Question about Belkin 5 ft. Shielded Serial Cable (F3B207-06)
Belkin cable where do I find instructions to use the belkin transfer cable to vista
    Scholar:
  • 47 Answers
Why are you trying to do so with a serial cable? You can only transfer 115Kb/sec over serial... get a crossover ethernet cable and do so at 100Mb. Just ensure that you've set the ip address on both computers to a static ip... like 192.168.1.1 on the 1st and 192.168.1.2 on the second. They should be aware of each other then under Network Connections. If you've got a network device, like a hub, router, or gateway, you can use standard ethernet cables and let the network device automatically asign the network IP address.
Posted on Sep 08, 2007
SOURCE:
Ten simple sentences
What exactrly do you mean? Is this a problem pertaining to the Belkin Easy-Transfer Cable for Windows XP and Windows Vista?
Feb 16, 2011 | Belkin Easy-Transfer Cable for Windows XP...
I just purchased a new laptop that has windows 7. How do I transfer my accounts and files from my old one that uses windows xp?
From the windows 7 computer, Start, Accessories,System Tools, Windows Easy Transfer. Follow the onscreen instruction. Note both system must be on the same network.
Aug 08, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I recently purchased a Dell Inspiron 560S with Windows 7. Our present computer has Windows 2000. I bought a Belkin Easy Transfer Cable and note on the packaging it states for Vista and XP. Will it work for...
Unfortunately, Windows Easy Transfer is not supported on Windows 2000. So I would suggest you to return this cable back and use the manual method of transfer of data from one computer to another. Thanks. Abhishek
Mar 10, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Using a belkin easy transfer cable with only one monitor
Hi there. You can use the same monitor for boh the computer (just consider the annoyance of having to go to computer one, do the trick, disconnecting the monitor and connecting it to computer 2 and so on). If, what you want is to extract the files from the old pc because you are going to get rid of it and want to save them, I"d suggest you get a Hard Drive External Enclosure (between 20 and 35 dollars from most places). Connect such hard drive to it and read it via USB interface (or probably E-SATA or Firewire. Depending what do you have in your computer). Hope it helps, good luck.
Jan 05, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I have a belkin easy transfer cable. How do i transfer photo's
On the old computer, run Vista's "Files and Settings Transfer Wizard" to write one large file onto the old computer. The "export" file will contain your pictures.
Copy, via the transfer-cable, that one file to the new computer.
Run the "import" function of the Windows 7 Files and Settings Transfer Wizard to read the copied file.
Nov 17, 2009 | Dell Computers & Internet
Belkin esy transfer cable problem?
Check the easy transfer details on the link below:
http://techtake.net/2009/08/12/windows-easy-transfer-windows-7/
http://techtake.net/2009/08/12/can-i-upgrade-from-windows-xp-to-windows-7/
This may not be a direct solution, but will help you identify the problem.
I hope this helps.
Aug 26, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Connectivity problem with Belkin Easy Transfer Cable with XP and Vista. Presumably, software is installed on both machines (installed F5U258 driver on the XP machine, and was pre-installed on the Vista...
Hi..Start the file transfer on your old pc.When you get the screen to choose the option of using the transfer cable,select it..On your new pc click Start>accessories>System tools and then windows easy transfer..Follow on screen prompts and away you go..Just transfered some hol pics to my new vista machine
Feb 18, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Error installing belkin easy transfer cable
Go to Belkin's support site here: http://catalog.belkin.com/support/?lid=en, then navigate to the cable that you have and download the drivers to your hard drive. Then when the found hardware wizard comes up next you can select to install the driver from a location you'll choose (point it to wherever you downloaded them to on your hard drive). XP SP2 should have picked it up, but if your running Vista you may need Vista specific driver (should be at the Belkin support site linked above).
Good luck.
Feb 24, 2008 | Computers & Internet
Belkin 5 ft. Shielded Serial Cable (F3B207-06) Logo
91 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
