Question about Honeywell HS1750 Stand (Pedestal) Fan
Assembly issue the blade knob won't come off ... and it is too big, can't put the rear grill over it.
  • gospursgo Sep 03, 2007
    I have the manual. I am using terminology from the manual. The motor housing has built in shaft, approx 4" or so. The rear grill and the blade go on the shaft. Then the blade knob and the grill hub. But the blade knob is "affixed" to the shaft. I can't remove it, and the rear grill and blade won't fit over it.
    Fan has motor housing and built in shaft. Need to put the rear grill and blades over the shaft, but the "blade hub" is attached to the end of the shaft. The blade hub is about 1.5" in diameter. Prevents me from putting the grill and blade over the shaft.
    Novelist:
  • 114 Answers
THE BLADFE KNOB IS THREADED BACKWARDS ... TO LOSSEN TURN IT CLOCKWISE. ITS THAT WAY SO THE BLADE DOES NOT SPIN OFF.
Posted on Sep 04, 2007
    Sergeant:
  • 279 Answers
You mean the knob is connected directly to the blades? I'm not sure what you mean by blade knob, but does turning it turn the blades? If so, I'd suggest wedging something between the front grill and the blade to prevent it spinning and try to twist the knob off. I tried to find a owner's manual for your fan, with the assumption that there would be assembly instructions, but was unable to find one. Do you still have the owner's manual? And if so, are there any assembly instructions in there? How did the back grill come off, if you can't get it over the knob? Or are you assembling it for the first time. If you are assembling it for the first time, was the knob there when you got it? That seems poor design if so.
Posted on Sep 03, 2007
  • John Goodman Sep 03, 2007
    Sounds like there has to be a way to remove that hub. However, without any documentation, or any visuals of the hub, I'm not sure how much more can be done for you.
SOURCE:
How does one assemble the blade grill on the Goldair GPFM-401 mist fan? It seems impossible to line up the back and front grills and secure them.
There is one correct position for aligning front and rear blade guards. Unfortunately, some trial and error is required to find it.
Oct 30, 2016 | Dryers
Sear knob will not stay on (very loose fit). Other knobs seem tighter fit. The grill is brand new -- thus disappointed by post assembly quality control.
Pull the knob of of the sear burner valve shaft and check to see if it is melted on the inside, if it is, it will fit loose and needs to be replaced.
Dec 30, 2009 | Weber Summit S-470 Propane Grill
Replace burners
Remove the two screws on each side of the grill on the the burner knobs assembly. Move the whole assembly backwards, enabling the burners to pop right in. Make sure you seat them properly (its very easy, they "pop" in) but you'll have to keep an eye on the back part where they slide into the slots at back of the burner. If you push them all the way into the slots, you can't seat them properly, if you seat them all the way up into the assembly, as they will be when you put the assembly with the knobs on it back on, they don't hit the slots. Sorta halfway in is perfect.
Apr 04, 2009 | Ducane 30400040 Stainless Steel Grill
I need the assembly instructions for a Four Seasons Gas Grill
I purchased this grill and assembled it yesterday. I noted the area that is providing confusion as it is wrong. Please follow the following instructions. It is quite simple when you have a background in electrical and electronics engineering. These directions should translate my knowledge into step by step instructions for all.
1. Attach the two thinner wires with two terminals on each wire, from the front of the grill head to the larger (Input or Control) terminals on the igniter assembly. These two wires are from the push to turn micro switches on each of the burner control knobs on the grill head. Attach the two smaller terminals on these thinner wires to the micro switch on the side burner control connected as part of the regulator and hose assembly.
2. Attach the three thicker wires from the front of the grill head to three of the six smaller (output) terminals on the igniter assembly. These wires go to the igniters themselves.
3. Connect the two thicker wires from the rear of the grill head to two of the six output terminals on the igniter assembly. The small wire is for the igniter on the bottom infrared burner and the larger, thermally insulated wire, connects to the igniter on the rear infrared burner.
4. Connect the lead from the side burner to the remaining small output terminal on the igniter assembly.
5. Mount the igniter to the front of the right side shelf by removing the battery cover and hexagonal nut. Insert the shaft through the hole in the front of the right side shelf and secure with the hexagonal nut. Replace the battery cap. Do not install the battery at this time.
6. Mount the side burner control by inserting the long end of the control into the side burner assembly. Attach the control to the front of the right side shelf with the two screws held in the front of the control assembly. NOTE: You must remove the screws from the control assembly and insert them through the Off/On bezel and front panel of the right side shelf before screwing them back into the control assembly. Install the control knob for the right side shelf. Verify that the connections to the side burner control micro switch made in step 1 are still intact.
7. Insert the battery into the igniter assembly by removing the batter cap and inserting the AA size battery with the positive (pointed) end out. Replace the battery cap.
8. Test the igniter assembly prior to installing the gas tank and installing the “Flame Tamers” and grates by pushing in on each burner control knob in turn. Listen for a popping sound and look for sparks at each burner.
I hope this helps.
Ed Roberts
President
E. F. Roberts & Associates
www.efrobertsassoc.com
Mar 19, 2009 | Grilling
Burner Knobs stcuk/can't turn
I had the same issue.
Take the lid assembly off and remove the metal shield over the burner controls.
This will allow you to remove the black cover that you see on the front of the grill and will give you access to the burner controls behind the knobs.
there is an almost diamond shaped metal piece with a screw in the top and one in the bottom that the know shaft runs through.. take note how it is currently positioned and then remove the screws and the piece of metal will come off.. dont lose the spring or lock washer.
you will now have access to the valve which is your issue. i sprayed some liquid wrench and i used a large common head screw driver to "beak" the valve to allow it to turn. Test it so you know which position to return the valve to and then put it all back together.
Aug 28, 2008 | Coleman Roadtrip Grill LXE 9949-750
Knob removal
yes. it slides on a off with a little pressure.
Mar 29, 2008 | Kenmore 16225 Grill
Gas coming out near burner knobs
The issue is with the valve that is connected to the knob. it is poorly designed. To fix it take off the lid assembly and remove the front black cover that covers the knobs. remove the almost diamond shaped metal piece that the knob shaft runs through. put on your gas tank and adjust the valve to a position where no gas comes through.. might be lucky or you will have to replace that valve.
Oct 14, 2007 | Coleman Roadtrip Grill LXE 9949-750
Honeywell HS1750 Stand (Pedestal) Fan Logo
261 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
chargerhp
chargerhp
JonSnell Electronic
JonSnell Electronic
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
