Question about Samsung SGH-D900 Cellular Phone
Bluetooth frozen I have a Samsung D900, my Bluetooth is permanently searching for devices which causes my phone to last only a couple of hours. I have tried to deactivate, but then my phone freezes... Anyone got a solution?
  • 1 more comment
  • robjones Sep 04, 2007
    Bdeath,
    Thnaks, but it didn't work.... any other suggestions?
  • debbie5000 Mar 03, 2008
    yes my d900 keeps freezing my phone anytime i try to switch it off...thgank uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu i just tried the manufacturing default and it worked for my phonenow av been aving this bluetooth problem for the past 2weeks thank you am happy u restored my phone.
  • kgskaug Nov 17, 2008
    I had exactly the same problem.
    Resetting to Factory Defaults (through the normal Menu) did not work.
    The EEP reset code suggested by "Level4" worked for me. Slightly scary, but my Bluetooth is now at least off. Didn't need it very much anyway.
    Thanks, Level4!
  • 33 Answers
RobJones, Your bluetooth chip needs to be replaced. Unfortunately you cannot do anything about this. There is fixing resin (glue, underfill)around the bluetooth module. Sometimes, if phone has been dropped or bent, the resin will be cracked. If authorized repair service will see this, they will qualify it as BER (Beyond Economical Repair)-Customer abuse. Not authorized service can try to replace it because there is 99% chance, that everything will be ok ;)
Posted on Sep 29, 2007
  • Level4 Sep 29, 2007
    Well... There is another chance what to do... But it will delete all of data from the phone.
    You can type *2767*3855#. Your phone will be re-seted to original settings (so bluetooth should be disabled). This possibly will disable your bluetooth chip and a problem with short battery life will be solved. If you will decide to try it , let me know, if battery life was better than before.
    If you want to use your bluetooth, it needs to be replaced.
    Level4 tech.
  • Level4 May 11, 2008
    BDeath
    This security code are zeros (00000000) I don't know how many zeros, but type as much as is possible and then OK. Code "12345" is for Nokia ;)
Thanks it worked for my phone manufacturing default
Posted on Mar 03, 2008
I had the same problem went to two authourised repaiers first turned bluetooth off and second reflashed sofware phone still ate batteries in 3 to 4 hrs eventually replaced as they have a two year warranti
Posted on Oct 23, 2007
  • 58 Answers
Try to put back your default factory settings. It will ask you to put the security code. It should be 12345 or 01234. I think it will not erase your personal datas, but it will reset anything to the first day you bought it :)
Posted on Sep 03, 2007
SOURCE:
Bluetooth fails to deactivate
the chip of bluetooth works with the smal program on the cellphone.  there are two option. software or chip is broke down. should go to service.
May 29, 2009 | Samsung SGH-D900 Cellular Phone
Bluetooth pairing issue w/ jabra headset & Samsung SGH A-707
what you have to do is turn on the bluetooth of the other device and at the same time your phone's bluetooth is on. If your phone is the only device that the bluetooth is on near you then it your phone will not find a device. Cause your phone searches for another bluetooth device,therefore.....it doesn't include itself.
Sep 02, 2008 | Nokia 1600 Cellular Phone
Samsung d600 bluetooth rarely works
Hi there, it looks to me as if your blue-tooth module might have a dry joint, this is easily fixed by a repair centre, they will be using hot air to re-solder the module. This gives you a 80% repair.
Aug 12, 2008 | Samsung SGH-D900 Cellular Phone
Bluetooth from Samsung D900 (HELP PLEASE!)
nback - DO AHARD RESET *2767*3855#
KEWL - BUT YOUR BT TO SEARCH SWTCH THE JABRA ON THEN PAIR THE P/W 0000
Sep 27, 2007 | Samsung SGH-D900 Cellular Phone
Samsung d900 bluetooth help
Your bluetooth output device may have a weak signal generator. I suggest visiting an electronics store to check it thoroghly. Good Luck!
Sep 11, 2007 | Samsung SGH-D900 Cellular Phone
D900 Bluetooth
try a hard reset *2767*3855# then try again
Sep 02, 2007 | Samsung SGH-D900 Cellular Phone
I bought this device but...
when you turn on the WEP200, you must continue to hold the button down until the blue light goes solid, that indicates pairing mode. Now, have your device search for it.
Aug 10, 2007 | Samsung WEP200 Headset
Bluetooth
Pairing: Press and hold until you see a solid blue light (approximately 8 sec) then release. Search with your blue tooth phone for a bluetooth device and if finds samsung wep-150. enter pass key or pin: 0000
May 08, 2007 | Samsung WEP-150 Wireless Headset
Connecting phone to bluetooth
had the same problem but this site reminded me to hold the phone button down 7-8 seconds. I was simply not waiting long enough - took more like 12 seconds.
Apr 05, 2007 | Jabra BT250 Consumer Headset
Samsung SGH-D900 Cellular Phone Logo
516 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
