Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer won't turn on
For several days, the washer kept beeping, as if it were reading to be turned on for a normal wash cycle. However, if I pressed Start, nothing would happen. Eventually, things would clear and the washer worked fine. Yesterday, however, it happened again. This time, I unplugged the washer, thinking it just needed to be reset, and now it doesn't work at all. No lights come on and the washer is unusable at this point.
  • blaze12 Jun 08, 2008
    No lights come on on the control panel.
    I checked the home power sourse and there is nothing wrong with the recepatcle. I checked the breaker and it is not tripped. What is wrong with this thig?
  • Anonymous Jun 14, 2008
    The washing wont turn on, the ac plug is ok, it seems that the power is ok. before i pressed start i have to press transactions then press strart. but now it wont do. wht is the problem
  • 883 Answers
Try running an extension cord to another outlet (another circuit breaker). ensure the cord is not too long (25 feet ok) and able to carry 15 to 20 amps (use 12 AWG cord).
Posted on Sep 04, 2007
SOURCE:
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
The washer powers on fine, but when I select the wash cycle and press start, it beeps and nothing else happens. It will not start.
Mine is doing the same dam thing! It's new too, only a couple of months. It seems like this is a common problem from what I've read. I've lost confidence in whirlpool....
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Turn on ok. Press start and spin light blinking and beeping.
Several problems were found
1. the touch panel PCB board had tracks which were damaged by moisture and had it repaired for $50 (Aus); this affected the advance function on the washing machine.
2. Controller motor was replaced with a rebuilt one (since the touch panel kept on shutting down).
3. Make sure that the wire holding the harness reed switch is tight (this I think controls the level in the washing machine).
Apr 13, 2009 | Fisher Washing Machines
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Whirlpool Calypso GVW9959K Top Load Washer Logo
105 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
