbin holder. I can
I had the same problem and can't find my Owner's Manual. I found the answer on-line. Hopefully, you have the same type of bobbin casing. To get the answer, go to www.startsewing.co.uk and choose "How to thread a Sewing Machine". If you have the same type of bobbin casing, you should be able to figure out the proper placement of the parts by looking at the one in the demonstration. I am thrilled (!) and hope this works for you, too.
Jan 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Cant put back together
Upload some photos of your machine, showing where you removed the parts from, also showing the parts you removed,
and I''ll guide you how to put them back.
Jun 09, 2008 | Kenmore 15516 Mechanical Sewing Machine
Bobbin casing for elna 8000
There is one small metal piece 3/4 inch long and shaped like the letter "T" that fits under the right hand needle plate snap one screw. Attach to underneath square nut and can be seen sticking out from the top holding the bobbincase in place after the top plate is replaced and everything is back together. If this is not it, a picture would help as I have repair 100's of Elna 5000 to 9000's.
SewTech
Apr 16, 2008 | Sewing Machines
Bobbin shuttle problem not solved
Did you download the manual from the link I provided? Both the normal & quick set bobbins are covered on pages 27 - 30 Here is the direct link to the manual: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000242/xl3500_t_3510ug01enes.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 03, 2007 | Brother XL-3510 Mechanical Sewing Machine
Brother XL-3510 Mechanical Sewing Machine Logo
485 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
