Question about Hoshizaki Commercial Freezer KM-500MAH
Something wrong with Harvesting cycle, ICE will not come out, coils freeze up.
We purchased a brand new KML-250MAH put it in operation, everything works fine, except that the ice doesn't drop down. I think there is something wrong with the harvesting cycle, because when I open up the panel on the top to inspect the coils, all I see is a huge chunk of ice around it. Is there any way I can make the harvesting cycle longer? Can I manually make the harvesting cycle run so that the ice can drop down and defrost quickly? Any suggestions on what may be happening?
  • Hoshizaki Master
  • 4,655 Answers
If you need answers and have not recieved results I will try to help, I see no one responded to your request because the manual and diagnostics info seems to only be sent to people that sell and purchase the machine. If you need help and want answers  you can call me at 864-812-1887 or e-mail me at seabreezehvac@yahoo.com  your description of the problems could be many different possibilities. I want to know and help also. Thanks John Tripp
Posted on Oct 24, 2007
My kml 250mah stopped makinr this condition?g ice after descaling. what is a possible cause fo
The valve that you turn to clean the area in between the plates has a small micro switch. This prevents the compressor from running in cleaning cycle. If the compressor is running, there is another issue.
Jun 02, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Why does my KML-600MAH only make water not ice?
Check to see how long it stays in the freeze cycle. normally it takes a least 20 minutes to make a batch. If less than that, you are probably loosing water causing an early harvest and almost no ice.
Jan 12, 2013 | Hoshizaki Freezer Commercial Ice Machines...
Ice machine not harvesting
if you are sure the float swith is good and the dip switches on the board are correct, you most likely have a bad 1 minute timer on the control board. will have to replace board.
Nov 30, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KML-450MAH ice maker wont start after clean up
If you did a cleaning cycle and used the bypass valve to clean between the evap plates, look for the micro switch on the bypass valve to be bad. It is a small switch attached to the by pass and keeps the compressor off during the cleaning process. I'd start there.
Jul 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I have had my True Freezer for a short time. I bought it brand new. I opened my business on Oct 19th. Since then the service man has had to come 6 times to try to correct the problem with the defrost. To...
Hello there: You didn't give out enough informations for me to think what is wrong with a new unit like yours.. What did the serviceman been doing durring these 6 times service call. Did the unit ever work even for one day? Did he change the defrost timer or just made adjustment on the timer. What happen, is the unit icing up so much so that the unit is just a block of ice and that blocked the circulation of the freezing cold air around the unit . Ice is only 32 degree and that is why you only can get 40 degree box. May be the drain tube always frosten up that cause the ice building back up to the coil and form a big lumb of ice. Let me know what is happening , did he add some gas in everytime he service your unit? Let me know more and I will try to solve your problem. Dickson
Nov 04, 2010 | True Freezers
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Combination cooler/freezer will not get blow 30
a coil covered in ice is one of two things
your defrost is not working or your circ fan is not working
make sure the fan inside is free and spinning
the make sure your defrost timer is operational
the bev airs are usually right in front behind the toe kick
short of that ohm out your heater to ensure its working
Oct 23, 2009 | Freezers
Kenmore upright freezer
You should check the drain hose inside underneath the freezer.This is done at the back down below. Mine was looped too high and water could not get out. I took the loop off that was holding the hose and now water can drain away without freezing. You can pour warm water down the drain hole to melt the ice in the tube if you remove the grate covering it inside the freezer. I have read that several Kenmore upright freezer
owners have the same problem. I was astonished that this was the problem and I had put up with it for too long, defrosting the freezer every 2-3 months!.Give it a try!
Nov 27, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Hoshizaki Commercial Freezer KM-500MAH Logo
188 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Joe Palazola
Marvin
Marvin
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
