Question about Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic DMC_F27 won't zoom
My camera will not zoom,I charged the battery - but that didn't help.
    Problem Solver:
  • 8 Answers
Contact panasonic, or go to a local camera shop. it sounds as if its broken and needs a repair
Posted on Sep 03, 2007
My 5 year old panasonic DMC-TZ27 seems to have jammed as it won't switch on!
Try the most basic step first. Please check if the battery is fully charged. If not it is not providing enough juice to the motor that turns the zoom lens. Please charge it fully first and give it a try.
If not, try re-setting the camera. you can find it in the menus.
if not the worst case scenario, the zoom motor is burnt, please take it to the service center for necessary repairs
Feb 22, 2015 | Panasonic Lumix DMC-TZ7 Digital Camera
Is there a long lens for the Panasonic DMC-F27?
Camera is currently equipped with a Leica 12X zoom lens. I would like to be able to take pcs. from a greater distance than this lens permits. Can you recommend a lens that I can attache to the Panasonic DMC-F27 that will enable me to do so? Thank you!!
Apr 14, 2013 | Panasonic Lumix DMC-FZ7 Digital Camera
How do you charge panasonic lumix DMC-LS6
You don't. The DMC-LS6 uses standard AA batteries, either disposables or rechargeables. If you use rechargeable batteries then you must charge them outside the camera using a separate charger. AA rechargeables and chargers should be available at just about any department, electronics, or office-supply store.
Jul 29, 2012 | Panasonic LUMIX DMC-LS6 Digital Camera,...
Panasonic DMC-TZ3: one day it's working fine, next it won't power on. Tried the "Power Saver" reset technique posted ... didn't work. Battery is fully-charged.
Hello
Try removing the battery and the memory card for 1 minute then return them back. Make sure the battery is inserted properly. If that didn't work, try turning it on without the memory card.
Did you get any error message when you try to turn on your camera?
Sep 02, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
My panasonic camera DMC-F27 is showing "memory
Hi pblac11,
This could be a problem with the format of the memory card , or the memory card is not formatted as per the requirements of your camera.
I would give you a way out to try and see if it works , as I have been through this problem myself too.
Using a card reader device , connect your memory card to your computer and make sure it gets detected in your computer.
In case you are using windows xp , vista or windows 7 , you will find the removable drive relevant to your memory card being detected.
Now all you have to do is try and format the card in a mode that is different than the current one.
For e.g if your memory card has been formatted by NTFS file system , then try changing the format to the FAT32 file system.
and if it's FAT32 already , try formatting the card with the NTFS system and then try and insert the card in your camera after it has been formatted successfully.
The above solution has helped me , hope it helps you as well..:)
Your feed back would be appreciated.
Jun 21, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
Lens won't come out after dropping camera.
Only lightly toasted. The drop likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. There is no safe DIY fix for either condition, but the camera can be repaired by the manufacturer or at a local camera shop. Make sure to get an estimate first -- you may need to decide if the camera is worth the cost of the repair.
Nov 15, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic lumix dmc fz18 won't zoom in or out after being dropped from a table. the camera can still take photos but not zoom on playback or while taking photos
The innards of modern DSLRs are precise and fragile. You need to contact a reputable repair shop ASAP. In addition to fixing your camera, they will clean the interior properly, eliminating dust particles that find their way to the CCD. The cleaning is something you should have done from time to time anyway, so just bite the bullet and take it in!
Sep 05, 2009 | Panasonic Lumix DMC-FZ18 Digital Camera
I have a lumix DMC-F27 camera it will no longer zoom. No I not in movie mode.
Do you mean DMC-FZ7?
I own one. Assuming that the camera is working normally, then I know two settings that will cause the zoom to be fixed.
Suggestion No. 1:
If the zoom is fixed at the wide end:
1. Turn the mode dial to "P". Now turn on the camera.
2. Press "MENU SET".
3. Press the up arrow button.
4. Now, a menu item named "CONVERSION" should be highlighted. Press the right arrow button.
5. A sub-menu screen should now pop up, select and set "OFF".
Suggestion No. 2:
If the zoom is fixed at the telephoto end:
1. Follow Suggestion No.1.
Suggestion No. 3:
If none of the above solve the problem, then the lens might have been knocked slightly out of position.
~If the camera has been dropped.
~If the camera has been thumped or banged.
~If while zooming, the lens was obstructed.
The zoom motor also could have died, it costs about $50.00 U.S. at Panasonic.com.
My best advice would be to contact panasonic customer service.
Jul 19, 2008 | Cameras
Panasonic Lumix DMC-tz1
lens mechanism needs cleaning ( moisture ) and possible alignment ( jarred ) ; charge or replace batteries , before getting estimate ;
Jul 31, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
130 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
