Motorola sm56speaker phone
When I dial up a connection to the net, I get a message " loop current too high, check your telephone line.the same line I used with my laptop without any problems. to connect using this modem on the PC I have to open the free hand speaker of the telephone machine.
  • Anonymous Mar 05, 2009
    When you try to dial a connection an error message box pops
    “Loop current too high, please close the application and check the telephone line connection”
If ur connected your telephone line by lan card pls check that link & speed selection.
Posted on Sep 10, 2007
How to use d link modern & rate pls
Posted on Sep 26, 2008
SOURCE:
My motorola Model K704B is saying "no line in what can I do to fix it
The "No Line" message means that the base of the cordless phone either doesn't have power, the line is damaged or that the handset/base are not communicating properly. To diagnose the problem, first check that the base AC cord is connected to a good outlet. You may want to unplug the cord from both the phone and the wall outlet and then plug it in again. (I've seen a case where someone turned off a surge protector and forgot to turn it back on; without power, the cordless phone won't work.)
To check if the problem is the phone line, I like to use an old corded telephone. Plug the backup phone in and check for a dial tone. If there is no dial tone, try a new RJ-11 cord. If there is still no dial tone, try the test phone at another jack. If you can, find the box where your telephone line service comes in. Open the box and look to see if there is an RJ-11 jack. If that jack is present, try using the test phone and listen for the dial tone. If there is no dial tone at the service box, contact your phone company. They should fix this problem for free. (It's possible that rodents have damaged the phone line outside of your home.) If the box doesn't have an RJ-11 jack, you'll need the phone company to test the service and repair it if needed.
If there is a dial tone at the service jack, then you have an inside problem. If there was no dial tone at only the first jack, you can check the jack itself. Unscrew the face plate and look at the back of the unit. There are two types of connections. If you have the screw terminals, look for a disconnected wire. Strip a new section of wire and secure it under the correct screw on the face plate. See http://cablesupply.com/content/47-telephone-connections-and-rj11 for the wiring pattern. If the jack uses a keystone, you'll need a punch-down tool that is available in many hardware stores in the electrical wiring section. Do not strip the conductor; just push it down into the correct slot of the keystone. If the problem is not at the jack, you'll need to check all of the wiring from the service box for damage. Your telephone company will do this for a fee.
If the test phone had a dial tone at all of the telephone jacks, then the problem is with the cordless handset and the base. One of the two units is not communicating correctly (transmit/receive). If your cordless phone is still under warranty, contact Motorola. If only one handset can be used with the base, replace the phone. If your cordless phone can pair multiple handsets with the base and only one handset is giving the "no line" message, replace the handset.
I hope this helps.
Feb 05, 2016 | Motorola Cell Phones
How do I check my balance for time and days remaining
From your phone:
  • Dial #WEB# (#932#) to check used and remaining high-speed data for your current billing cycle.
  • Dial 611 at any time to connect to our automated telephone system. When you're prompted, say "data usage" to check your line.
  • We've even got an app! Download and use MyAccount to check usage for your line and other lines on your account.
From your tablet or computer: Log in to your My T-Mobile account. After you log in, click USAGE to see the per-line usage under the DATAcolumn. You can even check usage history. It's that simple!
Jun 02, 2015 | Samsung Cell Phones
HOW D CHECK MY BALANCE OR DAYS AND MONUTES?
From your phone:
Jun 02, 2015 | Universal amsung Galaxy Tab 30-pin Travel...
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
Message reads: "Check tel line"
You can remove your telephone line from the base unit and fix it to stranded telephone unit and hear the dial tone.If it heard then some inductor or else part may be broken inside the base unit due high current surge.If the dial tone didn't heard from the other phone also check for the corroded line cord or modular box fault with the tel line.There should be 30 Volt-50Volt D.C.Voltage at your wire ends.
[email protected]
May 18, 2009 | Panasonic KX-TG1033S Cordless Phone
Error message -no loop current
It can't find a DIAL TONE check the line with a regular phone.
Mar 06, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Dynamode Internal Fax Modem 56K
i had same problem trying to receive faxes until i changed phone connections.
according to a motorola manual (link below) this has something to do with being connected to a "proper analog phone line".
i had the phone line running from wall to a newer gateway (maybe 8 months) dec 07 to a maybe 2 year old compaq. kept getting that loop current error on the compaq when trying to receive a fax until i elimated the gateway connection and plugged the wall right into the compaq.
here's a link that might help: http://downloadmirror.intel.com/12655/ENG/Motorola.htm
see section 6, troubleshooting. hope this helps...
Jun 27, 2008 | Computers & Internet
No loop current
Check the line cable. Try inserting that line to another telephone unit. And if there's still no dial tone the problem is on the line itself. You should call your line provider. But if the line is ok, check the LIU connectors if it is inserted correctly. It the connectors are ok, then the possible problem is on the tel. line circuit on its mainboard.
Sep 13, 2006 | Philips PPF-531 Plain Paper Thermal...
Computers & Internet Logo
599 people viewed this question
Ekse
Alun Cox
