Question about Bosch Axxis+ WFR 2460 Front Load Washer
Pump blocked message
My Front Loader Bosch Axxis+ says pump is blocked. I take off cap in front and lots of water comes out. Good for two loads then the message comes back on and it won't spin.
  • Carter456 Dec 28, 2007
    Getting the same message. Follwed manual, used drain hose, removed cap and one time there was actually something in there and removed it. That worked for a little while but the message became more frequent. Each time we followed the process above but no obstuctions. Now message comes on during each wash "as usual shutting down the cycle. Nothing behind the cap. What else could it be? Where else should I be checking?Bosch Axxis+ is only about 1 year old. Thanks
  • Anonymous Mar 16, 2014
    how to replace water pump on Bosch front load
  • 38 Answers
Next time u clean the filter when it is empty of water. put your finger in the whole and u will find somthing wound round the impeler of the pump remove what ever is obstructing and u will have no more problems make sure u unplug the machine b4 you start doing this good luck
Posted on Sep 04, 2007
Bosch Axxis washer leaks underneath
take top off at back and check valve ,it should be at the top . Also check front rubber boot for rips, this is a big problem in all brands.
Nov 21, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Water is leaking from Bosch washing machine WFL2060UC. Checked the hose connections. Lots of water comes out of drain hose after one cycle and water is pooled in the pump (place where the cap is next to...
Bosch washing machine WFL2060UC This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 13, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Last night our Bosch ''Nexxt'' front loader literally ate a sock. At least I think it was a sock. The only remains are black lent. LOTS of black lent. It is giving an E:04=not draining error code. I have...
The best wat to remove the pump, is to disconnect the washer completely from the water supply, remove the drain hose from the stand pipe, unplug the washer, and tilt the washer backwards.
remove the lower plastic panel if there is one, and access the pump from underneath at the front.
Hope this helps.
Dec 19, 2009 | Bosch Axxis WFL 2060 Front Load Washer
How do I winterize bosch front loader washing machine
Turn off the water supply to the washer, and disconnect the inlet hoses, remove the drain outlet hose and lay it down to drain any water in the hose.
Remove filter, and drain water off inside.
That should do it.
Hope this helps.
Dec 10, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Water wont drain from my front loader bosch axxis washer and no spin cycle
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
May 05, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFR 2460 washing machine
the pum should do that but the magnet side may have saturated with water beyond the seal. i recommend replacing the pump.
Mar 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
218 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
