Question about Toshiba Satellite A135-S2276 Notebook
DVD RW / CD RW Drive
My laptop which has a DVD RW / CD RW Drive will not play/recognise certain original audio cd's. The disc will spin and try and read the cd but nothing happens. This is not all cd's just some.
  • 32 Answers
Uninstall the drive in the device manager.
Posted on Oct 27, 2007
    Problem Solver:
  • 8 Answers
Sounds as if your drive is failing, try buying a new drive.
Posted on Sep 03, 2007
SOURCE:
Trying to copy some pics onto a cd to get some disc space but my drive wont recognise the cd rw
do you have a cd writer or rom drive is the first thing you have to check, if it's a writer then put the disc in first and it should give you an option to write files to cd accept then follow the the instruction to add your files, assuming your running windows. iif that does'nt work check to see if your discs are + or - it may be your wriiter will only accept one kind
Mar 26, 2010 | Compaq Presario V4000 Notebook PC
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Not recognising dvd player/not playing dvds
Sounds like the laser pick-up is not reading the disc, or the spindle motor is not spinning so the dvd can be read.
Jan 25, 2009 | NEC ND-3540A DVD RW Dual Layer Burner
Computer DVD/CD Drive does not recognise any discs
The most likely cause is a faulty DVD drive. Replacing the DVD drive is fairly simple.
You can buy a new one online for around $25 including shipping. If you need help finding a drive or installing a drive, I can help with that. Just let me know.
Jan 08, 2009 | NEC Computers & Internet
Dvd burner sees CD but not DVD
I've had the same problems. some writers don't recognise certain dvd formats.I've even had the problem with a multi drive. So try different formats till your drive recognises one and stick to that format. I hope that works for you
Nov 30, 2008 | Pacific Digital (U30274) DVD±RW...
Philips DVD +RW & CD-R/RW driver
hi
please try to restart your computer while the dvd is still in the drive. this usually happens if your drive may have some accumulated dust for it will select only a few dvd to read.
Jan 15, 2008 | Philips (1B000119) 52x CD-R Storage Media
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
Nec dvd + rw nd-1100a
first try a audio CD see if ti reads that fine. then inset a data CD and see if you can see all the files on it. Try a few data and audio CD's. If it has trouble with any of these your drive has gone to the great garbage dump in the sky.
Jun 28, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Dvd-rom trouble
Hi, first of all, I'd check if you have the problem with CD/DVDs burned (written on a CD/DVD writer) or you have it also with original CD/DVDs, which would be weird. Depending on your finding to the above point I'd do one thing or another, but to me does not look like a driver problem. I'd check with Toshiba support if there's a new firmware for your drive, this does improve the media the device can read and correct problems like the one you mention. To know the fimware version you're using, open device manager and go find your drive, right click on it and choose details tab. Normally the firmware revision is the number at the end of the instance. Good luck mate !
Dec 29, 2006 | Toshiba (SD-M1212-S) DVD Drive
Toshiba Satellite A135-S2276 Notebook Logo
203 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
