Question about ASUS M2V Motherboard
M2V Replacement failing to post after initial power on
I am now on my second M2V board with an Athlon 64 X2 4200. I have 1gb ram, pc6400, 5 hd's and dvdrw. I have a 6800GS Nvidia card, and extra raid adapter in pcie x1 slot. Previously ALL components worked on previous board, but board failed after bios flash failed. The new board i have will post after resetting RTC, but if i configure the settings in the bios, it reboots and fails to post. I can allow it to use default settings but when i reboot the machine, it fails to post. I have tried to remove all hd's and dvdrw but this fails to remedy the situation. I am in the process of checking the jumpers on the board, however i fail to see how this would allow me to post on initial rtc clear, but not further on from then. I can only boot after rtc clear, but after that it fails. ANY help on the matter would be much appreciated. cheers Dom
  • Dom_M2V Sep 04, 2007
    keyboard non functional, no leds when num/caps/scroll locks active.
    I checked jumpers and they are all in a position im confident wont prevent boot, and have tried in numerous different variations.
    Ram removed, no difference. but does post after rtc has been cleared, fails to after reboot. Didnt realise it could post with no ram :)
    havent got another pci or pcie card to test out.. thankyou for the suggestions tho... :)
    one thing i found most unusual, the Day of the week in the bios. As with all bios's and most date/time programs, one cant enter in the day of the week - ie wednesday or saturday. When i set the date as 03/09/2007 (uk date) the bios detects the dotw as a saturday, yet, as we all know it was a monday.
    Could the problem lie in a bad flash from manufacturer?
  • Dom_M2V Sep 05, 2007
    second keyboard fails unless rtc is cleared. I have decided to send the board back - faulty under warranty - ill let them figure out whats wrong with the board. Thanks for the help guys, frustrating tho it is form me, having people try to help is better than going it alone!
    :D cheers
  • 883 Answers
Is the keyboard operational? also try another video card and finally remove the RAM just to POST.
Posted on Sep 04, 2007
  • Marty marty Sep 04, 2007
    ok, try another keyboard...if none disconnect keyboard as a test only.
Ibm 8215 beep codes
Here is a list of beep codes, this may help determine the problem wit your system.
1. Keyboard
2. System Board1-4-X Error detected in first 64 KB of RAM.1. Memory Module
2. System Board2-1-1, 2-1-21. Run Setup
2. System Board2-1-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-2-21. Video Adapter (if installed)
2. System Board2-2-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-3-X1. Memory Module
2. System Board2-4-X1. Run Setup
2. Memory Module
3. System Board3-1-X DMA register failed.1. System Board3-2-4 Keyboard controller failed.1. System Board
2. Keyboard3-3-4 Screen initialization failed.1. Video Adapter (if installed)
2. System Board
3. Display3-4-1 Screen retrace lest detected an error.1. Video Adapter (if installed)
2. System Board
3. Display3-4-2 POST is searching for video ROM.1. Video Adapter (if installed)
2. System Board41. Video Adapter (if installed)
2. System BoardAll other beep code sequences.1. System BoardOne long and one short beep during POST. Base 640 KB memory error or shadow RAM error.1. Memory Module
2. System BoardOne long beep and two or three short beeps during POST.(Video error)1. Video Adapter (if installed)
2. System BoardThree short beeps during POST.1. See "System board memory" on page 62.
2. System BoardContinuous beep.1. System BoardRepeating short beeps.1. Keyboard stuck key?
2. Keyboard Cable
3. System Board
Nov 29, 2011 | IBM ThinkCentre M52 8215 - P4 531 3 GHz...
Hello try the vista 64 bit driver from here:
Select the driver and hit global for download
Unzip the file before you install
Good luck
Nov 14, 2010 | ASUS M2V Motherboard
Linux fedora 12 driver for asus m2v-tvm mother board & amd athlon 64 processor
search & download driver from google and install it on ur system.
Apr 13, 2010 | Computers & Internet
How do i read the motherboard to see what board i have
The Manufacturer of the mother board is MSI and details are as follows:
Manufacturer Part # :K9MM-V
Product Type :Motherboard
Form Factor/chase: Micro ATX
Chipset Type :VIA UniChrome Pro K8M800 / VIA VT8237R Plus
Multi Core Support :Dual Core
Max Bus Speed :800 MHz
Socket Type 0 ( 1 ) :- Socket AM2
Compatible Processors : Athlon 64, Sempron, Athlon 64 FX, Athlon 64 X2
It supports 64 Bit Processor
Multi Core Support :Dual-Core
Its Supports RAM Technology: DDR II SDRAM
RAM Installation : 0 MB / 2 GB (max)
Supported RAM Speed :PC2-4300, PC2-6400, PC2-5300
RAM Features :Two DDR Channels
Video Memory :Shared video memory (UMA)
Audio Codec :Realtek ALC655
Sound Output Mode : 5.1 channel surround
Expansion Slots Total (Free) :1 processor - Socket AM2
You can addin RAM of :2 memory ( 1.8 V ) - DIMM 240-pin
PCI :3 PCI ( 3.3 V/ 5 V )
Storage Interfaces
Additional Connectors : 4 x Hi-Speed USB
Dec 21, 2009 | MSI K9MM-V Motherboard
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Dead hard drive, replacement not working
The solution is that you simply cannot go out and buy a replacement HD. You have to buy TOSHIBA's replacement HD.
They make a 40, 80, 160 and 320 GB HD for Tecra MV2's etc.- Other HDs simply will not detect.
Jun 05, 2009 | Toshiba Tecra M2V-S310 Notebook
I want to download ASUS M2v-MS Motherboard
I have the same Motherboard & processor but need to if any component has failed and whats the symptoms or are you trying to assemble one ad the PC is not starting up or not booting. Mention the OS and post your specific query as a comment to help us help you better................sodeep
May 16, 2009 | ASUS M2V-MX Motherboard
With dvi monitor goes black for 2 second then comes back intermittently
To what I understand. Dvi and vga is only applicable to a system or CPU. Sorry if I am wrong.
Mar 29, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
Unaible to upgrade RAM
It will only support up to 2GB Ram and the same memory specification
Nov 23, 2007 | ASUS M2N-MX Motherboard
ASUS M2V Motherboard Logo
126 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
