posted by mantal on Sep 03, 2007
i have replaced the thermal fuse for the dishwahser above twice now. First time i did not replace the wires and it went out again. Next time i did replace the wires and it just went out again. What could be causing our thermal fuse to continue to blow?
Best Solution
posted on Sep 03, 2007
mantal, first thing I would check would be the power connections. I have seen a lot of these fuses blown because of loose wire nuts to line and nuetral. If that is ok, suspect one of the componets overheating. Ohm out the motor windings, with the capacitor disconnected. Should be around 3-7 ohms, run windings, 6-10 aux. windings. Check the tech sheet behind the toe panel to make sure. Next, heater element. Look for damaged element. Should ohm at 10 to 30 ohms. Leads disconnected, power off on all tests. Look for any loose connection on any harnesses. Catriver
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE Tritonr XL GSD6260JCC Dishwasher
GE Nautilus 24" Built-in Dishwasher
Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
Bosch 22 in. SKT5108 Free-standing Dishwasher
Bosch 23 in. SHU303 Built-in Dishwasher
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Can you Help with these Dishwashers problems?
Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher
had to replace the discharge... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
