Question about Creative Labs ZEN V Plus MP3 Player
Problem wen i pressed reset button
Wen i pressed reset button , reloading failed and it is showing reloading for more than a day and it was not detected on my system atleast as usb .the screen showing reloading
    President:
  • 4,402 Answers
· Make sure you have media player 11
· If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
Posted on Dec 13, 2007
SOURCE:
After when i reset HP Mini 110-3735dx the system no more found it( an operating system wasn t found)
redux 1
NO OS STATED before the ***** of pc. W7 was new
is it w8, w8.1 or W10 (slammed )
F11 dead. got you.
that means (list)
the hdd is bad.
or
infected with virus (damaged F11 partitions recovery)
or
some one put a Microsoft disk (not HP)
and did a install not using HP media.
bam
I call it slammed.
http://pcdied.com/XP-sux-sg.html#slammed
if I boot that PC and it run under say
knoppix 7 perfectly , then the PC is ok
if the disk test passes, then the HDD is ok
and only the partition (HP restore) is damaged or missing on said HDD.
is it missing,did you look ? we use that same linux disk to LOOK... to see
the knoppix disk tests are here. under bad hdd.
http://pcdied.com/brick-dead.html
http://pcdied.com/brick-dead.html#Knoppix
the order is this, flow)
1: is the PC ok? battery ok, coin cell ok?
2: test PC with Knoppix 7
is pc ok?
3: test PC HDD with Knoppix disk tests.
looking at SMART data first, is now out of spare clusters and lots of dead clusters growing,
yes, bad hDD, or even its dead, then we run the full hDD test using Knoppix boot stick,
4: ok hdd seems ok, i look at the Hp recover partition. using same knoppix.
is it missing, or obviously damaged or files missing?
then it was slammed.
5: we then install fresh what ever OS you want.
how to do that and choices are many.
best is the HP media kit , to make it like new.
other use other ways and take days to find all the missing pieces, (humpty-dumptied)
I can do that latter my self ,done so 1000s of times.
(I go to HP and see what is there and get all these files)
the PC came with W7, if your PC was not w7 now
that means you slammed the PC, with W10.
you have yet to say what OS you ran before it died.
if w7 great, if w10, ouch..
https://support.hp.com/us-en/drivers/selfservice/hp-mini-110-3700-pc-series/5082187/model/5111936
if you have damaged F11,
install w7 any why you can, (most ways fail)
a real MS disk from MS actual will work to a POINT.
the MS disk will miss many HP drivers. and all apps
so go to the above link and get them all
warning HP only SUPPORTS W7 on this PC> period.
Aug 15, 2017 | HP Computers & Internet
How do I reset my laptop
try to do system restore atleast 7 days back wen ur internet was working fine ...........restart the computer and keep on tapping f11 and from recovery manager u can do system restore or if u want to reset everything then u can always do system recovery from the same page but as u said it will erase all ur data from the computer but will definitely fix the issue .
May 16, 2010 | HP Pavilion 110-1030NR Notebook
Problem with tom tom 730
suggest reload tom tom software on to memory card but format card before doing so
Aug 20, 2009 | Tomtom GO 910
I cant format my usb
Try this, It might work:
i)Try to put Pen Drive or USB in usb port and insert an Windows XP CD and try restarting start and i think u the know procedure of formating Window XP or reload OS(let me say that i'm not formating or reloading OS on ur system, there is small procedure over there after that u can use system normally....)
ii) when u reach a blue screen that show all the partitions of ur system (like C: D: E:  ....), observe it will also show ur usb partition(mention memory....) separately,,, try to use this  option :
 Delete Partition by pressing D(usb partition being highlighted...) and then follow instruction .....and now  u will see that there is no partition letter(such as D, E , F) assinged to ur usb
 Now Create an partition on that by pressing C ... this will create an partition and it will retain or give  name or lettering to it(such as D, E, F)
 after this donot continue format the system, just exit from by pressing ESC button .... and ur system will start normally, ...observer usb now u will be able format.... from now..
Thanking you,
M. Sridhar.
Dec 27, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Fomatting not possible it says write protection
i) Try to put Pen Drive or USB in usb port and insert an Windows XP CD and try restarting start and i    think u the know procedure of formating Window XP or reload OS(let me say that i'm not formating      or reloading OS on ur system, there is small procedure over there after that u can use system            normally....)
Thanking you,
M. Sridhar.
My Creative ZEN 8 GB has Firmware Problems
Try uninstalling Windows Media Player version 11 from your computer before trying to reload the firmware. It works wonders.
Aug 12, 2008 | Creative Labs ZEN SLEEK MP3 Player
MS WNOM 4000
Make sure batteries are good and try
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jul 26, 2008 | Microsoft Wireless Optical Notebook Mouse...
Unable to boot up my O2 Xda Atom
Dear cafei,
Go to boot loader on your O2 XDA atom by removing batt+pressing camera button+plugging in the batt back WHILE still press holding the cam button the ue the stylus to press soft reset button, then connect to your pc via usb, then run the update program (most refer to it as DSUU, u can download one from seeo2.com) just wait for the progress to complete and you're done.
if in case you get stuck at 6%, unplug usb cable, remove battery, then insert battery while press holding the power button, while still holding the power button, press the reset button with the stylus, it should show the o2 splash, wait for any progress. then re-run the DSUU again to perform full flash.
disclaimer:
please take note that i did not suggest any 3-party rom, it is best if you try the O2-released ROM (or DSUU).
Jun 02, 2008 | O2 Xda Atom Exec Smartphone
Creative Labs ZEN V Plus MP3 Player Logo
48 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
