Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Printer it wont install anto my computer and ive used the disk that comes with it and ive conected the usb cable aswell
  • 3 more comments
  • barkinji Nov 16, 2007
    it wont load it comes up with the install and thats about it it works fine on it's own and when Itry todo anything through windows ME it keeps telling me to install the drivers can some one help
  • Anonymous Nov 18, 2007
    I have laptop with Windovs Vista and My lexmark printer X3470 Can not work, where I can download the specific driver?
  • ellivnerg Nov 29, 2007
    Wizard cant find the software for the X3470 or just comes up with a error and needs to close
  • Anonymous Dec 05, 2007
    I said "yes" to a windows update and now cannotuse the printer: software seems to be missing. I can't install either from original disk OR from a download of software! Printer was fine prior to this incident!
  • DAUNIE Feb 24, 2008
    nEED TO REINSTALL PRINTER AFTER COMPUTER HAS CRASHED. CANNOR FIND OUR DISC. WHERE CAN WE BUY AMOTHER DISC?
    Problem Solver:
Xreox workcentre pe16 on
did not show display alpabets
show only box type
did not scanner light
did not caller tone
Posted on Mar 13, 2008
    Sergeant:
  • 390 Answers
I would suggest to make a copy of the printer driver disc and use the copy to install it. If it does, you will know it had some glitches or slightly corrupted files, which can be overcome by using a copy. Good luck, post back if no good. The next step would be to check os specifications to make sure it is totally compatable with your pc, and then to download new driver from the manufacturers site
Posted on Sep 09, 2007
    Master:
    Sergeant:
  • 461 Answers
Did you turn the printer on?
Posted on Sep 04, 2007
SOURCE:
My hpdeskjet f4140 wont print a microsoft works document
Hi Josh,
Try disconnecting the usb connections to the PC.
Uninstall the printers software and reboot your computer.
Turn off the printer and then on again.
Insert the installations disk into your computer.Follow the installation instructions and connect the printer only when prompted by the installation setup to do so.
Hope this helps.Thanks!
Nov 14, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
Scanner does not work It keeps telling me "no conncetion to computer" but the printer is conected . I can copy from the computer. Wher can I find an instruction manual for Officejet Pro L7590 My last HP...
The Driver of the scanner and driver of the printer, this two miscellaneouses of the driver, in addition is fixed. Attentively install both drivers with mounting disk. Else use the cable USB from kit of the supply, scanner can not work since long шур USB.
Sep 25, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
When i plug in my shuffle nothing happens
Try connecting your iPod Shuffle to another computer. If it doesnt connect, the USB cable might be faulty, or the Shuffle aswell.
Aug 09, 2009 | Apple iPod shuffle Second Gen. Silver (1...
A Canon MP240 four-in-one no USB?
Most USB printers do not include the cable, sorry. You can get a cable at Walmart or almost anywhere, just make sure it is a USB printer cable. It will have the aprox. 3/4" wide end to match the computer and a more square end with one side of the square having an angle on two edges so it can only be pluged in one way. Good Luck
Jul 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Printer problem
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the printer USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Mar 28, 2009 | Canon PIXMA iP1600 Printer
Need to install my lexmark 1200 on my computer
Well i would recomend you to disconnect the printer from the system & then uninstall the software & then reinstall the software using the installation disks.. & in between the installation when it asks to connect the printer cable... then only connect the cable to the computer...
Jan 17, 2009 | Lexmark X1270 All-In-One InkJet Printer
Epson aculaser cx11nf all in one wont install
check under device manager, click on Universal serial bus controllers. on the list you should have USB PRINTING SUPPORT, then check on printers and faxes right click on your al-cx11nf icon and click on properties and clcik on ports tab, make sure it is set to usb001 virtual printer port \
if that doesnt work try connecting printer using ethernet or straight cable so that you will know if there is something wrong with the ports at the back of your printer
by the way make sure that it is a direct connection
Mar 09, 2008 | Epson ACULASER CX11NF All-In-One Printer
No printing
has your copier been set up with pin numbers or department counters, if so you will need to enter a valid pin no. in printer driver properties. Also go into printer properties and check printing preferences aswell as properties for any paper size/tray issues and remeber to apply any changes.
Mar 05, 2008 | Office Equipment & Supplies
No disk
look for drivers here:
http://software.canon-europe.com/products/0010094.asp
Choose the correct OS
Download
Conect printer via USB cable
Install
Print test page
Use
Don't forget to vote!
Jan 21, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
165 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
